Home » Modeling » Papyrus » PAPYRUS! how to operate checking OCL constraints on stereotypes!(PAPYRUS! how to operate checking OCL constraints on stereotypes!)
PAPYRUS! how to operate checking OCL constraints on stereotypes! [message #928279] Sun, 30 September 2012 13:55 Go to next message
Tahar gh is currently offline Tahar ghFriend
hello
using PAPYRUS, how to operate OCL constraints checking on stereotypes!
I use:
- Eclipse Modeling Tools (galileo) Build id: 20100218-1602
- Papyrus UML Modeler 1.12.3.200912231359
and I wanted to test this simple example: "How to use OCL constraints in Papyrus" which can be found easily on papyrusuml site.
All steps were followed and everything works fine, but arriving at the final stage (Validation -> Validate OCL constraints in Defined Stereotypes), the control pass even though the constraint is violated (see the example in attachment)!
I remade this example several times and even on two different machines but the control of the OCL constraint always passes successfully!
In fact, in my Eclipse/PAPYRUS environment I've the Menu "Validate OCL constraints in Defined Profile" and not "Validate OCL constraints Defined Stereotypes in" as in the example.
Thank you for your help
Re: PAPYRUS! how to operate checking OCL constraints on stereotypes! [message #928451 is a reply to message #928279] Sun, 30 September 2012 16:40 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
This functionality is not currently available.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=388529 provides a patch to
allow editing OCL constraints that use Stereotype facilities.
Providing a Validation Rule dispatcher that recognises Profiles as a
Constraint source remains to be done.
Ed Willink
On 30/09/2012 15:55, Tahar gh wrote:
> hello
> I use:
Re: PAPYRUS! how to operate checking OCL constraints on stereotypes! [message #929392 is a reply to message #928451] Mon, 01 October 2012 12:19 Go to previous messageGo to next message
Mr Ed thanks for your reply
I have to build an uml profile with OCL constraints on stereotypes and then realize models conform to this profile; for this reason I need to check the conformity of the realized models to the profile (in an other word, I must check that OCL constraints are respected by these models). because papyrus does not implement this option, is there any other free (or open) tool that do it? and in the absence of such tools how, based on your experience, can I resolve this question?
Thank you in advance
Re: PAPYRUS! how to operate checking OCL constraints on stereotypes! [message #929517 is a reply to message #929392] Mon, 01 October 2012 14:29 Go to previous messageGo to next message
No promises, but if you just load you UML model in the Sample UML Model
editor and invoke Validate it might do what you want.
Ed Willink
Re: PAPYRUS! how to operate checking OCL constraints on stereotypes! [message #930518 is a reply to message #929517] Tue, 02 October 2012 11:45 Go to previous messageGo to next message
Cedric Dumoulin is currently offline Cedric DumoulinFriend
Member
Ed Willink a écrit :
> Hi
If this work, it should be easy to add the option directly from the
Papyrus modelexplorer.
Can someone confirm that this work ?
Cedric
> Regards
> Ed Willink
Re: PAPYRUS! how to operate checking OCL constraints on stereotypes! [message #930538 is a reply to message #930518] Tue, 02 October 2012 12:06 Go to previous message
Very unlikely to work in Papyrus because Papyrus has discarded the
standard EMF Validation support in favour of EMFv registrations.
Ed Willink
>> Hi
> Cedric
>> Regards
>> Ed Willink
Previous Topic:How to activate Model Explorer, Outline, Properties views automatically
Next Topic:AssociationEditHelperAdvice and getAfterSetCommand
Current Time: Tue Jan 16 10:00:57 GMT 2018
Powered by FUDForum. Page generated in 0.01770 seconds
