Home » Newcomers » Newcomers » Adding/removing files from working sets
Adding/removing files from working sets [message #932177] Wed, 03 October 2012 22:46 Go to next message
Jesse Weinstein is currently offline Jesse WeinsteinFriend
Member
I cannot find a way to add or remove a particular file from a working set without going into the Edit Working Sets, scrolling through the very, very long list of files, and re-selecting the desired file. Is there any way to do this? Has someone written a plugin that adds this functionality?
For reference, I'm using Indigo, mainly with CDT (but I hope this would be general between the various language interfaces).
I also have AnyEdit installed.
Re: Adding/removing files from working sets [message #932391 is a reply to message #932177] Thu, 04 October 2012 04:06 Go to previous messageGo to next message
Jesse,
Drag and drop works nicely in the package explore, i.e., dragging a
project onto a working set in the project . You can hold the Ctrl key
down if you want to to add the same project to more than one working set
rather than just move it from one to the other. It looks like the
project explorer doesn't support that, and that's probably what you're
using, unless CDT has a specialized explorer that does...
> functionality?
Re: Adding/removing files from working sets [message #933050 is a reply to message #932391] Thu, 04 October 2012 17:34 Go to previous message
Member
Yes, I am using the Project Explorer, and no, it doesn't seem to have any such functionality. Grumble. Maybe I'll try asking in the CDT forum, specifically...
Previous Topic:Build Path Error
Next Topic:no proposals
Current Time: Thu May 24 02:32:45 GMT 2018
Powered by FUDForum. Page generated in 0.03028 seconds
