Home » Modeling » EMF » how to get the reachable objects from an EObject
how to get the reachable objects from an EObject [message #929864] Mon, 01 October 2012 20:55 Go to next message
Junior Lekane Nimpa is currently offline Junior Lekane NimpaFriend
Hello everyone,
i am quite new to EMF and i want to implement a property sheet to display some properties of EObjects. Actually i am facing a problem. I want to display all types that an ETypedElement can take as value. But i don't know how to get all those reachable types.
Can someone help me?
Any help would be really appreciate
regards
Junior
Re: how to get the reachable objects from an EObject [message #929898 is a reply to message #929864] Mon, 01 October 2012 21:37 Go to previous messageGo to next message
Christian W. Damus is currently offline Christian W. DamusFriend
Hi, Junior,
Have a look at the implementation of getChoiceOfValues() in the
ItemPropertyDescriptorWithUniqueChoiceOfValueLabels inner class in the
EModelElementItemProvider for an example.
Christian
On 2012-10-01 20:55:55 +0000, Junior Lekane Nimpa said:
> Hello everyone,
> regards
> Junior
Re: how to get the reachable objects from an EObject [message #934016 is a reply to message #929898] Fri, 05 October 2012 15:10 Go to previous messageGo to next message
Hello ,
Thanks christian for your reply. I had a look at the implementation of getChoicesOfValues, but since i am new to EMF, i could not get smart.
Basically, my problem is as follows.
I am implementing property sheet pages to visualize some properties of EObjects
and i want to user to be able to set the eType of a selected ETypedElement in an advanced property sheet. To do this, i use a ComboBoxViewerCellEditor.
But i don't know what should be the input of the cellEditor, so that it display for example the following:
EBoolean
EChar
EString
I tried the following:
ComboBoxViewerCellEditor.setInput(EcorePackage.Literals.ECLASSIFIER);
But i only get the attributes of the MetaObject EClassifier displayed.
I also tried the following
IItemPropertyDescriptor descriptor = new ItemPropertyDescriptor(new   EcoreItemProviderAdapterFactory(),null,null,EcorePackage.Literals.ETYPED_ELEMENT__ETYPE);
 result = descriptor.getChoiceOfValues(typedElement);
i only get the classes that are contained in my .ecore file.
But how do i get all predefined types like EBoolean,EString,... and all classes, that are contained in my .ecore file together as input of the ComboBoxViewerCellEditor?
Any hint and/or answer is really welcome
Junior
Re: how to get the reachable objects from an EObject [message #934799 is a reply to message #934016] Sat, 06 October 2012 09:56 Go to previous messageGo to next message
You'd need a content provider and a label provider for that; the
contents presumably will be computed by the content produced by the
content provider.
What you'll want is very similar to
org.eclipse.emf.ecore.provider.ETypedElementItemProvider.addETypePropertyDescriptor(...).new
ItemPropertyDescriptorWithUniqueChoiceOfValueLabels()
{...}.getChoiceOfValues(Object)
If you have an ETypedElement why don't get use
EcoreItemProviderAdapterFactory to get an adapter for
IItemPropertySource and then
org.eclipse.emf.edit.provider.IItemPropertySource.getPropertyDescriptor(Object,
Object) to get the property descriptor (the second argument should be
EcorePackage.Literals.ETYPED_ELEMENT__ETYPE) from which you can call
getChoiceOfValues. If you use EMF's content and label providers in the
cell editor, you can use
org.eclipse.emf.edit.provider.ItemProvider.ItemProvider(Collection<?>)
to create an input object that will list these choices.
On 05/10/2012 5:10 PM, Junior Lekane Nimpa wrote:
> Hello ,
> EObjects
> ComboBoxViewerCellEditor. But i don't know what should be the input of
> EBoolean
> EChar
> EString
> Regards
> Junior
Re: how to get the reachable objects from an EObject [message #937743 is a reply to message #934799] Tue, 09 October 2012 08:17 Go to previous message
Hi Ed,
many thanks for your reply.
Now i understand a little bit more.
Best regards
Junior
Previous Topic:Serialize only selected objects....
Next Topic:[net4j] Configuring the HTTP Acceptor
Current Time: Wed Apr 25 11:01:29 GMT 2018
Powered by FUDForum. Page generated in 0.01613 seconds
