Home » Eclipse Projects » BIRT » Why can't i use Dynamic Parameters?????
Why can't i use Dynamic Parameters????? [message #132572] Mon, 20 February 2006 06:12 Go to next message
Originally posted by: aimdliu.sina.com
I create a new Report Parameters, and select "Display Type" as "Combo
Box", "Value Row" as "Dynamic". Because i want the Combo Box's data comes
from the DataBase.
Although, my Data set normally works, The DataSet List is empty.
What's the reason maybe?
I have a screen shot at:
http://aimd.blog.edu.cn/UploadFiles/2006-2/220456475.png
Thanks all
Re: Why can't i use Dynamic Parameters????? [message #132986 is a reply to message #132572] Mon, 20 February 2006 17:39 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Try it in the viewer and then select run report, it should populate.
Jason
"Xiaoliu" <aimdliu@sina.com> wrote in message
news:0d47c8ace570f0e6a231dc9688560bed$1@www.eclipse.org...
> from the DataBase. Although, my Data set normally works, The DataSet List
> is empty.
> Thanks all
Re: Why can't i use Dynamic Parameters????? [message #133107 is a reply to message #132986] Tue, 21 February 2006 00:56 Go to previous messageGo to next message
Originally posted by: xiaoz.hotmail.com
Sorry, could you say it in detail?
the DataSet is valid in other field, but, i must connect database to
initialize the report parameter, and the problem is DataSet's invalid in
report parameter edit wizard.
thanks
Re: Why can't i use Dynamic Parameters????? [message #133389 is a reply to message #133107] Tue, 21 February 2006 11:47 Go to previous messageGo to next message
When you preview with the BIRT Viewer and click the RunReport icon it should
show your dynamic parameter list filled out.
Is this not happening?
Jason
"Xiaoliu" <xiaoz@hotmail.com> wrote in message
news:8208766fd0f8110e51926f0feb079f6e$1@www.eclipse.org...
> thanks
Re: Why can't i use Dynamic Parameters????? [message #133776 is a reply to message #133389] Wed, 22 February 2006 01:13 Go to previous messageGo to next message
My birt version is 2.0.0,
when i preview the design and click "show report parameter" button, there
comes a dialog with a combo box. I want to fill the combo box with
database data not the static text, the problem is that I can't use the
database in report parameter's property, the screen shot at:
thanks
Re: Why can't i use Dynamic Parameters????? [message #133788 is a reply to message #133389] Wed, 22 February 2006 01:28 Go to previous message
I maybe know the answer, we can't fill the combobox item with DataSet with
parameters, but, dataset without parameters is ok
thanks
Previous Topic:Problems with params in drilldown reports
Next Topic:How to transfer chinese param?
Current Time: Tue Feb 20 17:57:26 GMT 2018
Powered by FUDForum. Page generated in 0.02836 seconds
