Home » Modeling » Papyrus » Why I cannot create a papyrus project
Why I cannot create a papyrus project [message #933144] Thu, 04 October 2012 19:34 Go to next message
wws_ques wws_ques is currently offline wws_ques wws_quesFriend
Member
After installing the papyrus 0.8.2 using Help -> Install New Software, I cannot create a papyrus project. See the attachment. What is wrong with my installation? Thanks.
Re: Why I cannot create a papyrus project [message #933709 is a reply to message #933144] Fri, 05 October 2012 09:09 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
There seems to be a problem with your installation, but I lack information.
Is there any error in your error log view?
Camille
Camille Letavernier
Re: Why I cannot create a papyrus project [message #934203 is a reply to message #933709] Fri, 05 October 2012 18:58 Go to previous messageGo to next message
Member
I just run eclipse -clean and I got the following info related to papyrus in my installation details window. Is there anything wrong there? Initially I copied all the file to another location. I used the PAPYRUS.LINK file to point to the location I have papyrus files but it didn't work. Then I used install new software to install papyrus but I get the current problem. Thanks.
org.eclipse.papyrus.collaborationuse.editor.xtext (0.8.1.v201109161105) "Papyrus CollaborationUse xtext direct editor (Incubation)" [Starting]
org.eclipse.papyrus.collaborationuse.editor.xtext.ui (0.8.1.v201109161105) "Papyrus CollaborationUse xtext ui direct editor (Incubation)" [Installed]
org.eclipse.papyrus.common.editor.xtext (0.8.1.v201109161105) "Papyrus common xtext direct editor (Incubation)" [Starting]
org.eclipse.papyrus.common.editor.xtext.ui (0.8.1.v201109161105) "Papyrus Parameter common ui direct editor (Incubation)" [Starting]
org.eclipse.papyrus.connectionpointreference.editor.xtext (0.8.1.v201109161105) "pluginName" [Starting]
org.eclipse.papyrus.connectionpointreference.editor.xtext.ui (0.8.1.v201109161105) "pluginName" [Starting]
org.eclipse.papyrus.constraintwithessentialocl.editor.xtext (0.8.1.v201109161105) "pluginName" [Starting]
org.eclipse.papyrus.controlmode (0.8.1.v201109161105) "pluginName" [Starting]
org.eclipse.papyrus.controlmode.history (0.8.1.v201109161105) "Papyrus Control Mode Trace (Incubation)" [Starting]
org.eclipse.papyrus.controlmode.umlprofiles (0.8.1.v201109161105) "pluginName" [Starting]
org.eclipse.papyrus.core (0.8.1.v201109161105) "Papyrus Backbone (Incubation)" [Active]
org.eclipse.papyrus.core.adaptor.gmf (0.8.1.v201109161105) "UML Papyrus GMF Editor (Incubation)" [Starting]
org.eclipse.papyrus.core.queries (0.8.1.v201109161105) "Papyrus Core Queries Plugin (Incubation)" [Starting]
org.eclipse.papyrus.core.queries.configuration (0.8.1.v201109161105) "Configuration Model for queries (Incubation)" [Starting]
org.eclipse.papyrus.core.queries.configuration.edit (0.8.1.v201109161105) "Configuration Edit Support (Incubation)" [Starting]
org.eclipse.papyrus.core.resourceloading (0.8.1.v201109161105) "Papyrus Resource Loading (Incubation)" [Active]
org.eclipse.papyrus.core.resourceloading.preferences (0.8.1.v201109161105) "Preferences for resource loading feature (Incubation)" [Starting]
org.eclipse.papyrus.diagram.activity (0.8.1.v201109161105) "Papyrus Activity Diagram (Incubation)" [Installed]
org.eclipse.papyrus.diagram.clazz (0.8.1.v201109161105) "Papyrus Class Diagram (Incubation)" [Installed]
org.eclipse.papyrus.diagram.common (0.8.1.v201109161105) "Papyrus Common Diagram (Incubation)" [Installed]
org.eclipse.papyrus.diagram.common.groups (0.8.1.v201109161105) "Papyrus Common groups plugin (Incubation)" [Installed]
org.eclipse.papyrus.diagram.common.palette.customization (0.8.1.v201109161105) "fragmentName" [Installed]
org.eclipse.papyrus.diagram.communication (0.8.1.v201109161105) "Papyrus Communication Diagram (Incubation)" [Installed]
org.eclipse.papyrus.diagram.component (0.9.0.v201109161105) "Papyrus Component Diagram (Incubation)" [Installed]
org.eclipse.papyrus.diagram.composite (0.8.1.v201109161105) "Papyrus Composite Structure Diagram (Incubation)" [Installed]
org.eclipse.papyrus.diagram.deployment (0.9.0.v201109161105) "Papyrus Component Diagram (Incubation)" [Installed]
org.eclipse.papyrus.diagram.icons.uml (0.8.1.v201109161105) "Papyrus plugin for its UML diagram editor icons (Incubation)" [Starting]
org.eclipse.papyrus.diagram.menu (0.8.1.v201109161105) "Papyrus Menu Diagram (Incubation)" [Installed]
org.eclipse.papyrus.diagram.profile (0.8.1.v201109161105) "Papyrus UML Profile Diagram (Incubation)" [Installed]
org.eclipse.papyrus.diagram.sequence (0.8.1.v201109161105) "Papyrus Sequence Diagram (Incubation)" [Installed]
org.eclipse.papyrus.diagram.statemachine (0.8.1.v201109161105) "Papyrus State Machine Diagram (Incubation)" [Installed]
org.eclipse.papyrus.diagram.usecase (0.8.1.v201109161105) "Papyrus UseCase Diagram (Incubation)" [Installed]
org.eclipse.papyrus.doc (0.8.1.v201109161105) "Papyrus Main Documentation plugin (Incubation)" [Resolved]
org.eclipse.papyrus.documentation (0.8.1.v201109161105) "Papyrus documentation manager (Incubation)" [Starting]
org.eclipse.papyrus.documentation.uml (0.8.1.v201109161105) "UML implementation of Papyrus Documentation (Incubation)" [Starting]
org.eclipse.papyrus.documentation.view (0.8.1.v201109161105) "View for documentation support (Incubation)" [Starting]
org.eclipse.papyrus.documentation.view.papyrus (0.8.1.v201109161105) "Papyrus integration of the documentation view (Incubation)" [Resolved]
org.eclipse.papyrus.editor (0.8.1.v201109161105) "Papyrus Core Editor Plugin (Incubation)" [Starting]
org.eclipse.papyrus.export (0.8.1.v201109161105) "pluginName" [Installed]
org.eclipse.papyrus.extendedtypes (0.8.1.v201109161105) "Papyrus enhanced types metamodel plugin (Incubation)" [Starting]
org.eclipse.papyrus.extendedtypes.emf (0.8.1.v201109161105) "ModifySemanticValuesActionConfiguration Model" [Starting]
org.eclipse.papyrus.extendedtypes.uml (0.8.1.v201109161105) "UML configurations for Extended Types framework (Incubation)" [Starting]
org.eclipse.papyrus.extensionpoints.editors (0.8.1.v201109161105) "Papyrus Embedded Editors extensions point (Incubation)" [Starting]
org.eclipse.papyrus.extensionpoints.uml2 (0.8.1.v201109161105) "Papyrus UML extensions - library and profile (Incubation)" [Starting]
org.eclipse.papyrus.icons.uml (0.8.1.v201109161105) "Papyrus UML Model Elements Icons Plugin (Incubation)" [Starting]
org.eclipse.papyrus.layouttool (0.8.0.v201109161105) "Papyrus Layout tools (Incubation)" [Active]
org.eclipse.papyrus.layouttool.algorithms.gridAlgorithm (0.8.0.v201109161105) "Papyrus Grid Algorithm Plug-in (Incubation)" [Starting]
org.eclipse.papyrus.layouttool.algorithms.horizontalAlgorithm (0.8.0.v201109161105) "Papyrus Horizontal Algorithm Plug-in (Incubation)" [Starting]
org.eclipse.papyrus.layouttool.algorithms.horizontalSymmetryAlgorithm (0.8.0.v201109161105) "Papyrus Horizontal Symmetry Algorithm Plug-in (Incubation)" [Starting]
org.eclipse.papyrus.layouttool.algorithms.horizontalTreeAlgorithm (0.8.0.v201109161105) "Papyrus Horizontal Tree Algorithm Plug-in (Incubation)" [Starting]
org.eclipse.papyrus.layouttool.algorithms.radialAlgorithm (0.8.0.v201109161105) "Papyrus Radial Algorithm Plug-in (Incubation)" [Starting]
org.eclipse.papyrus.layouttool.algorithms.springAlgorithm (0.8.0.v201109161105) "Papyrus Spring Algorithm Plug-in (Incubation)" [Starting]
org.eclipse.papyrus.layouttool.algorithms.treeAlgorithm (0.8.0.v201109161105) "Papyrus Tree Algorithm Plug-in (Incubation)" [Starting]
org.eclipse.papyrus.layouttool.algorithms.verticalAlgorithm (0.8.0.v201109161105) "Papyrus Vertical Algorithm Plug-in (Incubation)" [Starting]
org.eclipse.papyrus.layouttool.algorithms.verticalSymmetryAlgorithm (0.8.0.v201109161105) "Papyrus VerticalSymmetryAlgorithm Plug-in (Incubation)" [Starting]
org.eclipse.papyrus.layouttool.subeditor.gmf (0.8.0.v201109161105) "Papyrus Layout tools sub editor for GMF pluguin (Incubation)" [Active]
org.eclipse.papyrus.log (0.8.1.v201109161105) "Papyrus Logging plugin(Incubation)" [Active]
org.eclipse.papyrus.message.editor.xtext (0.8.1.v201109161105) "Papyrus Message xtext direct editor (Incubation)" [Starting]
org.eclipse.papyrus.message.editor.xtext.ui (0.8.1.v201109161105) "Papyrus Property xtext ui direct editor (Incubation)" [Starting]
org.eclipse.papyrus.modelexplorer (0.8.1.v201109161105) "Papyrus Model Explorer (Incubation)" [Active]
org.eclipse.papyrus.modelexplorer.resourceloading (0.8.1.v201109161105) "Papyrus Resource Loading for Model Explorer (Incubation)" [Starting]
org.eclipse.papyrus.modelexplorer.widgets (0.8.1.v201109161105) "pluginName" [Starting]
org.eclipse.papyrus.navigation (0.8.1.v201109161105) "Papyrus navigation (Incubation)" [Starting]
org.eclipse.papyrus.navigation.uml (0.8.1.v201109161105) "Papyrus UML navigation (Incubation)" [Resolved]
org.eclipse.papyrus.onefile (0.8.1.v201109161105) "pluginName" [Starting]
org.eclipse.papyrus.outline (0.8.1.v201109161105) "Papyrus Outline (Incubation)" [Installed]
org.eclipse.papyrus.outline.emftree (0.8.1.v201109161105) "Papyrus Outline (Incubation)" [Starting]
org.eclipse.papyrus.paletteconfiguration (0.8.1.v201109161105) "Papyrus palette metamodel plugin (Incubation)" [Installed]
org.eclipse.papyrus.paletteconfiguration.customization (0.8.1.v201109161105) "Customization" [Installed]
org.eclipse.papyrus.paletteconfiguration.edit (0.8.1.v201109161105) "Papryus PaletteConfiguration Edit Support (Incubation)" [Installed]
org.eclipse.papyrus.parameter.editor.xtext (0.8.1.v201109161105) "Papyrus Parameter xtext direct editor (Incubation)" [Starting]
org.eclipse.papyrus.parameter.editor.xtext.ui (0.8.1.v201109161105) "Papyrus Parameter xtext ui direct editor (Incubation)" [Starting]
org.eclipse.papyrus.parsers (0.8.1.v201109161105) "Papyrus UML Parsers (Incubation)" [Starting]
org.eclipse.papyrus.pastemanager (0.8.1.v201109161105) "Papyrus Paste Management(Incubation)" [Starting]
org.eclipse.papyrus.perspective (0.8.1.v201109161105) "Papyrus Perspective (Incubation)" [Starting]
org.eclipse.papyrus.preferences (0.8.1.v201109161105) "Papyrus Preferences (Incubation)" [Starting]
org.eclipse.papyrus.profile (0.8.1.v201109161105) "Papyrus Profile Diagram (Incubation)" [Installed]
org.eclipse.papyrus.properties (0.8.1.v201109161105) "Papyrus properties runtime (Incubation)" [Starting]
org.eclipse.papyrus.properties.model (0.8.1.v201109161105) "Papyrus properties model (Incubation)" [Starting]
org.eclipse.papyrus.properties.model.edit (0.8.1.v201109161105) "Properties Edit Support (Incubation)" [Starting]
org.eclipse.papyrus.properties.model.editor (0.8.1.v201109161105) "Properties Editor (Incubation)" [Starting]
org.eclipse.papyrus.properties.notation (0.8.1.v201109161105) "Notation" [Installed]
org.eclipse.papyrus.properties.runtime (0.8.1.v201109161105) "Papyrus Properties Editor Runtime (Incubation)" [Starting]
org.eclipse.papyrus.properties.runtime.uml (0.8.1.v201109161105) "Papyrus Properties Editor Runtime for UML (Incubation)" [Starting]
org.eclipse.papyrus.properties.sysml (0.8.1.v201109161105) "Papyrus properties SysML (Incubation)" [Installed]
org.eclipse.papyrus.properties.tabbed.core (0.8.1.v201109161105) "Papyrus Tabbed Properties Core (Incubation)" [Starting]
org.eclipse.papyrus.properties.tabbed.customization (0.8.1.v201109161105) "Papyrus Tabbed Properties Customization Tool (Incubation)" [Installed]
org.eclipse.papyrus.properties.tabbed.profile (0.8.1.v201109161105) "Profile tabbed properties(Incubation)" [Installed]
org.eclipse.papyrus.properties.table (0.8.1.v201109161105) "Papyrus Table Property View" [Starting]
org.eclipse.papyrus.properties.uml (0.8.1.v201109161105) "Bundle-Name" [Installed]
org.eclipse.papyrus.properties.view.sysml (0.8.1.v201109161105) "pluginName" [Starting]
org.eclipse.papyrus.properties.view.uml (0.8.1.v201109161105) "Papyrus Properties Editor UML views(Incubation)" [Starting]
org.eclipse.papyrus.property.editor.xtext (0.8.1.v201109161105) "Papyrus Property xtext direct editor (Incubation)" [Starting]
org.eclipse.papyrus.property.editor.xtext.ui (0.8.1.v201109161105) "Papyrus Property xtext ui direct editor (Incubation)" [Starting]
org.eclipse.papyrus.resource (0.8.1.v201109161105) "Papyrus Resource Model (Incubation)" [Starting]
org.eclipse.papyrus.resource.edit (0.8.1.v201109161105) "Papyrus Resource Edit Support (Incubation)" [Starting]
org.eclipse.papyrus.resource.migration (0.8.1.v201109161105) "Papyrus Resource Migration (Incubation)" [Starting]
org.eclipse.papyrus.resourceloading.umlprofile (0.8.1.v201109161105) "pluginName" [Resolved]
org.eclipse.papyrus.sasheditor (0.8.1.v201109161105) "Papyrus SashEditor (Incubation)" [Starting]
org.eclipse.papyrus.sasheditor.di (0.8.1.v201109161105) "Papyrus Sashwindows di Model (Incubation)" [Starting]
org.eclipse.papyrus.service.edit (0.8.1.v201109161105) "Papyrus Edit Service (Incubation)" [Starting]
org.eclipse.papyrus.state.editor.xtext (0.8.1.v201109161105) "Papyrus State xtext direct editor (Incubation)" [Starting]
org.eclipse.papyrus.state.editor.xtext.ui (0.8.1.v201109161105) "Papyrus State xtext ui direct editor (Incubation)" [Starting]
org.eclipse.papyrus.sysml (0.8.1.v201109161105) "UML profile for SysML (from OMG SysML V1.1 formal/2008-11-02) (Incubation)" [Starting]
org.eclipse.papyrus.sysml.diagram.blockdefinition (0.8.1.v201109161105) "pluginName" [Installed]
org.eclipse.papyrus.sysml.diagram.common (0.8.1.v201109161105) "UML Common diagram for SysML (Incubation)" [Installed]
org.eclipse.papyrus.sysml.diagram.internalblock (0.8.1.v201109161105) "SysML Internal Block Diagram" [Installed]
org.eclipse.papyrus.sysml.diagram.parametric (0.8.1.v201109161105) "Papyrus Paramatric Diagram for SysML (Incubation)" [Installed]
org.eclipse.papyrus.sysml.diagram.requirement (0.8.1.v201109161105) "Papyrus SysML Requirement Diagram for SysML (Incubation)" [Installed]
org.eclipse.papyrus.sysml.diagram.ui (0.8.1.v201109161105) "UI Plugin for papyrus SysML diagrams (Incubation)" [Installed]
org.eclipse.papyrus.sysml.edit (0.8.1.v201109161105) "Edit support for SysML (from OMG SysML V1.1 formal/2008-11-02) (Incubation)" [Starting]
org.eclipse.papyrus.sysml.facets (0.8.1.v201109161105) "EMF Facets for Papyrus SysML" [Installed]
org.eclipse.papyrus.sysml.modelexplorer (0.8.1.v201109161105) "ModelExplorer customization for SysML (Incubation)" [Installed]
org.eclipse.papyrus.sysml.service.types (0.8.1.v201109161105) "Papyrus SysML ElementType Service (Incubation)" [Installed]
org.eclipse.papyrus.sysml.table.allocation (0.8.1.v201109161105) "Papyrus Table Editor For Allocation" [Installed]
org.eclipse.papyrus.sysml.table.requirement (0.8.1.v201109161105) "Papyrus Table Editor For Requirements" [Installed]
org.eclipse.papyrus.tabbedproperties.appearance (0.8.1.v201109161105) "Papyrus Appearance TabbedProperties Plug in (Incubation)" [Installed]
org.eclipse.papyrus.tabbedproperties.core (0.8.1.v201109161105) "Papyrus Core Tabbed Properties (Incubation)" [Starting]
org.eclipse.papyrus.table.common (0.8.1.v201109161105) "Common Plugin for Papyrus Table Editor" [Installed]
org.eclipse.papyrus.table.default (0.8.1.v201109161105) "pluginName" [Installed]
org.eclipse.papyrus.table.instance (0.8.1.v201109161105) "Papyrus Nattable Instance" [Starting]
org.eclipse.papyrus.table.menu (0.8.1.v201109161105) "Papyrus Table Menu" [Installed]
org.eclipse.papyrus.table.modelexplorer (0.8.1.v201109161105) "Table Customization For Model Explorer" [Active]
org.eclipse.papyrus.table.widgets.celleditors.uml (0.8.1.v201109161105) "Cell Editors for Papyrus Tables" [Installed]
org.eclipse.papyrus.templaterepository (0.8.1.v201109161105) "TemplateRepository (Incubation)" [Starting]
org.eclipse.papyrus.transition.editor.xtext (0.8.1.v201109161105) "Papyrus Transition xtext direct editor (Incubation)" [Starting]
org.eclipse.papyrus.transition.editor.xtext.ui (0.8.1.v201109161105) "Papyrus Transition xtext ui direct editor (Incubation)" [Starting]
org.eclipse.papyrus.ui.perspectiveconfiguration (0.8.1.v201109161105) "UI perpective configuration(Incubation)" [Active]
org.eclipse.papyrus.ui.resources (0.8.1.v201109161105) "pluginName" [Starting]
org.eclipse.papyrus.ui.toolbox (0.8.1.v201109161105) "Papyrus UI Toolbox (Incubation)" [Starting]
org.eclipse.papyrus.uml.diagram.pkg (0.8.1.v201109161105) "pluginName" [Installed]
org.eclipse.papyrus.uml.menu (0.8.1.v201109161105) "pluginName" [Active]
org.eclipse.papyrus.uml.modelexplorer (0.8.1.v201109161105) "pluginName" [Installed]
org.eclipse.papyrus.uml.modelexplorer.widgets (0.8.1.v201109161105) "pluginName" [Starting]
org.eclipse.papyrus.uml.profile (0.8.1.v201109161105) "Papyrus profile for UML modelisation support plugin (Incubation)" [Resolved]
org.eclipse.papyrus.uml.service.types (0.8.1.v201109161105) "Papyrus UML ElementType Service (Incubation)" [Installed]
org.eclipse.papyrus.uml.standard (0.8.1.v201109161105) "UML Standard profile (static version of the profile) (Incubation)" [Starting]
org.eclipse.papyrus.uml.standard.edit (0.8.1.v201109161105) "Edit Support for UML2 Standard profile (Incubation)" [Starting]
org.eclipse.papyrus.uml.ui.perspectiveconfiguration (0.8.1.v201109161105) "Papyrus Perspective configuration for UML (Incubation)" [Starting]
org.eclipse.papyrus.umlutils (0.8.1.v201109161105) "Papyrus UML Utils (Incubation)" [Starting]
org.eclipse.papyrus.validation (0.8.1.v201109161105) "pluginName" [Starting]
org.eclipse.papyrus.widgets (0.8.1.v201109161105) "Papyrus widgets (Incubation)" [Starting]
org.eclipse.papyrus.widgets.gmf (0.8.1.v201109161105) "GMF Widgets" [Starting]
org.eclipse.papyrus.wizards (0.8.1.v201109161105) "Papyrus Wizards (Incubation)" [Starting]
Re: Why I cannot create a papyrus project [message #937236 is a reply to message #934203] Mon, 08 October 2012 20:20 Go to previous messageGo to next message
Member
Can someone give me a hint? Or, how to totally remove the previous installation and install a new one. Thanks.
Re: Why I cannot create a papyrus project [message #937276 is a reply to message #934203] Mon, 08 October 2012 21:08 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
This sounds like a really bad thing to do. P2 maintains tight control
and you may have undermined it; but you didn't say what files or where.
Your plugin versions suggest a very unhappy mix of 0.8 and 0.9.
You might try uninstalling or reverting via Help->About
Eclipse->Installation Details. Then you might try deleting all papyrus
files in plugins and features; but I suspect your installation is
probably so messed up you should start from scratch. Only use P2 via
Install New Software... for installation.
Ed Willink
Re: Why I cannot create a papyrus project [message #938528 is a reply to message #937276] Wed, 10 October 2012 00:15 Go to previous message
Member
Thanks, Ed. I have been using the installation of new plugins for a while via the instructions shown in the following website:
http://eclipseone.wordpress.com/2009/12/16/the-easy-way-to-reinstall-eclipse-and-share-plugins-across-multiple-installations/
So, from now on, you suggest not to follow it. Does P2 allow me to use the previous plugins from one Eclipse version to another version?
Previous Topic:Papyrus and attributes' types
Next Topic:Editor is dirty at openning
Current Time: Sun May 20 19:39:40 GMT 2018
Powered by FUDForum. Page generated in 0.02170 seconds
