Home » Eclipse Projects » Jubula » Identifying windows API window(#32770) window in RCP Application.(Jubula is not identifying the window with wndclass "#32770" which is a native windowsApi.)
Identifying windows API window(#32770) window in RCP Application. [message #953714] Mon, 22 October 2012 13:27 Go to next message
Yuga M is currently offline Yuga MFriend
Iam very new to Jubula.
My development team is moving our software as eclipse based RCP application.
so i started checking the compatability with eclipse IDE itself.
i tried to add some available software sites using button "import sites".
i got this window using the path "Window\preferences"
from left side tree clicked-> (install\update) \available software sites "
i tried to imort sites by clicking on import sites button.
but jubula is not identifing the window .
will someone suggest me how to make jubula identify that window.
Re: Identifying windows API window(#32770) window in RCP Application. [message #954846 is a reply to message #953714] Tue, 23 October 2012 09:45 Go to previous message
Alexandra Schladebeck is currently offline Alexandra SchladebeckFriend
What do you mean, the window can't be identified? Do you mean you are waiting for the window and it's not being found? Or can you not map components in the window?
If it's a native window from the operating system, you will have to use actions such as "Copy to clipboard", "External key combination" and "external text input". If it is indeed a native window, then these forum threads may help:
Previous Topic:Limit to modularization and referencing?
Next Topic:#32770 window is not detecting in Jubula
Current Time: Mon Mar 19 22:36:57 GMT 2018
Powered by FUDForum. Page generated in 0.01947 seconds
