Home » Language IDEs » Java Development Tools (JDT) » Tracking problems while modifying a ICompilationUnit (use none deprecated methods)
Tracking problems while modifying a ICompilationUnit (use none deprecated methods) [message #947666] Wed, 17 October 2012 09:45 Go to next message
Thomas Schindl is currently offline Thomas SchindlFriend
When trying to get informations about problems happening while modifying
a working copy of the ICompilationUnit I only managed find a way to do
this using the deprecated
ICompilationUnit#becomeWorkingCopy(IProblemRequestor, ProgressMonitor)
My current code looks something like this (please note I'm a JDT-Dummy
more or less so maybe what I do makes not really sense)
-----------8<---------------
class MyJDTEditor {
MyJDTEditor(IEditorInput input) {
IResourceFileInput fsInput = (IResourceFileInput) input;
unit = (ICompilationUnit) JavaCore.create(fsInput.getFile());
unit.becomeWorkingCopy(new IProblemRequestor() {
public void acceptProblem(IProblem problem) {
int linenumber = problem.getSourceLineNumber();
int srcStart = problem.getSourceStart();
int srcEnd = problem.getSourceEnd();
public void insert(int start, String data) {
try {
unit.getBuffer().replace(start, 0, data);
unit.reconcile(ICompilationUnit.NO_AST, true, null, null);
} catch (JavaModelException e) {}
public void set(String data) {
try {
unit.getBuffer().setContents(data);
public void save() {
unit.commitWorkingCopy(true, null);
So what is the none deprecated way to get access to the compilation
errors/warnings? Pointers to JDT-UI code to see how things are dealt are
probably even better ;-)
Tom
Re: Tracking problems while modifying a ICompilationUnit (use none deprecated methods) [message #947691 is a reply to message #947666] Wed, 17 October 2012 10:16 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
On 17.10.2012 11:45, Tom Schindl wrote:
The safest way (to shield yourself from the primary working copy model
owned/used by JDT) would be to implement your own WorkingCopyOwner and
use it in the JDT Core APIs. To create a working copy you'd call
org.eclipse.jdt.core.ITypeRoot.getWorkingCopy(WorkingCopyOwner,
IProgressMonitor).
Dani
> class MyJDTEditor {
> try {
> try {
> Thanks
> Tom
Re: Tracking problems while modifying a ICompilationUnit (use none deprecated methods) [message #948880 is a reply to message #947691] Thu, 18 October 2012 13:24 Go to previous messageGo to next message
Am 17.10.12 12:16, schrieb Daniel Megert:
> IProgressMonitor).
> Dani
That worked like a charme. Is there anything I need to do when I close
my editor to clean up the ICompilationUnit?
Tom
Re: Tracking problems while modifying a ICompilationUnit (use none deprecated methods) [message #948953 is a reply to message #948880] Thu, 18 October 2012 14:43 Go to previous message
>>> Hi,
>> IProgressMonitor).
>> Dani
See org.eclipse.jdt.core.ICompilationUnit.discardWorkingCopy()
Dani
> Tom
Previous Topic:Need Help getting Hello Program on screen
Next Topic:J2EE 4.2.1 from 4.2.0 update fail
Current Time: Mon Jan 22 11:57:22 GMT 2018
Powered by FUDForum. Page generated in 0.01774 seconds
