Home » Archived » Test and Performance Tools Platform (TPTP) » is static analysis still available for TPTP 4.5
is static analysis still available for TPTP 4.5 [message #133098] Wed, 23 July 2008 11:43 Go to next message
Kristof Szabados is currently offline Kristof SzabadosFriend
Member
I have downloaded an all in one TPTP 4.5 package, and the static
analysis package, but am not able to invoke the static analysis.
/*actually as I see the static analysis packages are available in the
all in one package, but even if I copy the separate files I can not make
it work */
It seems as if the whole package could not be loaded by Eclipse as in
contrast with
http://www.eclipse.org/tptp/home/documents/process/developme nt/static_analysis/TPTP_static_analysis_tutorial_part1.html
I just don't have any "Analysis" command.
Just a short note the link on
http://www.eclipse.org/tptp/platform/documents/gettingstarte d/Static_Analysis_Getting_Started.html
is broken.
Does anyone know how to activate the static analysis feature in this
version, I was using it since Eclipse 3.2
Re: is static analysis still available for TPTP 4.5 [message #133177 is a reply to message #133098] Thu, 24 July 2008 10:24 Go to previous messageGo to next message
Paul Slauenwhite is currently offline Paul SlauenwhiteFriend
Hi Kristof,
Static Analysis has moved to a an as-is component with separate
installation instructions:
http://www.eclipse.org/tptp/home/downloads/?ver=4.5.0#AsIsCo mponents
We package 'empty' plug-ins in the GA deliverables to support upgrades
through the Update Manager.
Paul
"Kristof Szabados" <szabadosk@yahoo.com> wrote in message
news:g675gs$eir$1@build.eclipse.org...
> I have downloaded an all in one TPTP 4.5 package, and the static analysis
> /*actually as I see the static analysis packages are available in the all
> in one package, but even if I copy the separate files I can not make it
> work */
> contrast with
> is broken.
> Thanks
Re: is static analysis still available for TPTP 4.5 [message #133201 is a reply to message #133177] Thu, 24 July 2008 12:19 Go to previous messageGo to next message
Member
Hi Paul,
I don't really understand this.
I have downloaded the as-is component (for tptp 4.5) and owerwritten
with it all files that I found in the dropins folder of the all-in-one
tptp 4.5 package.
But I still don't see the usual menu, from where I could run the static
analysis on my code.
/* as far as I see this is the installation method for this component */
Actually I'm not really surprised as according to the timestamps the
as-is component versions were created about 1 minute earlier than the
all-in-one versions, and seem to have the same content.
I also tried the update manager, but after installing everything for
tptp 4.5, there was still no change.
I don't really understand what might be wrong, as there is no error log
I could refer to.
Best regards
Kristof
Paul Slauenwhite wrote:
> Hi Kristof,
> Paul
>> work */
>> contrast with
>> is broken.
>> Thanks
Re: is static analysis still available for TPTP 4.5 [message #133214 is a reply to message #133201] Fri, 25 July 2008 10:15 Go to previous messageGo to next message
Hi Kristof,
Did you restart with the -clean flag?
Paul
news:g69rvn$3k6$1@build.eclipse.org...
> Hi Paul,
> I have downloaded the as-is component (for tptp 4.5) and owerwritten with
> it all files that I found in the dropins folder of the all-in-one tptp 4.5
> package.
> Actually I'm not really surprised as according to the timestamps the as-is
> component versions were created about 1 minute earlier than the all-in-one
> I also tried the update manager, but after installing everything for tptp
> I don't really understand what might be wrong, as there is no error log I
> could refer to.
> Best regards
> Kristof
>> Hi Kristof,
>> upgrades through the Update Manager.
>> Paul
>>> Hi,
>>> it work */
>>> contrast with
>>> is broken.
>>> Thanks
Re: is static analysis still available for TPTP 4.5 [message #133329 is a reply to message #133214] Fri, 25 July 2008 15:53 Go to previous messageGo to next message
Member
Hi Paul,
Yes.
In the meanwhile I also tried to put the files directly into the eclipse
folders, instead of using the dropins, but with no difference.
Best Regards
> Hi Kristof,
> Paul
>> Hi Paul,
>> package.
>> could refer to.
>> Best regards
>> Kristof
>>> Hi Kristof,
>>> Paul
>>>> Hi,
>>>> it work */
>>>> contrast with
>>>> is broken.
>>>> Thanks
Re: is static analysis still available for TPTP 4.5 [message #133354 is a reply to message #133329] Fri, 25 July 2008 16:13 Go to previous messageGo to next message
Our Release Engineering Team just informed that you need an additional
step required due to the LTA:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=239795
Paul
news:g6csu5$e1$1@build.eclipse.org...
> Hi Paul,
> Yes.
> Best Regards
>> Hi Kristof,
>> Paul
>>> Hi Paul,
>>> tptp 4.5 package.
>>> I could refer to.
>>> Best regards
>>> Kristof
>>>> Hi Kristof,
>>>> Paul
>>>>> Hi,
>>>>> make it work */
>>>>> contrast with
>>>>> is broken.
>>>>> Thanks
Re: is static analysis still available for TPTP 4.5 [message #142440 is a reply to message #133354] Tue, 02 June 2009 11:29 Go to previous messageGo to next message
Benjamin Zeiss is currently offline Benjamin ZeissFriend
due to recent activities of mine, i have searched the net and found this
thread about the TPTP static analysis plugins not working.
Why don't you just build the as-is components and distribute them with
the TPTP package? I don't see how any normal user can possibly install
these as-is components by himself. As a developer, i spent about 3 hours
just trying to install the static analysis plugins somehow into Eclipse
Galileo. I gave up and recompiled the analysis.core and analysis.ui
plugins by myself - after that, they worked. The idea to just distribute
the plugins without classes is incredibly strange. It even took me a
while to figure out why Eclipse was reporting problems due to missing
classes as i was not aware of its as-is status (whatever that means. it
feels more like "abandoned" to me.) and just assumed that the
plugins should work when they are installed. I am seriously considering
to create our own branch of the static analysis plugins unless something
is changing here. The trouble is just too big otherwise.
Ben
Paul Slauenwhite schrieb:
> Paul
>> Hi Paul,
>> Yes.
>> Best Regards
>>> Hi Kristof,
>>> Paul
>>>> Hi Paul,
>>>> tptp 4.5 package.
>>>> I could refer to.
>>>> Best regards
>>>> Kristof
>>>>> Hi Kristof,
>>>>> Paul
>>>>>> Hi,
>>>>>> make it work */
>>>>>> contrast with
>>>>>> is broken.
>>>>>> Thanks
Re: is static analysis still available for TPTP 4.5 [message #142659 is a reply to message #142440] Mon, 15 June 2009 15:34 Go to previous messageGo to next message
Eugene Chan is currently offline Eugene ChanFriend
Hi Ben,
The owner of the static analysis component no longer work and contriube
resource in the project and due to the lack of additional resources to
support the component, PMC has decided to move it to as-is and there will be
no maintence on the component supported by the project.
Eugene
"Benjamin Zeiss" <zeiss@cs.uni-goettingen.de> wrote in message
news:h032fk$hkm$1@build.eclipse.org...
> Hello,
> Ben
>> additional
>> Paul
>>> Hi Paul,
>>> Yes.
>>> Best Regards
>>>> Hi Kristof,
>>>> Paul
>>>>> Hi Paul,
>>>>> tptp 4.5 package.
>>>>> static
>>>>> log
>>>>> I could refer to.
>>>>> Best regards
>>>>> Kristof
>>>>>> Hi Kristof,
>>>>>> Paul
>>>>>>> Hi,
>>>>>>> the
>>>>>>> make it work */
>>>>>>> in
>>>>>>> contrast with
>>>>>>> is broken.
>>>>>>> Thanks
Re: is static analysis still available for TPTP 4.5 [message #142678 is a reply to message #142659] Mon, 15 June 2009 17:18 Go to previous message
robert tomb is currently offline robert tombFriend
Eugene:
I don't see the Static Analysis Engine in any of the builds since 4.5.0.
Is it dead? If so, that's extremely unfortunate (for me). I was just going
to start working on a static analysis feature for our tooling and had
hoped to base it on TPTP's static analysis.
Previous Topic:Handling CBEs in my class lively?
Next Topic:NullPointerException with TPTP 4.6.0 RC5
Current Time: Wed Jan 17 03:37:41 GMT 2018
Powered by FUDForum. Page generated in 0.01901 seconds
