Home » Eclipse Projects » Plugin Development Environment (PDE) » Eclipse tries to load old resources
Eclipse tries to load old resources [message #938814] Wed, 10 October 2012 07:16
Alexander Pann is currently offline Alexander PannFriend
when I create a new plugin project and launch it as an Eclipse application Eclipse trys to load resources from previous plugin projects. I have already set up a new workspace and use a fresh version of the Eclipse SDK.
As a result most of the samples doesn't work. Yesterday everything worked as expected. I am currently using eclipse-SDK-4.2-win32-x86_64 and also tried 4.3.
Thanks in advance.
!SESSION 2012-10-10 09:00:04.130 -----------------------------------------------
eclipse.buildId=I20120608-1400
java.version=1.6.0_35
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_AT
Framework arguments: -product org.eclipse.sdk.ide
Command-line arguments: -product org.eclipse.sdk.ide -data F:\realtimeFX/../runtime-EclipseApplication -dev file:F:/realtimeFX/.metadata/.plugins/org.eclipse.pde.core/Eclipse Application/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.ui 4 4 2012-10-10 09:00:09.602
!MESSAGE Unable to find Action Set: tes.actionSet
!ENTRY org.eclipse.ui 4 4 2012-10-10 09:00:09.611
!MESSAGE Unable to find Action Set: lala.actionSet
!ENTRY org.eclipse.jface 4 0 2012-10-10 09:00:10.589
!MESSAGE Unable to resolve plug-in "platform:/plugin/RealtimeFX/icons/sample.gif".
!STACK 0
java.io.IOException: Unable to resolve plug-in "platform:/plugin/RealtimeFX/icons/sample.gif".
at org.eclipse.core.internal.runtime.PlatformURLPluginConnection.parse(PlatformURLPluginConnection.java:64)
at org.eclipse.core.internal.runtime.PlatformURLPluginConnection.resolve(PlatformURLPluginConnection.java:75)
at org.eclipse.core.internal.boot.PlatformURLHandler.openConnection(PlatformURLHandler.java:67)
at org.eclipse.osgi.framework.internal.protocol.URLStreamHandlerProxy.openConnection(URLStreamHandlerProxy.java:112)
at java.net.URL.openConnection(Unknown Source)
at org.eclipse.core.internal.runtime.PlatformURLConverter.toFileURL(PlatformURLConverter.java:33)
at org.eclipse.core.runtime.FileLocator.toFileURL(FileLocator.java:206)
at org.eclipse.jface.resource.URLImageDescriptor.getFilePath(URLImageDescriptor.java:137)
at org.eclipse.jface.resource.URLImageDescriptor.createImage(URLImageDescriptor.java:157)
at org.eclipse.jface.resource.ImageDescriptor.createImage(ImageDescriptor.java:227)
at org.eclipse.jface.resource.ImageDescriptor.createImage(ImageDescriptor.java:205)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.getImage(SWTPartRenderer.java:178)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.createTab(StackRenderer.java:731)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.processContents(LazyStackRenderer.java:134)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:635)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:725)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:696)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:690)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:675)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:59)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:98)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:639)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:626)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:961)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Previous Topic:Addding plugin to Marketplace
Next Topic:java.lang.IllegalArgumentException when creating a file
Current Time: Sun May 20 23:41:32 GMT 2018
Powered by FUDForum. Page generated in 0.02088 seconds
