Home » Eclipse Projects » GEF » Filters in GEF
Filters in GEF [message #129247] Wed, 28 April 2004 01:24 Go to next message
Originally posted by: vgusev.graphlogic.com
What would be a roadmap to implement filters in GEF editors. For example, I
would like to use the filter dialog similar to that in the Tasks view to
filter out the nodes, children, links etcetera at will. So more precisely,
how one can hook into this kind of Filter from GEF? Thanks.
Vladimir
Re: Filters in GEF [message #129502 is a reply to message #129247] Wed, 28 April 2004 23:34 Go to previous messageGo to next message
Pratik Shah is currently offline Pratik ShahFriend
I am not sure what exactly you are looking for. GEF currently doesn't
support a filter mechanism. But it shouldn't be too difficult to achieve
what you want to do. You can just put a filter action on your context menu,
system menu, and/or toolbar, and then take different actions depending on
what kind of filtering is requested. For instance, if connections are to be
filtered, you could invoke setVisible(false) for the connection layer. Or
if all nodes of a certain type (say labels in the logic example) were to be
filtered, you could just refresh your editparts (assuming your
getModelChildren() method would know that it needs to filter the labels
based on some property).
"Bob" <vgusev@graphlogic.com> wrote in message
news:c6n0pd$k3e$1@eclipse.org...
> Hello,
I
> Vladimir
Re: Filters in GEF [message #129627 is a reply to message #129502] Thu, 29 April 2004 02:36 Go to previous messageGo to next message
The Figure class has isVisible method:
public boolean isVisible() {
return getFlag(FLAG_VISIBLE);
FLAG_VISIBLE rings a bell as something related to filters. Hence the
question. I thought there was a standard way to set the flags in Figure from
the Filter dialog. Yes?
Vladimir
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:c6pb6a$cf9$1@eclipse.org...
menu,
be
be
> > Hello,
example,
> I
precisely,
> > Vladimir
Re: Filters in GEF [message #129772 is a reply to message #129627] Thu, 29 April 2004 15:52 Go to previous messageGo to next message
figure visibility is not currently tied into whether an editpart is
selected. So your editparts would have to be careful to deselect themselves
if their filter state/figure visibility changed.
"Vladimir" <vgusev@graphlogic.com> wrote in message
news:c6ppbe$npj$1@eclipse.org...
from
> Vladimir
achieve
> menu,
on
to
> be
Or
> be
> > > Hello,
> example,
> > I
to
> precisely,
> > > Vladimir
Re: Filters in GEF [message #129784 is a reply to message #129247] Thu, 29 April 2004 15:53 Go to previous message
Besides figure visibility, you can also modify the way
getModelChildren/getModelSourceConnections works in your editpart
implementations. Then, all you need to do, is call refreshXxxx() when the
filter state changes. It's a simple matter of notification at that point.
> Hello,
I
> Vladimir
Previous Topic:Logic Gates Example
Next Topic:connection drawing problem
Current Time: Fri Feb 23 08:59:54 GMT 2018
Powered by FUDForum. Page generated in 0.01592 seconds
