Home » Language IDEs » Java Development Tools (JDT) » Defaults for Run As Java Application?
Defaults for Run As Java Application? [message #128919] Sat, 20 December 2003 14:21 Go to next message
Andrea Aime is currently offline Andrea AimeFriend
Member
Is there any way to set default jvm arguments for running a class as a
Java Application? I'd like to set -Xverify:none for every execution
since this decreases a bit startup time but can't find a way
to do it... with Netbeans it was quite easy, just modify the
command line of the default runner...
Also, is there a way to setup a shortcut for "Run" - "Run as" - "Java
Application"? In Netbeans it was as easy as pressing F6 on each file
that happened to have a main()...
Re: Defaults for Run As Java Application? [message #129120 is a reply to message #128919] Mon, 22 December 2003 15:33 Go to previous message
Darin Wright is currently offline Darin WrightFriend
Both of your requests exist as feature requests:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=37862
https://bugs.eclipse.org/bugs/show_bug.cgi?id=29581
Darin
"Andrea Aime" <andrea.aime@aliceposta.it> wrote in message
news:pan.2003.12.20.14.21.21.32105@aliceposta.it...
Previous Topic:Using JDT code formatting from an ant script
Next Topic:create an instance from IType
Current Time: Tue Jan 23 14:03:31 GMT 2018
Powered by FUDForum. Page generated in 0.01514 seconds
