Home » Modeling » TMF (Xtext) » Where is the recursive rule?
Where is the recursive rule? [message #945657] Mon, 15 October 2012 14:03 Go to next message
Alexey Romanov is currently offline Alexey RomanovFriend
I don't understand why I am getting this error:
error(211): ../ru.focusmedia.fire.idl/src-gen/ru/focusmedia/fire/idl/parser/antlr/internal/InternalIDL.g:592:3: [fatal] rule ruleField has non-LL(*) decision due to recursive rule invocations reachable from alts 1,2. Resolve by left-factoring or using syntactic predicates or using backtrack=true option.
with this grammar:
grammar ru.focusmedia.fire.idl.IDL with org.eclipse.xtext.xbase.Xbase
generate idl "http://www.focusmedia.ru/fire/idl/IDL"
// extended thrift with interfaces: replace services, allow references to interfaces in proxies and return types
Model:
	'package' name=QualifiedName
	imports+=Import*
	definitions+=Definition*;
Import:
	'import' importedNamespace=ImportName;
ImportName:
	QualifiedName '.*'?;
Definition:
	EnumDef | StructDef | InterfaceDef;
EnumDef:
	'enum' name=ValidID '{' enumConsts+=EnumConstDef* '}';
EnumConstDef:
	name=ValidID '=' id=INT ListSeparator?;
StructDef:
	'struct' name=ValidID '{' fields+=Field* '}';
	// absent requiredness is treated as "required"
Field:
	(id=FieldID)? (requiredness=Requiredness)? type=FieldType name=ValidID ('=' default=ConstValue) ListSeparator?;
FieldID:
	INT ':';
enum Requiredness:
	REQUIRED='required' | OPTIONAL='optional';
FieldType:
	{StructType} struct=[StructDef|QualifiedName] |
	{InterfaceType} '*' interface=[InterfaceDef|QualifiedName] |
	{BaseType} ('bool' | 'byte' | 'i16' | 'i32' | 'i64' | 'double' | 'string' | 'binary') |
	ContainerType;
ConstValue:
	literal=(XNumberLiteral | XBooleanLiteral | XStringLiteral) | ConstList | ConstMap;
ConstList:
	'[' elements+=ConstValue (ListSeparator? elements+=ConstValue)* ']';
ConstMap:
	'{' elements+=ConstMapElement (ListSeparator? elements+=ConstValue)* '}';
ConstMapElement:
	key=ConstValue ':' value=ConstValue;
ContainerType:
	{ListType} 'list' '<' elementType=FieldType '>' |
	{SetType} 'set' '<' elementType=FieldType '>' |
	{MapType} 'map' '<' keyType=FieldType ',' valueType=FieldType '>';
InterfaceDef:
	'interface' name=ValidID 'extends'
	(super+=[InterfaceDef|QualifiedName] (',' super+=[InterfaceDef|QualifiedName])*)?
	'{' methods+=MethodDecl* '}';
MethodDecl:
	(oneway?='oneway' | returnType=FieldType) name=ValidID '(' (args+=Field (','
	args+=Field)*) ')';
ListSeparator:
Field doesn't have any alternatives, and I can't see any place where I have left recursion. Am I missing something? In case it's useful, I've attached InternalIDL.g.
  • Attachment: InternalIDL.g
    (Size: 147.96KB, Downloaded 87 times)
[Updated on: Mon, 15 October 2012 14:07]
Report message to a moderator
Re: Where is the recursive rule? [message #945677 is a reply to message #945657] Mon, 15 October 2012 14:21 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
Alternative 1,2 is this part: "type=FieldType" which references
FieldType, and a FieldType refers to a ContainerType, which in turn
references FieldType.
- henrik
> Quote:
>> error(211):
> with this grammar:
> Model:
> imports+=Import*
> Import:
> ImportName:
> Definition:
> EnumDef:
> EnumConstDef:
> StructDef:
> Field:
> FieldID:
> INT ':';
> enum Requiredness:
> FieldType:
> ContainerType;
> ConstValue:
> ConstList:
> ConstMap:
> ConstMapElement:
> ContainerType:
> InterfaceDef:
> MethodDecl:
> (args+=Field (','
> args+=Field)*) ')';
> ListSeparator:
Re: Where is the recursive rule? [message #945732 is a reply to message #945677] Mon, 15 October 2012 15:33 Go to previous messageGo to next message
Thanks, I'll try to figure out how best to deal with it.
Re: Where is the recursive rule? [message #946364 is a reply to message #945732] Tue, 16 October 2012 06:37 Go to previous message
The problem turned out actually to lie in ListSeparators. Replacing "ListSeparator?" with "ListSeparator" or "(=>ListSeparator?)" fixes it.
Previous Topic:Combining JvmModelInferrer with IGenerator
Next Topic:[xbase] narrow cross references for java based JvmTypes
Current Time: Sun May 27 09:38:11 GMT 2018
Powered by FUDForum. Page generated in 0.02971 seconds
