Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWTException : Invalid image (How to check that an image is "valid" to avoid SWTException "Invalid image" ?)
SWTException : Invalid image [message #949778] Fri, 19 October 2012 05:30 Go to next message
hortiz Mising name is currently offline hortiz Mising name
Member
I use several Canvas to display images from a directory.
These are grouped in a window.
These images are created by an offscreen rendering process (JOGL API) which runs in the background on my PC.
Therefore, the window containing the canvas acts as a "real time" plot viewer.
Images are generated every second, and refreshed in their canvas every 1.1 second.
The problem that I have is that sometimes the image seems to be in an invalid state and cannot be displayed ("org.eclipse.swt.SWTException: Failed to execute runnable (org.eclipse.swt.SWTException: Invalid image)"), but I thought that the code below would have prevented this from happening:
public void updateImage(String imageName) {
	Image testImage;
	testImage = new Image(parent.getDisplay(), imageName);
	if (new File(imageName).exists()) {
		if (image != null) {		// previously displayed image
			image.dispose();
		image = new Image(parent.getDisplay(), imageName);
		testImage.dispose();
How can I be sure that my image is "valid" when I call the constructor of the Image class ? Apparently, the test on the existence of the image is not sufficient.
Is the only solution is to add a try/catch block ?
Helene
Re: SWTException : Invalid image [message #950252 is a reply to message #949778] Fri, 19 October 2012 15:04 Go to previous messageGo to next message
Grant Gayed is currently offline Grant Gayed
Yes, try/catch is the only way to detect this.
Are you expecting these images to always be valid (ie.- you're shipping
them all, as opposed to allowing them to come from some other
user-supplied source)? If so then perhaps you're seeing a bug in swt,
since an image that swt successfully reads once should always be
readable without problem.
Grant
Re: SWTException : Invalid image [message #950315 is a reply to message #949778] Fri, 19 October 2012 16:16 Go to previous messageGo to next message
Wojtek  is currently offline Wojtek
Member
hortiz Mising name wrote :
> viewer.
> second.
> Image testImage;
> image.dispose();
> sufficient.
Is the rendering process writing to the same file as you are trying to
read? Or are you creating a temporary file then renaming it to that
file?
You may be running into a concurrency problem where the rendering
process is half way through writing to the file at the same time you
are trying to read from it.
And:
could be changed to:
image = testImage;
Which will save re-reading the file.
Wojtek :-)
Re: SWTException : Invalid image [message #957461 is a reply to message #950315] Thu, 25 October 2012 04:34 Go to previous message
Member
Yes Grant I expect images to be valid, as the "offscreen generator" is always running.
I add a try/catch block and also (as Wojtek suggested) write in a first file and rename it when ready.
Previous Topic:SWT message queue clogged by browser messages
Next Topic:tree table flexibility
Current Time: Sun May 19 18:15:43 EDT 2013
Powered by FUDForum. Page generated in 0.01748 seconds
