Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Error launching main module as Acceleo Application
[Acceleo] Error launching main module as Acceleo Application [message #933114] Thu, 04 October 2012 14:50 Go to next message
Luís de Sousa is currently offline Luís de Sousa
Member
Dear all,
I'm starting a new Acceleo project and whenever I try to launch a main module as an Acceleo application I get the following error in the log:
Message: Couldn't load class dsl3s.templates.Main from project DSL3S
Exception Stack Trace:
An exception stack trace is not available.
Session Data:
eclipse.buildId=M20110909-1335
java.version=1.6.0_26
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product -product org.eclipse.epp.package.java.product -product org.eclipse.epp.package.java.product
Command-line arguments: -os linux -ws gtk -arch x86 -product org.eclipse.epp.package.java.product -product org.eclipse.epp.package.java.product -data /media/Data/users/lads/Trabalho/Eclipse/Workspace.DSL3S -product org.eclipse.epp.package.java.product
This happens with all main modules in the project. I have verified that all packages containing main modules are exported in the MANIFEST file.
I understand there is little information here. How can I provide more useful details?
Thank you,
Luís
Re: [Acceleo] Error launching main module as Acceleo Application [message #934838 is a reply to message #933114] Sat, 06 October 2012 07:02 Go to previous messageGo to next message
Member
Hello again,
Here in attachment goes a fresh Acceleo project that reproduces the error. If I try to launch the module test.mtl I get the error in the previous message. At the same time I'm getting also this warning:
Message: Couldn't load class test.Test. Check that its containing package is exported.
Session Data:
Command-line arguments: -os linux -ws gtk -arch x86 -product org.eclipse.epp.package.java.product -data /media/Data/users/lads/Trabalho/Eclipse/Workspace.DSL3S -product org.eclipse.epp.package.java.product
But as you can see in the project the export is there:
Export-Package: New.common
Besides this I can't provide much more information besides the software versions:
  Acceleo	3.3.0.v20120529-1042	org.eclipse.acceleo.feature.group	Eclipse Modeling Project
  MDT Papyrus - SDK: Runtime, Tools, Documentation and sources (Incubation)	0.8.1.v201109161105	org.eclipse.papyrus.sdk.feature.group	Eclipse Modeling Project
Eclipse:
Version: Indigo Service Release 1
Build id: 20110916-0149
Needless to say that I can't do any work with Acceleo right now. Please help.
Luís
Re: [Acceleo] Error launching main module as Acceleo Application [message #935833 is a reply to message #934838] Sun, 07 October 2012 07:10 Go to previous messageGo to next message
If you look at the bottom of the auto-generated Test.java you will see
some instructions on how to register packages such as UML. Try following
them.
Ed Willink
On 06/10/2012 12:02, Luís de Sousa wrote:
> Hello again,
> Quote:
>> Session Data:
> Eclipse:
> Luís
Re: [Acceleo] Error launching main module as Acceleo Application [message #941688 is a reply to message #933114] Fri, 12 October 2012 15:22 Go to previous messageGo to next message
Member
Hi Ed, thank you once again for your help. For future reference here's the line I added to the registerResourceFactories method:
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("New.common", New.common.Test.this);
Regards.
Re: [Acceleo] Error launching main module as Acceleo Application [message #942142 is a reply to message #941688] Sat, 13 October 2012 03:01 Go to previous messageGo to next message
Your line looks extremely suspect:
"New.common" is not an extension such as "*.common".
New.common.Test.this is unlikely to be a Resource Factory.
So you can probably delete the line because it does nothing.
Ed Willink
> Regards.
Re: [Acceleo] Error launching main module as Acceleo Application [message #966864 is a reply to message #942142] Thu, 01 November 2012 05:49 Go to previous message
Member
My apologies for the belated response.
Ed Willink wrote on Sat, 13 October 2012 03:01
Actually the template started running after including that, so it might do something after all...
In any case, given the project I attached here, what would be the correct content of this line?
Thank you.
Previous Topic:[Acceleo] Path in generated EMTL files differ when in debug or deployed
Next Topic:Executing a workflow (MWE) using a Model.xmi which is not part of a resource
Current Time: Sun May 19 20:10:48 EDT 2013
Powered by FUDForum. Page generated in 0.01767 seconds
