Home » Eclipse Projects » Eclipse Platform » Using key bindings for cut'n'paste in a plug-in?
Using key bindings for cut'n'paste in a plug-in? [message #133086] Fri, 19 September 2003 14:43 Go to next message
Originally posted by: oliver.klee.fit.fraunhofer.de
as a programming project at the University of Bonn, we're developing a
refactoring plug-in that displays its data as a TreeViewer. For that
TreeViewer, we have implemented cut and paste (using the context menu),
but we cannot find a way to get key bindings for CTRL+X/CTRL+V to work.
Does anyone know how to do this?
Thanks in advance,
Oliver Klee
Re: Using key bindings for cut'n'paste in a plug-in? [message #133131 is a reply to message #133086] Fri, 19 September 2003 17:01 Go to previous messageGo to next message
Originally posted by: simon.ibm.oti.lab
Assuming this is a view, take a look at IActionBars.setGlobalActionHandler
(you access the action bars via myViewPart.getViewSite().getActionBars())
Simon :-)
"Oliver Klee" <oliver.klee@fit.fraunhofer.de> wrote in message
news:bkf4i3$30e$1@eclipse.org...
> Thanks in advance,
> Oliver Klee
Re: Using key bindings for cut'n'paste in a plug-in? [message #133756 is a reply to message #133131] Mon, 22 September 2003 08:52 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
You have to bind your actions to the corresponding commands:
actionBars.setGlobalActionHandler(IWorkbenchActionConstants. COPY,
yourCopyAction);
actionBars.setGlobalActionHandler(IWorkbenchActionConstants. CUT,
yourCutAction);
HTH
Dani
> Simon :-)
>>Hi,
>>Thanks in advance,
>>Oliver Klee
Re: Using key bindings for cut'n'paste in a plug-in? [message #134254 is a reply to message #133756] Tue, 23 September 2003 09:52 Go to previous messageGo to next message
> yourCopyAction);
> yourCutAction);
Thanks a lot ... now at least I've managed to get the menu items to
work. But still the corresponding action handlers don't get called when
I press e.g. CTRL+X. =:-((
Is there anything I have to do to get the accelerator keys to work as
well? Help...!
Thanks in advance,
Oliver
Re: Using key bindings for cut'n'paste in a plug-in? [message #134908 is a reply to message #134254] Wed, 24 September 2003 11:09 Go to previous messageGo to next message
Oliver Klee wrote:
>> yourCopyAction);
>> yourCutAction);
> well? Help...!
> Thanks in advance,
> Oliver
Does your code which sets the handler get called? Is your editor
embedded in a multi-page editor?
Dani
Re: Using key bindings for cut'n'paste in a plug-in? [message #135750 is a reply to message #134908] Thu, 25 September 2003 08:26 Go to previous messageGo to next message
>> when I press e.g. CTRL+X. =:-((
>> well? Help...!
The code setting the handler gets called (as the menu items that use the
same handlers work).
Yes, the editor is part of a multi-page editor.
Thanks in advance,
Oliver
Re: Using key bindings for cut'n'paste in a plug-in? [message #135843 is a reply to message #135750] Thu, 25 September 2003 12:43 Go to previous message
>>> well? Help...!
This might be caused by one of the known problems with multi-page
editors. Check bugzilla to find out more about them.
Dani
> Thanks in advance,
> Oliver
Previous Topic:JSF plans?
Next Topic:Running applets inside an Eclipse View
Current Time: Tue Feb 20 08:17:30 GMT 2018
Powered by FUDForum. Page generated in 0.02258 seconds
