Home » Eclipse Projects » EGit » Indicator that upstream branch has updated?
Indicator that upstream branch has updated? [message #937097] Mon, 08 October 2012 12:58 Go to next message
D Z is currently offline D Z
I've tried searching, but I can't find an answer to this question:
Does EGit indicate which projects' repos have upstream updates to the branch you currently have checked out? In other words, if my local git repo is a clone from GitHub (and so I have tracking branches), will I get an indicator that tells me visually that GitHub has been updated and that I need to fetch if I want to be in sync?
Sorry for being clueless -- All I really want is easy in-eclipse notifications, and I'm wondering if EGit can help me or not. Thanks for any reply.
-- DZ
Re: Indicator that upstream branch has updated? [message #937229 is a reply to message #937097] Mon, 08 October 2012 16:09 Go to previous messageGo to next message
R Shapiro is currently offline R Shapiro
EGit provides a visual decoration if the active branch is behind and/or ahead of the branch or reference it's tracking (it can of course be both behind and ahead simultaneously). The decoration is an up-arrow+count for the number of commits ahead, and down-arrow+count for the number of commits behind. This works for all tracking branches, whether what's being tracked is a remote-reference or a local branch (the status decoration for local branch tracking is relatively new).
In that way it behaves like "git status" on the command-line. But also like "git status", when tracking a remote-reference it relies on the local state of that reference. To ensure that the remote-reference is current with the remote repository you must do a fetch. As far as I know that's true both in Git and EGit. Keep in mind that fetch does not do anything with your working tree or index. All it does is copy commits and update remote-references.
So the short answer to your question is: do a fetch and EGit will update the decorations accordingly.
If you're looking for the Git equivalent of 'hg in' in Mercurial or 'svn status -u' in Subversion, I don't think it exists in Git (or EGit). It isn't necessary, given Git's remote-reference concept, which neither SVN nor Mercurial has.
Re: Indicator that upstream branch has updated? [message #937949 is a reply to message #937229] Tue, 09 October 2012 08:03 Go to previous message
Matthias Sohn is currently offline Matthias Sohn
The other prerequisite of this decoration is that the currently checked out branch needs to track another branch [1]. This tracking relationship is established automatically if you select a branch and click "Create Branch...", the dialog which comes up allows to choose the branch to track in case there are multiple branches pointing to the same commit and to configure the merge strategy.
[1] http://git-scm.com/book/ch3-5.html#Tracking-Branches
Previous Topic:EGit could not detect where Git is installed
Next Topic:EGit https clone
Current Time: Wed Jun 19 14:04:31 EDT 2013
Powered by FUDForum. Page generated in 0.03558 seconds
