Re: Can't get BPMN Modeler to work [message #11899 is a reply to message #11871] |
Thu, 07 May 2009 05:12 |
Originally posted by: atoulme.intalio.com
Kerry wrote:
> I have installed the BPMN Modeler on my Linux box but it does not seem
> to work very well. It will create a default document but when you try to
> make any kind of connection between two shapes the connection will
> appear in the upper left corner of the pool instead of connecting the
> two shapes and the modeller then fails accept any more changes. If you
> save the changes, when you open the document afterwards you get;
> Could not open the editor: Corrupted model
> org.eclipse.stp.bpmn.impl.ActivityImpl@604cd176 (iD:
> _11Tc8DoZEd6bVPeztXi7sQ) (documentation: null, name: null, ncname: null,
> orderedMessages: [], activityType: GatewayDataBasedExclusive, looping:
> <unset>)
> This is the same message you get when trying to load the samples.
> I have even tried a completely fresh install of Eclipse but I get the
> same problem. Any help would be appreciated.
Kerry, look up this thread:
news://news.eclipse.org:119/15b7869ef49cd0ddcd602ae63981af90 $1@www.eclipse.org
and the associated bug with its resolution:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=266959
Antoine
FUDForum. Page generated in 0.03574 seconds
