Home » Archived » Test and Performance Tools Platform (TPTP) » An unexpected error has been detected by Java Runtime Environment
An unexpected error has been detected by Java Runtime Environment [message #129242] Mon, 28 April 2008 10:00 Go to next message
Originally posted by: biscio81.tiscali.it
When i launch two or more file probe that monitors the same class, tptp
ProbeKit return this error.
Wthat is the problem?
# An unexpected error has been detected by Java Runtime Environment:
# Internal Error (455843455054494F4E530E4350500129), pid=5360, tid=5368
# Java VM: Java HotSpot(TM) Client VM (1.6.0_03-b05 mixed mode)
# An error report file with more information is saved as hs_err_pid5360.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
Re: An unexpected error has been detected by Java Runtime Environment [message #129519 is a reply to message #129242] Tue, 29 April 2008 08:02 Go to previous messageGo to next message
Asaf Yaffe is currently offline Asaf YaffeFriend
Marco wrote:
Can you attached the generated log file (he_err_*.log)?
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: An unexpected error has been detected by Java Runtime Environment [message #129621 is a reply to message #129519] Tue, 29 April 2008 09:31 Go to previous messageGo to next message
Here is the file.
bye
"Asaf Yaffe" <asaf.yaffe@intel.com> ha scritto nel messaggio
news:fv6km2$aor$3@build.eclipse.org...
> Marco wrote:
>> hs_err_pid5360.log
> Asaf
> Asaf Yaffe
Re: An unexpected error has been detected by Java Runtime Environment [message #130164 is a reply to message #129621] Thu, 15 May 2008 12:49 Go to previous message
Marco,
Can you please open a Bug report for this issue at
http://bugs.eclipse.org/bugs (TPTP Project, TPTP Probe Instrumentation,
Platform.Execution.ProbekitBCI)?
Please include the following information:
- Eclipse and TPTP versions
- OS version and architecture
- Java version (use java -version)
- A small reproducer for this problem (class and probes).
Asaf
Asaf Yaffe
Previous Topic:Txt file instead of .TRCXML
Next Topic:How to use TPTP with weblogic?!?
Current Time: Thu Jan 18 20:14:03 GMT 2018
Powered by FUDForum. Page generated in 0.02089 seconds
