Home » Eclipse Projects » BPMN 2.0 Modeler » Set is Default for a Gatway
Set is Default for a Gatway [message #949603] Fri, 19 October 2012 05:43 Go to next message
Tom Kohler is currently offline Tom KohlerFriend
is there a solution to set the "Is Default" to true for a sequence flow condition of a gateway? In the current version of the editor I only can select a script language and write a condition. There is no possibility to set it as default. Is this feature still missing?
Thanks Thomas
Re: Set is Default for a Gatway [message #954025 is a reply to message #949603] Mon, 22 October 2012 18:31 Go to previous messageGo to next message
Robert Brodt is currently offline Robert BrodtFriend
A sequence flow with a condition can not be the default flow; either an outgoing flow has a condition or it is the default flow.
Re: Set is Default for a Gatway [message #963112 is a reply to message #954025] Mon, 29 October 2012 15:33 Go to previous messageGo to next message
Hello Bob,
I agree with your answer. But if I activate a Gateway component and open the corresponding Gateway property view -> Section Sequence Flow List I can add a condition or I think I should activate the flag in the "is Default" column. (This was the doing for older versions). I can live with the workarround but I don't understand the column "is Default". What is the reason for this column?
Thanks Tom
Re: Set is Default for a Gatway [message #964379 is a reply to message #963112] Tue, 30 October 2012 13:23 Go to previous messageGo to next message
Ah yes...looks like an omission in the jbpm plugin - it appears to be working in the "Default" runtime plugin though.
Can you please file a bug for this issue here:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=BPMN2Modeler
Thanks!
Bob
Re: Set is Default for a Gatway [message #976068 is a reply to message #964379] Thu, 08 November 2012 09:40 Go to previous messageGo to next message
Hello Bob,
thanks for the information. I added a file to the bugzilla.
Thomas
Re: Set is Default for a Gatway [message #976069 is a reply to message #964379] Thu, 08 November 2012 09:41 Go to previous message
Hello Bob,
Thomas
Previous Topic:Use of Generics in DataTypes
Next Topic:Script task doesn't display Script Format dropdown
Current Time: Tue Apr 24 14:44:37 GMT 2018
Powered by FUDForum. Page generated in 0.01616 seconds
