Home » Modeling » Graphiti » Connection Feature and Drop on Canvas
Connection Feature and Drop on Canvas [message #929419] Mon, 01 October 2012 12:51 Go to next message
Surya Kathayat is currently offline Surya KathayatFriend
Member
I have a "Task node A" (graphical node in graphiti) with a "Context button". The context button is in tended to create a new "Task node B" and a link connting from A to B.
"Task node A" and context button is shown in the figure below.
index.php/fa/11676/0/
When I drag starting from context button and drop on the canvas editor, I get the new task created but the "link" is not created as expected as you can see in the following diagram. The link unexpectedly ends up towards the left top corner of the editor.
index.php/fa/11677/0/
I have created a feature class "OrderLinkToActionTaskCreateFeature" as following.
public class OrderLinkToActionTaskCreateFeature extends OrderLinkCreateFeature {
	public OrderLinkToActionTaskCreateFeature(IFeatureProvider fp) {
		super(fp);
	public boolean canCreate(ICreateConnectionContext context) {
		return true;
	public Connection create(ICreateConnectionContext context) {
		try {
			Connection newConnection = null;
			// get Tasks which should be connected
			Task source = super.getTask(context.getSourceAnchor());
			Task target = createTargetTask();
			//dynamically add new action task to the diagram
			AddContext addContext = new AddContext();
			addContext.setNewObject(target);
			addContext.setTargetContainer(getDiagram());
			//set location for PE and location constraints BO
			addContext.setX(context.getTargetLocation().getX());
			addContext.setY(context.getTargetLocation().getY() );
			target.setConstraints(new Rectangle(context.getTargetLocation().getX(), context.getTargetLocation().getY(), 100, 60));
			IAddFeature addFeature = getFeatureProvider().getAddFeature(addContext);
			if (addFeature.canAdd(addContext)) {
				addFeature.add(addContext);
			// now add connection
			if (source != null && target != null) {
				// create new business object
				OrderLink eReference = super.createOrderLink(source, target);
				// add connection for business object
				AddConnectionContext addConnContext = new AddConnectionContext(context.getSourceAnchor(), context.getTargetAnchor());
				addConnContext.setNewObject(eReference);
				addConnContext.setTargetContainer(getDiagram());
				newConnection = (Connection) getFeatureProvider().addIfPossible(addConnContext);
	    	// set the state of editor to dirty
	    	DiagramUtil.setActiveEditorStateToDirty();
			return newConnection;
		} catch (Exception e) {
			e.printStackTrace();
		return null;
	private Task createTargetTask(){
		Task actionTask = IdmmodelFactory.eINSTANCE.createActionTask();
		actionTask.setName("action task.." + new Random().nextInt(999));
		actionTask.setPrivateTask(1);
		actionTask.setHasSubtasks(0);
		actionTask.setIsExpanded(true);
		actionTask.setGuid(UUID.randomUUID().toString().toUpperCase());
		actionTask.setInstanceId(UUID.randomUUID().toString().toUpperCase());
		actionTask.setActionType(IConstants.ACTION_TASK);
		actionTask.setUiTaskType(0);
		return actionTask;
When I debug down, I noticed that connection context target anchor is null in the corresponding add feature class ("OrderLinkAddFeature" shown at the end of this post) i.e addConContext.getTargetAnchor() in connection.setEnd(addConContext.getTargetAnchor()); is null in OrderLinkAddFeature class.
Any pointers will be highly appreciated.
Best Regards
Surya
Additional code
Super class of the above feature class is following which is used to connect to Tasks nodes that are already present on the canvas which works properly.
public class OrderLinkCreateFeature extends AbstractCreateConnectionFeature {
	public OrderLinkCreateFeature (IFeatureProvider fp) {
		// provide name and description for the UI, e.g. the palette
		super(fp, "Order Link", "Create Order Link");
    public String getCreateImageId() {
    	return ImageUtil.IMG_ORDERLINK;
		try {
			// return true if both anchors belong to an EClass
			// and those EClasses are not identical
			Task source = getTask(context.getSourceAnchor());
			Task target = getTask(context.getTargetAnchor());
			if (source != null && target != null && source != target) {
				return LinkUtils.canLinkCreate(source, target, this);
			return false;
		return false;
	public boolean canStartConnection(ICreateConnectionContext context) {
		try {
			// return true if start anchor belongs to a EClass
			if (source != null) {
				return LinkUtils.canLinkStart(source, this);
		return false;
		try {
			// get EClasses which should be connected
				OrderLink eReference = createOrderLink(source, target);
				AddConnectionContext addContext = new AddConnectionContext(context.getSourceAnchor(), context.getTargetAnchor());
				addContext.setNewObject(eReference);
				newConnection = (Connection) getFeatureProvider().addIfPossible(addContext);
				//addGraphicalRepresentation(addContext, eReference);
		return null;
	 * Returns the EClass belonging to the anchor, or null if not available.
	public Task getTask(Anchor anchor) {
		try {
			if (anchor != null) {
				Object object = getBusinessObjectForPictogramElement(anchor.getParent());
				if (object instanceof Task) {
					return (Task) object;
		return null;
	 * Creates a EReference between two EClasses.
	public OrderLink createOrderLink(Task source, Task target) {
		try {
			OrderLink link = IdmmodelFactory.eINSTANCE.createOrderLink();
			link.setName("");
			link.setSource(source);
			link.setTarget(target);
			source.getOutgoingLinks().add(link);
			target.getIncomingLinks().add(link);
			//link.setSource(source);
			//target.getIncomingLinks().add(link);
			/*eReference.setEType(target);
			eReference.setLowerBound(0);
			eReference.setUpperBound(1);
			source.getEStructuralFeatures().add(eReference);*/
			return link;
		return null;
The corresponding feature is following
public class OrderLinkAddFeature extends AbstractAddFeature {
   // private static final IColorConstant E_REFERENCE_FOREGROUND = new ColorConstant(98, 131, 167);
    public OrderLinkAddFeature (IFeatureProvider fp) {
        super(fp);
    public PictogramElement add(IAddContext context) {
        IAddConnectionContext addConContext = (IAddConnectionContext) context;
        OrderLink orderLink = (OrderLink) context.getNewObject();
        IPeCreateService peCreateService = Graphiti.getPeCreateService();
        Diagram targetDiagram = LinkUtils.getDiagramFromConnectionAddContext(addConContext);
        // CONNECTION WITH POLYLINE
        ManhattanConnection connection = peCreateService.createManhattanConnection(getDiagram()); //peCreateService.createFreeFormConnection(getDiagram());
        connection.setStart(addConContext.getSourceAnchor());
        IGaService gaService = Graphiti.getGaService();
        Polyline polyline = gaService.createPolyline(connection);
        polyline.setLineWidth(2);
        polyline.setForeground(manageColor(IdmColors.TASK_BORDER_COLOR));
        // create link and wire it
        link(connection, orderLink);
        // add dynamic text decorator for the association name
        ConnectionDecorator textDecorator = peCreateService.createConnectionDecorator(connection, true, 0.1, true);
        Text text = gaService.createDefaultText(getDiagram(),textDecorator);
        text.setForeground(manageColor(IColorConstant.BLACK));
        gaService.setLocation(text, 5, 0);
        // set reference name in the text decorator
        //text.setValue((orderLink.getGroup()==null)?"":orderLink.getGroup());
        // add static graphical decorator (composition and navigable)
        ConnectionDecorator cd;
        cd = peCreateService.createConnectionDecorator(connection, false, 1.0, true);
        createArrow(cd);
        // add model
        targetDiagram.getLink().getBusinessObjects().add(orderLink);
        return connection;
    public boolean canAdd(IAddContext context) {
    	try {
    		// return true if given business object is an OrderLink
	        // note, that the context must be an instance of IAddConnectionContext
	        if (context instanceof IAddConnectionContext && context.getNewObject() instanceof OrderLink) {
	        	return true;
        return false;
    private Polyline createArrow(GraphicsAlgorithmContainer gaContainer) {
    	try {
	       // Polyline polyline = gaService.createPolyline(gaContainer, new int[] { -15, 10, 0, 0, -15, -10 });
	        Polyline polyline = gaService.createPolyline(gaContainer, new int[] { -10, 5, 0, 0, -10, -5 });
	        return polyline;
			// TODO: handle exception
    	return null;
  • Attachment: before.gif
    (Size: 7.05KB, Downloaded 523 times)
  • Attachment: after.gif
    (Size: 12.47KB, Downloaded 510 times)
[Updated on: Mon, 01 October 2012 12:57]
Report message to a moderator
Re: Connection Feature and Drop on Canvas [message #929944 is a reply to message #929419] Mon, 01 October 2012 22:48 Go to previous messageGo to next message
Aljoscha Hark is currently offline Aljoscha HarkFriend
Hi there,
I think the problem is that you pass the TargetAnchor of the [context during dragging] to the AddFeature. There is none. I think you should pass the anchor of the created Shape therefore.
Greetings,
Aljoscha
Re: Connection Feature and Drop on Canvas [message #930298 is a reply to message #929944] Tue, 02 October 2012 07:26 Go to previous message
Member
Thanks Aljoscha. It works just by doing setEnd(anchor) to the connection.
BR
Surya
Previous Topic:Using CDO Dawn with Graphiti
Next Topic:Gradiently render/fill Rectangles/Rounded Rectangles/ Polygons
Current Time: Mon May 21 15:27:10 GMT 2018
Powered by FUDForum. Page generated in 0.02430 seconds
