Home » Eclipse Projects » BIRT » Is row[0]==row["0"]? Or should it be?
Is row[0]==row["0"]? Or should it be? [message #132105] Fri, 17 February 2006 11:13 Go to next message
Peter Fopma is currently offline Peter FopmaFriend
Member
Here is another interesting thing we found...
We have a dataset where a column is named 0 (zero). Dragging the
dataset to the reports yields a table where the above column is
addressed as row["0"]. The preview shows the expected values.
Since the data is needed for further calculation we changed the
data element and added an assignment to a global array:
theArray[rowCounter++]=row["0"];
row["0"]
I expected the preview to remain unchanged and have a copy of the
values in the array named theArray, but...
Now the column in the preview contains the values of the index column -
row[0] -
and the array is assigned with the same index values.
Changing the code to
theArray[rowCounter++]=row[2]; // WLOG: assuming the column named 0 is at
index 2
row[2]
shows the correct result. Renaming the column to "Fred1" "Berta12" or
anything that is not a number works, too.
For the sane this should not be a problem since numbering metadata is not
exactly self-explanatory. But still, I think this is not the way it is
meant
to work, or is it!?
Peter Fopma
Re: Is row[0]==row["0"]? Or should it be? [message #132326 is a reply to message #132105] Fri, 17 February 2006 16:05 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
Peter,
Naming the column 0 is probably not very descriptive either, but
this may be a bug. Can you log a bugzilla entry?
Jason
"Peter Fopma" <peter.fopma@ifb-group.com> wrote in message
news:7b5a5fcc9cc00636e4403840314948bb$1@www.eclipse.org...
> row["0"]
> row[0] -
> index 2
> row[2]
> meant
> to work, or is it!?
> Peter Fopma
Previous Topic:Problem with X axis scale
Next Topic:serious problem with cascading parameters
Current Time: Mon Jan 22 22:30:31 GMT 2018
Powered by FUDForum. Page generated in 0.01297 seconds
