Home » Eclipse Projects » Rich Client Platform (RCP) » Would it be possible to fix a customized perspective?
icon10.gif  Would it be possible to fix a customized perspective? [message #930638] Tue, 02 October 2012 14:00 Go to next message
Alexandra Niculai is currently offline Alexandra NiculaiFriend
Member
Hello!
Is it possible to customize a perspective in an Eclipse RCP application, save it as a new perspective, then make this new perspective fixed and share it with others? Thank you!
Alexandra.
Re: Would it be possible to fix a customized perspective? [message #933284 is a reply to message #930638] Thu, 04 October 2012 22:48 Go to previous messageGo to next message
Wim Jongman is currently offline Wim JongmanFriend
Hi Alexandra,
Try this article http://java.dzone.com/articles/share-eclipse-perspective
Wim
Re: Would it be possible to fix a customized perspective? [message #938027 is a reply to message #933284] Tue, 09 October 2012 13:39 Go to previous message
Member
Hi Wim,
I read the article and it's a good solution for a developer. But for a user it's not that obvious, especially for the "make the perspective fixed" part.
What I would actually want to be able to do is to allow some users to create their own perspectives dynamically (either in the RCP app using the "Save as...", either in an xml file) and make them be fixed.
Then I'd like to be able to somehow automatically load these dynamic perspectives to the other computers without actually creating a new update (without having to export a new product).
Greetings,
Alexandra.
[Updated on: Tue, 09 October 2012 13:40]
Report message to a moderator
Previous Topic:Product won't build with Delta Pack
Next Topic:Programatically open a menu from menubar
Current Time: Fri Feb 23 05:03:33 GMT 2018
Powered by FUDForum. Page generated in 0.02175 seconds
