Home » Modeling » GMF (Graphical Modeling Framework) » Use GMF diagram only as a viewer rather than a editor
Use GMF diagram only as a viewer rather than a editor [message #933000] Thu, 04 October 2012 12:38 Go to next message
Martin Jacob is currently offline Martin Jacob
I am using GMF diagram only to view. The XMI file containing the information of nodes and edges is
generated by another program. As I have in my current example 10,000 nodes and about 15,000 edges to
open the diagram takes quite a while.
I already removed the labels of the edges but the time did reduce only 15% and takes still a long time.
I found the time spend to open the diagram updates all the AncestorHelpers. I imagine these are used
for editing only.
Is there a way to remove the edit functionality? I do not need to draw new edges or to add nodes but
I still want to bend existing edges.
Regards, Martin
Re: Use GMF diagram only as a viewer rather than a editor [message #934251 is a reply to message #933000] Fri, 05 October 2012 15:47 Go to previous message
Aurelien Pupier is currently offline Aurelien Pupier
I don't know which part you can remove or not. i think that you should try and you will see Smile
Otherwise, an idea to improve performance will be to use a binary serialization. This is something done in EMF but not yet in GMF. But if it is really important, I think that it will be a good way to improve the overall performance.
EDIT: if you are ok not to be able to move even edges, you can open a diagram in read-only mode: http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse.gmf.doc/howto/diagram/howto.html
Aurélien Pupier - BonitaSoft S.A.
My blog
My company Eclipse-related blog
[Updated on: Fri, 05 October 2012 15:54]
Report message to a moderator
Previous Topic:Show EObject in Diagram
Next Topic:EMF compare and merge
Current Time: Wed May 22 03:20:24 EDT 2013
Powered by FUDForum. Page generated in 0.01508 seconds
