Home » Modeling » QVT-OML » Operational QVT Interpreter
Operational QVT Interpreter [message #946881] Tue, 16 October 2012 11:43 Go to next message
Eclipse User
when I define a debug/launch config for the Operation QVT Interpreter,
which meta model registry does it use? When I select my .qvto script, it
correctly lists input and output models, but whatever input file I
specify, it's always rejected.
Previously I loaded all relevant models into the global EMF registry and
attached a file suffix to it. How is this supposed to work with the
per-project metamodel map?
Marius
Re: Operational QVT Interpreter [message #946906 is a reply to message #946881] Tue, 16 October 2012 12:12 Go to previous messageGo to next message
As a general rule only Eclipse plugins (and standalone code emulating
Eclipse plugins) should modify the global EMF registries.
If the input file is rejected, I suspect that in some sense it is
incompatible with what you have specified. But you provide no real
details to go on.
I'm afraid that I will not be able to give you any further help without
a zipped project including a launch configuration that can just be
installed and run to demonstrate your problem.
Ed Willink
On 16/10/2012 16:43, Marius Gröger wrote:
> Hello,
> Thanks
> Marius
Re: Operational QVT Interpreter [message #947717 is a reply to message #946906] Wed, 17 October 2012 07:01 Go to previous messageGo to next message
Eclipse User
Hello Ed,
actually my question was this: how does the Operational QVT Interpreter
determine the i/o models - does it use the metamodel map of the project
hosting the qvto file?
Marius
On 16.10.2012 18:12, Ed Willink wrote:
> Hi
> details to go on.
> Regards
> Ed Willink
>> Hello,
>> Thanks
>> Marius
Re: Operational QVT Interpreter [message #947751 is a reply to message #947717] Wed, 17 October 2012 07:49 Go to previous message
I don't know. It works for me which is why I need to see an example of
what doesn;t work to be able to comment further.
Ed Willink
On 17/10/2012 12:01, Marius Gröger wrote:
> Hello Ed,
> Thanks
> Marius
>> Hi
>> details to go on.
>> Regards
>> Ed Willink
>>> Hello,
>>> Thanks
>>> Marius
Previous Topic:ant qvto:transformation and "PackageNotFoundException"
Next Topic:Generation
Current Time: Sat May 18 19:32:51 EDT 2013
Powered by FUDForum. Page generated in 0.01577 seconds
