Home » Newcomers » Newcomers » Eclipse will not install Android Support Library(Problem creating first project)
Eclipse will not install Android Support Library [message #930744] Tue, 02 October 2012 15:45 Go to next message
Michael Mossman is currently offline Michael MossmanFriend
I am an experienced programmer but new to Android, hence using Eclipse for the first time.
Unfortunately I cannot get my first project off the ground. I get as far trying to create the project when the following sequence happens.
A screen arrives titled 'Install Dependencies' telling me that the required version is 8 and the installed version is 'Not installed'
I click on the Install/Upgrade button and something must happen because Android SDK Manager pops up and I get a whole series of 'Fetching:' messages.
The next screen asks me to Choose Package to Install and the only option is Android Support Library, revision 10. This doesn't bother me as I presume 10 is better than 8 so I hit the Install button.
This is where it all goes wrong as I get a red message saying:-
File not found:C:\Program Files (X86)\Android\android-sdk\temp\support_r10.zip (Acces is denied).
Sure enough, when I check this folder, it is empty.
Now, something must have happened as as SDK Manager did a whole lot of fetching and must have put these files somewhere.
I am quite happy to find them and put them in the correct folder but the question is
What is the name of the files that I am looking for ?
Can somebody please help. I am sure there must be a really simple solution.
Thank you, Mike
Re: Eclipse will not install Android Support Library [message #930797 is a reply to message #930744] Tue, 02 October 2012 16:51 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
> for the first time.
> messages.
> question is
> Thank you, Mike
Android programming isn't supported by Eclipse forums, but by Android
forums. See sticky posts at top of this forum for details. I would
suggest the formal Android source and/or one of those at this link:
http://www.javahotchocolate.com/tutorials/android.html#support
Re: Eclipse will not install Android Support Library [message #931742 is a reply to message #930797] Wed, 03 October 2012 13:34 Go to previous message
My problem must have been caused by a dodgy software release (probably Android ! ).
In sheer desperation I wiped everything clean and started again. This time I noticed some differences.
First of all, the Android download was version R20.0.3, then this insisted on Java 32-bit whereas before I loaded 64-bit for Windows 7. Just to be consistent, I also loaded 32-bit Eclipse.
The only other thing I did differently was to completely set up Android with all the extra packages before even starting Eclipse.
Everything now works O.K.
Previous Topic:Copying projects - how to?
Next Topic:Problem with Scout Tutorials
Current Time: Tue May 22 04:32:57 GMT 2018
Powered by FUDForum. Page generated in 0.05237 seconds
