Home » Modeling » EMF » Cross-domain references
Cross-domain references [message #924223] Wed, 26 September 2012 16:22 Go to next message
Martin  odloucký is currently offline Martin odlouckýFriend
Member
in my application, I would like to have two editing domains with separate command stacks, one for model A and one for model B. However, model A may reference some parts of model B and vice versa. What if I delete some part of model B referenced from model A? Model A will not notice the change. Is there some prefered way to handle such situations so that the models and the command stack will stay consisten? Let's say I have two editors each one with its own editing domain.
Thanks.
Re: Cross-domain references [message #924768 is a reply to message #924223] Thu, 27 September 2012 05:31 Go to previous message
Martin,
I think you should have a look at the EMF transaction framework. It
doesn't give you exactly this, but what you suggest below sounds unworkable.
On 26/09/2012 6:22 PM, Martin odloucký wrote:
> Hello,
> domain.
> Thanks.
Previous Topic:[CDO] Could not activate TCPClientConnector on CDO Hibernate
Next Topic:Fast retrieval of an EClassifier by qualified name and root EPackage
Current Time: Tue Jan 16 23:24:13 GMT 2018
Powered by FUDForum. Page generated in 0.01882 seconds
