Home » Eclipse Projects » BIRT » Birt 3.7.2 and WAS (Websphare Application Server) 6.1
Birt 3.7.2 and WAS (Websphare Application Server) 6.1 [message #955037] Tue, 23 October 2012 13:03
Sibusiso Nkambule is currently offline Sibusiso NkambuleFriend
I am trying out spring and birt integration example from springsource.org (see the url below) . I am using spring 3.1.1 and birt 3.7.2.
The example works on tomcat 6.0.35 but I need to running on WAS 6.1.
Here is how the engine is started up
public IReportEngine getObject()  {
                final EngineConfig config = new EngineConfig();
                //This line injects the Spring Context into the BIRT Context
                config.getAppContext().put("spring", this.context );
                config.setBIRTHome("");
                config.setLogConfig( null != this._resolvedDirectory ? this._resolvedDirectory.getAbsolutePath() : null  , this.logLevel);
                try {
                        Platform.startup( config );
                catch ( BirtException e ) {
                        throw new RuntimeException ( "Could not start the Birt engine!", e) ;
                IReportEngineFactory factory = (IReportEngineFactory) Platform.createFactoryObject( IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
                IReportEngine engine = factory.createReportEngine( config );
                engine.changeLogLevel(Level.FINEST);
                this.birtEngine = engine ;
                return engine;
If I run it on WAS 6.1 I get there errors on the attached file (errorLog.txt).
The details of the example can be found at Quote:
( www.springsource.org/BusinessIntelligenceWithSpringAndBIRT )
Any help will be appreciated...
  • Attachment: errorLog.txt
    (Size: 104.19KB, Downloaded 383 times)
Previous Topic:[chart] custom number format - space to seperate thousands
Next Topic:DataException from 3.7 runtime when rpt designs have scripts
Current Time: Wed Jan 17 07:01:49 GMT 2018
Powered by FUDForum. Page generated in 0.01683 seconds
