Home » General (non-technical) » Eclipse Foundation » Error while opening eclipse(Error while opening eclipse)
Error while opening eclipse [message #952064] Sun, 21 October 2012 05:55
Sheeshkamal Vishwakarma is currently offline Sheeshkamal VishwakarmaFriend
!SESSION 2012-10-21 11:14:09.258 -----------------------------------------------
eclipse.buildId=M20070212-1330
java.version=1.7.0_09
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.equinox.common 4 0 2012-10-21 11:14:12.354
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Bundle-RequiredExecutionEnvironment: CDC-1.0/Foundation-1.0,J2SE-1.3
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:294)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:329)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1046)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:573)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:495)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:275)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:455)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:189)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:291)
!ENTRY org.eclipse.update.configurator 4 0 2012-10-21 11:14:12.393
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Bundle-RequiredExecutionEnvironment: J2SE-1.4,CDC-1.0/Foundation-1.0,J2SE-1.3
!ENTRY org.eclipse.core.runtime 4 0 2012-10-21 11:14:12.395
!STACK 0
!ENTRY org.eclipse.osgi 4 0 2012-10-21 11:14:12.399
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.common_3.2.0.v20060603.jar/ was not resolved.
!ENTRY org.eclipse.osgi 4 0 2012-10-21 11:14:12.400
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.update.configurator_3.2.2.R32x_v20070111.jar/ was not resolved.
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime_3.2.0.v20060603.jar/ was not resolved.
!ENTRY org.eclipse.osgi 4 0 2012-10-21 11:14:12.404
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:65)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.osgi 2 0 2012-10-21 11:14:12.412
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-10-21 11:14:12.412
!SUBENTRY 2 org.eclipse.update.configurator 2 0 2012-10-21 11:14:12.412
!MESSAGE Missing imported package javax.xml.parsers_0.0.0.
!MESSAGE Missing imported package org.xml.sax.helpers_0.0.0.
!MESSAGE Missing imported package org.w3c.dom_0.0.0.
!MESSAGE Missing imported package org.xml.sax_0.0.0.
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2012-10-21 11:14:12.412
!MESSAGE Missing required bundle org.eclipse.equinox.registry_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.core.jobs_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.equinox.preferences_[3.2.0,4.0.0).
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2012-10-21 11:14:12.413
!MESSAGE Missing required bundle org.eclipse.core.contenttype_[3.2.0,4.0.0).
!ENTRY org.eclipse.osgi 2 0 2012-10-21 11:14:12.414
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-10-21 11:14:12.414
!SUBENTRY 2 org.eclipse.equinox.common 2 0 2012-10-21 11:14:12.414
!MESSAGE Missing Constraint: Bundle-RequiredExecutionEnvironment: CDC-1.0/Foundation-1.0,J2SE-1.3
!SUBENTRY 2 org.eclipse.update.configurator 2 0 2012-10-21 11:14:12.414
!MESSAGE Missing required bundle org.eclipse.equinox.common_[3.2.0,4.0.0).
!SUBENTRY 2 org.eclipse.update.configurator 2 0 2012-10-21 11:14:12.415
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-10-21 11:14:12.415
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime_3.2.0.v20060603.jar/ [3] was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2012-10-21 11:14:12.415
!MESSAGE Missing optionally required bundle org.eclipse.core.runtime.compatibility.auth_[3.2.0,4.0.0).
Hi All, Can anyone plz help me on this????? I have problem when i open my eclipse, I have also attached with the screen shot...
  • Attachment: error.png
    (Size: 1.76MB, Downloaded 406 times)
Previous Topic:P2.inf Copy
Next Topic:Why is Eclipse not in the Apple App Store?
Current Time: Fri Jan 19 13:55:15 GMT 2018
Powered by FUDForum. Page generated in 0.01466 seconds
