Home » Archived » Test and Performance Tools Platform (TPTP) » Correlation functionality in TPTP 4.5
Correlation functionality in TPTP 4.5 [message #133227] Fri, 25 July 2008 13:35 Go to next message
Krishna is currently offline KrishnaFriend
Hi Experts,
I developed correlation code based on TPTP 4.2. Now we want to upgrade
to TPTP 4.5 and I get compilation erros because few TPTP APIs are
deprecated.
Following Interfaces are deprecated and I am unable to find documentation
about there replacements. Please help.
1. org.eclipse.tptp.platform.common.ui.trace.logc.extensions.
ICorrelationMonitor.java
2. org.eclipse.tptp.platform.common.ui.trace.logc.extensions.
ILogRecordCorrelationEngine.java
3. org.eclipse.hyades.logging.parsers.importer.ParserWrapper.ja va
4. org.eclipse.tptp.platform.common.ui.trace.logc.extensions.
ILogRecordFilter.java
5. org.eclipse.hyades.logging.parsers.importer.IImportWizardCon trol.java
6. org.eclipse.hyades.logging.parsers.importer.
IImportWizardControlListener.java
7. org.eclipse.tptp.monitoring.logui.internal.wizards.LogFileDe tailsUI.java
8. org.eclipse.hyades.logging.parsers.LogParserException.java
9. org.eclipse.hyades.logging.parsers.Parser.java
Krishna
Re: Correlation functionality in TPTP 4.5 [message #133282 is a reply to message #133227] Fri, 25 July 2008 14:53 Go to previous messageGo to next message
Eugene Chan is currently offline Eugene ChanFriend
Hi Krishnamurthy,
You can take a look at the TPTP 4.5 Example which is packaged in the TPTP
4.5 SDK build. The sample is under File > Example... > Logging > Log
Correlation Sample. It contains sample code for a correlator with the TPTP
codebase. There is also parser sample under the same category.
Eugene
"Krishnamurthy Chakravarthula" <chakrava@ugs.com> wrote in message
news:8d2051b5a6dff92f0eafe17d3cdeda4c$1@www.eclipse.org...
> Hi Experts,
> I developed correlation code based on TPTP 4.2. Now we want to upgrade to
> TPTP 4.5 and I get compilation erros because few TPTP APIs are deprecated.
> 7.
> Krishna
Re: Correlation functionality in TPTP 4.5 [message #133697 is a reply to message #133282] Mon, 04 August 2008 09:09 Go to previous messageGo to next message
Hi Eugene,
I downloaded TPTP 4.5 SDK and installed the plugin in Eclipse 3.4. There
are four samples under File > Example... > Logging. I could not find File
> Example... > Logging > Log Correlation Sample. Am I missing any thing?
Can you please provide the name of the file having the log correlation
sample?
Krishna
Re: Correlation functionality in TPTP 4.5 [message #133780 is a reply to message #133697] Tue, 05 August 2008 15:59 Go to previous message
You will need to also download the 'Log and Trace Analyzer SDK' for the
samples you are looking for.
Eugene
news:54ee285ba70af5aa220a8e3a4a0f4fe3$1@www.eclipse.org...
> Hi Eugene,
> sample?
> Krishna
Previous Topic:Profile using TPTP gives CoreException The process launcher seems to be inactive
Next Topic:Where did ParserWrapper go in 4.5
Current Time: Fri May 25 16:41:31 GMT 2018
Powered by FUDForum. Page generated in 0.01501 seconds
