Home » Language IDEs » C / C++ IDE (CDT) » QT and CDT
QT and CDT [message #125820] Thu, 04 November 2004 10:43 Go to next message
Gael Martin is currently offline Gael MartinFriend
Member
Dear all, I'm using CDT 2.1RC0 to develop QT applications.
QT use this signals/slots mechanism, therefore you do find the macro
"slots" and "signals" in the classes declaration, for instance:
class Test : public QObject
public:
Test();
~Test();
private slots:
void mySlot();
signals:
void mySignal();
However the CDT parser failed to register the class whenever it finds
the word "signals" or "slots" in the class declaration. Is there anyway
to configure the parser to ignore them and still register this as a
class or I have to dig into the code?
Gael
Re: QT and CDT [message #125860 is a reply to message #125820] Thu, 04 November 2004 12:14 Go to previous messageGo to next message
Vaidotas Radžius is currently offline Vaidotas RadžiusFriend
> public:
> Test();
> ~Test();
> private slots:
> void mySlot();
> signals:
> void mySignal();
> Gael
In Project Peoperties -> C/C++ Include Paths & Symbols press Add
Preprocessor Symbol button and type in signals=/*signals*/. Repeat the
same with slots
Maybe this helps
Vaidas
Re: QT and CDT [message #125887 is a reply to message #125860] Thu, 04 November 2004 12:58 Go to previous messageGo to next message
Member
> same with slots
Indeed, that works fine now, thanks ever so much.
Gael
Re: QT and CDT [message #125965 is a reply to message #125860] Thu, 04 November 2004 19:25 Go to previous messageGo to next message
>> public:
>> Test();
>> ~Test();
>> private slots:
>> void mySlot();
>> signals:
>> void mySignal();
>> Gael
> same with slots
> Maybe this helps
But are not those things define somewhere in a qt header, for all to use.
maybe the problem is that this file was not included i.e. #include
qt_macros.h
are something ?
Not a QT expert
> Vaidas
Re: QT and CDT [message #134667 is a reply to message #125965] Wed, 12 January 2005 21:55 Go to previous messageGo to next message
>>> public:
>>> Test();
>>> ~Test();
>>> private slots:
>>> void mySlot();
>>> signals:
>>> void mySignal();
>>> anyway to configure the parser to ignore them and still register this
>>> as a class or I have to dig into the code?
>>> Gael
>> same with slots
>> Maybe this helps
> qt_macros.h
> are something ?
Yes, however, they are defined as:
#define signal
#define slot
so perhaps they cannot be properly interpreted?
Re: QT and CDT [message #134877 is a reply to message #134667] Fri, 14 January 2005 15:28 Go to previous messageGo to next message
Andrew Niefer is currently offline Andrew NieferFriend
not knowing anything about QT : note that even if signals & slots are
#defined away, the below code would be preprocessed as:
private : //ok
void mySlot();
: //not ok
void mySignal();
with the given code, you would need to #define signals as one of public,
protected, private.
-Andrew
"Joshua Pollak" <pardsbane@offthehill.org> wrote in message
news:cs46cf$6hl$1@www.eclipse.org...
> alain wrote:
> > Vaidotas Rad
Re: QT and CDT [message #641509 is a reply to message #134667] Thu, 25 November 2010 18:05 Go to previous messageGo to next message
Daniel  is currently offline Daniel Friend
Hello guys,
Propably it is not anymore usefull for you, but what i do to get it work is the following:
first i add the path that vaias said before:
"In Project Peoperties -> C/C++ Include Paths & Symbols press Add
same with slots "
And then i add
#define signals
#define slots
as well as the declaration of the slot: (for example)
private slots:
void on_Ok_clicked();
on the ui_AddressBook.h
finally the code for the on_Ok_clicked() on the AddresBook.cpp.
I hope it is gonna help someone....
Re: QT and CDT [message #641568 is a reply to message #641509] Fri, 26 November 2010 07:03 Go to previous message
Axel Mueller is currently offline Axel MuellerFriend
Daniel wrote on Thu, 25 November 2010 19:05
Hello guys,
same with slots "
And then i add
#define signals
#define slots
private slots:
It is not necessary to add the defines manually. You should add the include path for Qt in Project Peoperties -> C/C++ General->Include Paths & Symbols->Includes (C++). Eclipse will then find the correct headers and can resolve the symbols.
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Previous Topic:Import a list of files
Next Topic:Debugging win32 C/C++ console application in Helios
Current Time: Sun Jan 21 20:09:10 GMT 2018
Powered by FUDForum. Page generated in 0.02537 seconds
