Home » Modeling » EMF » How to populate a Map of List ?
How to populate a Map of List ? [message #941546] Fri, 12 October 2012 16:26 Go to next message
David Michonneau is currently offline David MichonneauFriend
Member
I have modeled a map of <String,List> in my ecore based on the wiki (http://wiki.eclipse.org/EMF/FAQ#How_do_I_create_a_Map_in_EMF.3F), it has generated the code correctly, but now I don't see how to populate it.
Indeed the map values are EList, and I didn't find any corresponding feature for it. How to create it?
I get this method in the map impl class:
public EMap<String, EList<MyClass>> getEMap()
Now when I want to put something in it, I will do:
a.put("key", value);
the question is: how do I create an empty EList<MyClass> for value?
David
Re: How to populate a Map of List ? [message #941559 is a reply to message #941546] Fri, 12 October 2012 16:39 Go to previous messageGo to next message
David,
Comments below.
ECollections.emptyList(); a put will copy that into the value feature of
the map entry, essentially creating a map entry with an empty value
list. Or create a new BasicEList, populated it with MyClass instances
and use put("key", list), which will copy the list into the value
feature of the map entry.
> David
Re: How to populate a Map of List ? [message #942510 is a reply to message #941559] Sat, 13 October 2012 15:47 Go to previous message
Member
Cool, I didn't know of this API. I used a much more complex way:
BasicEMap.Entry<String,EList<MyClass>> entry = (BasicEMap.Entry<String,EList<MyClass>)EcoreUtil.create(MyPackage.Literals.MY_MAP );
entry.setKey("key");
value = entry.getValue(); // list auto-created by emf
map.add(entry);
but your solution is far simpler!
David
Previous Topic:Defining which derived class a feature from an abstract class shall use
Next Topic:hashcode and Map (non mutable case)
Current Time: Wed Jan 17 23:44:08 GMT 2018
Powered by FUDForum. Page generated in 0.01918 seconds
