Home » Eclipse Projects » EclipseLink » NPE in CascadeLockingPolicy.initUnmappedFieldsQuery
NPE in CascadeLockingPolicy.initUnmappedFieldsQuery [message #949858] Fri, 19 October 2012 11:21 Go to next message
Jorg Heymans is currently offline Jorg HeymansFriend
We are seeing strange behaviour in our application whereby the first time after the application starts and we try to persist a new JPA entity using entitymgr.persist() the following stacktrace occurs
Caused by: java.lang.NullPointerException: null
        at org.eclipse.persistence.internal.descriptors.CascadeLockingPolicy.initUnmappedFieldsQuery(CascadeLockingPolicy.java:242) ~[eclips
elink-2.3.3.jar:2.3.3.v20120629-r11760]
        at org.eclipse.persistence.internal.descriptors.CascadeLockingPolicy.initUnmappedFields(CascadeLockingPolicy.java:217) ~[eclipselink
        at org.eclipse.persistence.internal.descriptors.CascadeLockingPolicy.lockNotifyParent(CascadeLockingPolicy.java:273) ~[eclipselink-2
        at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.calculateChanges(UnitOfWorkImpl.java:651) ~[eclipselink-2.3.3.jar:2.3.3.
v20120629-r11760]
        at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabaseWithChangeSet(UnitOfWorkImpl.java:1490) ~[eclipselink-2.
        at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.commitRootUnitOfWork(RepeatableWriteUnitOfWork.java:267) ~[ec
lipselink-2.3.3.jar:2.3.3.v20120629-r11760]
        at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitAndResume(UnitOfWorkImpl.java:1143) ~[eclipselink-2.3.3.jar:2.3.3.
v20120629-r11760]
        at org.eclipse.persistence.internal.jpa.transaction.EntityTransactionImpl.commitInternal(EntityTransactionImpl.java:84) ~[eclipselin
        ... 53 common frames omitted
This is reproducible using eclipselink 2.3.3 and 2.4.0 and 2.4.1, did not try any other versions. Our application is deployed on WLS 10.3.4 and uses Spring 3.1 with the JpaTransactionManager. It is not related to a particular JPA entity, whatever the use case is we're executing - if it is the first time that a JPA entity needs to be saved we get the exception. After this first time everything works as normally.
If there is anything i can do to provide more debug info for this let me know, it's perfectly reproducible. The only thing i cannot provide easily is an isolated testcase.
Thanks !
Jorg
Re: NPE in CascadeLockingPolicy.initUnmappedFieldsQuery [message #956339 is a reply to message #949858] Wed, 24 October 2012 12:32 Go to previous messageGo to next message
created a ticket here, hopefully someone can confirm this
https://bugs.eclipse.org/bugs/show_bug.cgi?id=392536
Re: NPE in CascadeLockingPolicy.initUnmappedFieldsQuery [message #964688 is a reply to message #956339] Tue, 30 October 2012 18:19 Go to previous messageGo to next message
James Sutherland is currently offline James SutherlandFriend
This is a concurrency bug in the CascadeLockingPolicy. Are you using cascading locking in your model?
James : Wiki : Book : Blog : Twitter
Re: NPE in CascadeLockingPolicy.initUnmappedFieldsQuery [message #965734 is a reply to message #964688] Wed, 31 October 2012 13:15 Go to previous message
(discussion continues in the bugzilla ticket)
Previous Topic:@MappedSuperClass with DynamicEntity
Next Topic:EntityManager.find(...) with pessimistic lock never throws LockTimeoutException
Current Time: Tue May 22 23:51:07 GMT 2018
Powered by FUDForum. Page generated in 0.02589 seconds
