Home » Eclipse Projects » Vex » Slides from EclpseCon 2011
Slides from EclpseCon 2011 [message #925463] Thu, 27 September 2012 18:46 Go to next message
Kris Missing name is currently offline Kris Missing nameFriend
Member
is it possible to get the slides that have been presented at EclipseCon
2011 about Vex? It was not possible to visit the conference
Also, I have seen on the New and Noteworthy page that Vex has Image
support. How does this support look like? E.g. for an XHTML doc, is it
enough to add a img element with src-attribute that contains a relative
link to the image?
Kris
Re: Slides from EclpseCon 2011 [message #926211 is a reply to message #925463] Fri, 28 September 2012 12:15 Go to previous messageGo to next message
Holger Voormann is currently offline Holger VoormannFriend
Hi Kris,
Samples and snippets of Florian's Vex EclipseCon Europe 2011 talk (which are more important than the slides) are at GitHub: github.com/ftl/ece2011
Yes, in XHTML the path of the image to show are specified by the src attribute of the img element. This is done via CSS:
img {
  background-image: attr(src);
  height: attr(height);
  width: attr(width);
In CSS you could either directly specify the path of the (background) image (same image for all matching elements) or delegate to an attribute value (attr(...)).
Re: Slides from EclpseCon 2011 [message #932025 is a reply to message #926211] Wed, 03 October 2012 19:05 Go to previous messageGo to next message
Member
Hi Holger,
thanks for the info on the examples from the talk. They helped me to
understand the vex editor a little better.
What I am still struggling with is the display of images. The inline
display (img height = line height) is OK, but the display of images that
shall have their original size - I don't get it to work.
Is there an xhtml example that shows how to display images non inline,
e.g. what you can see here:
http://wiki.eclipse.org/Vex/NewAndNoteworthy#1.0.0_M3_.282010-11-08.29
(the big image)?
In Bug 298912 the following is mentioned
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=298912#c30):
"In block elements, Vex tries to show the image in its original size,
but scales it to the width of the containing element, if the image is
bigger."
I am not sure whether my tests have properly set a "block element" in
xhtml strict. E.g. what I tried is:
<?xml version='1.0'?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>Test</title>
</head>
<body>
<p>Text Text Text</p>
<div>
<img src="eclipse-vex-page.png"></img>
</div>
<p/>
</body>
</html>
As style I am using the "XHTML plain" as part of vex editor. This css
has the definition:
div {
display: block;
So I think this is a proper interpretation for a block element in xhtml
with the used css. However the image displayed is limited to the line
height although it is far bigger in height an width as displayed.
What I also tried is giving the img tag in the xhtml in the style
attribute the "display: block" directly; unfortunately with no effect...
To cut the long story short - what must one do to display images in
xhtml as block element having its original size?
Kris
Am 28.09.12 14:15, schrieb Holger Voormann:
> Hi Kris,
> img {
> width: attr(width);
> value (attr(...)).
Re: Slides from EclpseCon 2011 [message #934012 is a reply to message #932025] Fri, 05 October 2012 15:06 Go to previous messageGo to next message
Hi Kris,
The image belongs to the img element which is an inline (and not a block) element. It seems, the image support for inline elements is incomplete.
Could you please open a bug: https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Mylyn%20Docs%20Vex
Thx,
Holger
Re: Slides from EclpseCon 2011 [message #946971 is a reply to message #934012] Tue, 16 October 2012 17:37 Go to previous message
Member
Hi Holger,
sorry for the delay in my response - the last days have been very very
busy.
I got it working now with the following:
<img class="blockstyle" src="img-big.jpg"/>
and CSS:
..blockstyle{
display: block;
text-align: center;
That's why I am unsure about the bug and probably everything works as
expected. I mean - do children of a <div> with style "display:block"
have to inherit this layout behaviour. If yes, then I would open a bug,
if not, I think it's a feature.
Thanks & Regards
Kris
Am 05.10.12 17:06, schrieb Holger Voormann:
> Hi Kris,
> incomplete.
> Thx,
> Holger
Previous Topic:embedding VEX editor into a Dialog
Next Topic:table layout - spanning
Current Time: Wed Apr 25 07:14:15 GMT 2018
Powered by FUDForum. Page generated in 0.01622 seconds
