Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMF Compare & ChangeDescription on Teneo/Database backed EMF objects
EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #125164] Thu, 05 June 2008 15:47 Go to next message
Jason Henriksen is currently offline Jason Henriksen
Hi all,
This is really a theoretical concern that I want to put in your brains,
more than a specific bug. That said, I'm worried that the current
implementation of ChangeDescription is going to bite me if I use it as
it is.
I've just recorded a ChangeDescription on an object I held in my client
tier. The change description has a part that looks like this:
<value featureName="contactList">
<listChanges kind="REMOVE" index="4"/>
</value>
On the server I receive the change description, load the referenced
object out of the database and get ready to apply the change to the
Teneo backed object.
But here's the rub: Teneo/Hibernate does NOT guarantee that the objects
in the child list will be in the same order each time it is loaded from
the DB! (unlike a filesystem file that is the same each time you load
it) I can force Teneo to track the child-object-order but that means
adding a column to the database and sorting by that column when I
populate the list. Since my EMF objects are sitting on top of a legacy
database I can't easily do that plus it's a lot of error prone work to
make sure that's done correctly for every child list in the data model.
So now if I apply the change I'm going to delete whatever child object
happens to be in position 4 even though the order of the list may have
been shuffled. Oops.
Here's a possible solution: Database backed objects should all have an
@Id member in them. If the listChanges tag contained the value of the
ID column whenever it is present then we could use these
ChangeDescriptions on DB backed objects and be safe. As it is,
ChangeDescription + Teneo backed EMF = potentially lost data unless your
Teneo annotations are very specific and carefully checked.
Is that analysis correct, or does Ed have some magic up his sleeve?
Thanks all,
Jason Henriksen
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #125165 is a reply to message #125164] Thu, 05 June 2008 16:53 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hi Jason,
I think that a change descriptor with a list index won't even work in an environment were the list
index was also present in the db. Assume that the server receives the changedescription you listed
below. Now between the time the object was passed to the client and the changedescription comes back
the list has been adapted by another client then the indexes in the list will have changed anyway.
Or do you prevent this by doing a version check?
To solve this what you mean is that the changedescription should be recorded as:
<listChanges kind="REMOVE" id="5_myentityname"/>
</value>
(whereby id is something encoding the id and the entityname)
correct?
I think this is more an emf question than a Teneo question though.
gr. Martin
jason henriksen wrote:
> Hi all,
> it is.
> </value>
> Thanks all,
> Jason Henriksen
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #125166 is a reply to message #125165] Thu, 05 June 2008 17:17 Go to previous messageGo to next message
Hi Martin!
I do agree that this isn't really a teneo problem, it's more a problem
that the ChangeDescriptions are assuming that all lists are ordered when
for us that's not true.
Also, I am assuming that we're not letting users change values that have
been changed by other users. However I control that via external tokens
and a db lock count. That part is outside the scope of the
ChangeDescription stuff.
Jason
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #125167 is a reply to message #125165] Thu, 05 June 2008 17:21 Go to previous messageGo to next message
Eclipse User
Martin,
A change description for which the referenced model has changed in some
potentially arbitrary way just isn't coherent. Imagine trying to add to
a specific location in a list, but the list has different contents;
what's the right location. It's possible to set values explicitly and
have them serialized too...
Martin Taal wrote:
> Hi Jason,
> an environment were the list index was also present in the db. Assume
> that the server receives the changedescription you listed below. Now
> changedescription comes back the list has been adapted by another
> client then the indexes in the list will have changed anyway. Or do
> recorded as:
> </value>
> correct?
> gr. Martin
>> Hi all,
>> brains, more than a specific bug. That said, I'm worried that the
>> current implementation of ChangeDescription is going to bite me if I
>> use it as it is.
>> client tier. The change description has a part that looks like this:
>> </value>
>> objects in the child list will be in the same order each time it is
>> loaded from the DB! (unlike a filesystem file that is the same each
>> time you load it) I can force Teneo to track the child-object-order
>> but that means adding a column to the database and sorting by that
>> column when I populate the list. Since my EMF objects are sitting on
>> top of a legacy database I can't easily do that plus it's a lot of
>> error prone work to make sure that's done correctly for every child
>> object happens to be in position 4 even though the order of the list
>> may have been shuffled. Oops.
>> an @Id member in them. If the listChanges tag contained the value of
>> the ID column whenever it is present then we could use these
>> your Teneo annotations are very specific and carefully checked.
>> Thanks all,
>> Jason Henriksen
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #125168 is a reply to message #125167] Thu, 05 June 2008 17:46 Go to previous messageGo to next message
Hi Ed,
Yes, but is there a way to handle non-ordered lists using change descriptors?
gr. Martin
Ed Merks wrote:
> Martin,
> Martin Taal wrote:
>> Hi Jason,
>> recorded as:
>> </value>
>> correct?
>> gr. Martin
>>> Hi all,
>>> use it as it is.
>>> </value>
>>> Thanks all,
>>> Jason Henriksen
The Netherlands
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #125169 is a reply to message #125168] Thu, 05 June 2008 18:44 Go to previous messageGo to next message
Eclipse User
--------------080903090802060303080803
Martin,
List verses unordered are mutually exclusive terms since lists are
ordered collections. Is there a way to just treat a multi-valued
feature as a just set? No, EMF assumes that all features are backed by
lists and even if order has no deep semantic meaning, order is something
that's intended to be preserved and will be preserved. Some old
bugzillas are open regarding this type of issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=75931
https://bugs.eclipse.org/bugs/show_bug.cgi?id=89325
It's very hard to change the framework break assumptions of the past...
Martin Taal wrote:
> Hi Ed,
> descriptors?
> gr. Martin
> Ed Merks wrote:
>> Martin,
>> some potentially arbitrary way just isn't coherent. Imagine trying
>> to add to a specific location in a list, but the list has different
>> contents; what's the right location. It's possible to set values
>> explicitly and have them serialized too...
>> Martin Taal wrote:
>>> Hi Jason,
>>> in an environment were the list index was also present in the db.
>>> the changedescription comes back the list has been adapted by
>>> anyway. Or do you prevent this by doing a version check?
>>> recorded as:
>>> </value>
>>> correct?
>>> gr. Martin
>>>> Hi all,
>>>> I use it as it is.
>>>> </value>
>>>> child-object-order but that means adding a column to the database
>>>> and sorting by that column when I populate the list. Since my EMF
>>>> objects are sitting on top of a legacy database I can't easily do
>>>> that plus it's a lot of error prone work to make sure that's done
>>>> list may have been shuffled. Oops.
>>>> have an @Id member in them. If the listChanges tag contained the
>>>> value of the ID column whenever it is present then we could use
>>>> these ChangeDescriptions on DB backed objects and be safe. As it
>>>> is, ChangeDescription + Teneo backed EMF = potentially lost data
>>>> unless your Teneo annotations are very specific and carefully checked.
>>>> Thanks all,
>>>> Jason Henriksen
<html>
<head>
</head>
Martin,<br>
<br>
ordered collections.&nbsp; Is there a way to just treat a multi-valued
feature as a just set?&nbsp; No, EMF assumes that all features are backed by
something that's intended to be preserved and will be preserved. Some
old bugzillas are open regarding this type of issue:<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=75931">https://bugs.eclipse.org/bugs/show_bug.cgi?id=75931</a><br>
<a href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=89325">https://bugs.eclipse.org/bugs/show_bug.cgi?id=89325</a><br>
</blockquote>
It's very hard to change the framework break assumptions of the past...<br>
<br>
<br>
Martin Taal wrote:
<blockquote cite="mid:g29mr9$2nf$1@build.eclipse.org" type="cite">Hi
Ed,
<br>
descriptors?
<br>
<br>
gr. Martin
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Martin,
<br>
<br>
potentially arbitrary way just isn't coherent.&nbsp; Imagine trying to add
to a specific location in a list, but the list has different contents;
what's the right location.&nbsp;&nbsp; It's possible to set values explicitly and
<br>
<br>
<br>
Martin Taal wrote:
<br>
<blockquote type="cite">Hi Jason,
<br>
client then the indexes in the list will have changed anyway. Or do you
<br>
<br>
recorded as:
<br>
&lt;value featureName="contactList"&gt;
<br>
&nbsp;&nbsp; &lt;listChanges kind="REMOVE" id="5_myentityname"/&gt;
<br>
&lt;/value&gt;
<br>
<br>
<br>
correct?
<br>
<br>
<br>
<br>
gr. Martin
<br>
<br>
<br>
<blockquote type="cite">Hi all,
<br>
<br>
more than a specific bug.&nbsp; That said, I'm worried that the current
it is.
<br>
<br>
tier.&nbsp; The change description has a part that looks like this:
<br>
<br>
<br>
&nbsp; &lt;listChanges kind="REMOVE" index="4"/&gt;
<br>
&lt;/value&gt;
<br>
<br>
<br>
<br>
But here's the rub:&nbsp; Teneo/Hibernate does NOT guarantee that the
time you load it)&nbsp; I can force Teneo to track the child-object-order
column when I populate the list.&nbsp; Since my EMF objects are sitting on
<br>
<br>
been shuffled.&nbsp; Oops.
<br>
<br>
Here's a possible solution:&nbsp; Database backed objects should all have an
@Id member in them.&nbsp; If the listChanges tag contained the value of the
ChangeDescriptions on DB backed objects and be safe.&nbsp; As it is,
<br>
<br>
<br>
<br>
Thanks all,
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Jason Henriksen
<br>
<br>
<br>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------080903090802060303080803--
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #125170 is a reply to message #125165] Thu, 05 June 2008 19:06 Go to previous messageGo to next message
HaHA! Maybe this was a red herring of a problem!
On further analysis I've found that if I make the object have an
attribute with type xsd:ID then my child object references go from being
an index into being a URL that contains the REAL ID TEXT! This is a big
win because it means that the order of the listing is no longer
important at all.
For example:
<subDiffElements xsi:type="diff:UpdateAttribute">
<attribute
href="http:///com/ibm/example/Building.ecore#//Building/size"
<leftElement href="original.xml#home"/>
<rightElement href="altered.xml#vacation home"/>
</subDiffElements>
From what I've ready, Teneo will automatically set EAttribute.isID()
true on any objects that have the @Id annotation set. Is that true?
Will that work if the attribute is a long instead of a String?
If so, then I don't actually have a problem at all.
Jason
Martin Taal wrote:
> Hi Jason,
> environment were the list index was also present in the db. Assume that
> the server receives the changedescription you listed below. Now between
> comes back the list has been adapted by another client then the indexes
> in the list will have changed anyway. Or do you prevent this by doing a
> version check?
> recorded as:
> </value>
> correct?
> gr. Martin
>> Hi all,
>> use it as it is.
>> </value>
>> Thanks all,
>> Jason Henriksen
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #125173 is a reply to message #125170] Fri, 06 June 2008 00:41 Go to previous messageGo to next message
Hi Jason,
Teneo does not set the EAttribute.isId for you. Also as I understand it the isId should be set on
the client and not on the server (where Teneo runs).
However, assuming that the client has the ecore with the annotations then it is very easy to set the
id of the attributes which have a @Id annotation. Just iterate over the epackages, eclasses,
eattributes, check the eannotation and if it contains @Id call eAttribute.setId(true).
gr. Martin
> important at all.
> For example:
> <attribute
> </subDiffElements>
> Jason
> Martin Taal wrote:
>> Hi Jason,
>> recorded as:
>> </value>
>> correct?
>> gr. Martin
>>> Hi all,
>>> use it as it is.
>>> </value>
>>> Thanks all,
>>> Jason Henriksen
The Netherlands
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #125253 is a reply to message #125173] Fri, 06 June 2008 13:06 Go to previous messageGo to next message
Martin Taal wrote:
> Hi Jason,
> the isId should be set on the client and not on the server (where Teneo
> runs).
Would it hurt anything if I used xsd:ID as the type for my @Id fields
and then used instance type to make the id into a long so that it
matches the database?
Unfortunately, the front end software may be run at a 3rd party company.
Therefore all database information is stripped from the XSD before it
is presented to them. However if the type is xsd:ID then it wont
matter, so long as I can make sure that Teneo doesn't get confused by that.
Jason
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #125279 is a reply to message #125253] Fri, 06 June 2008 16:10 Go to previous messageGo to next message
Hi Jason,
Afaik normally xsd:ID maps to a string in ecore but maybe using an edatatype/instanceclass would
prevent this. So yes this sounds like a good approach to me.
gr. Martin
> Martin Taal wrote:
>> Hi Jason,
>> it the isId should be set on the client and not on the server (where
>> Teneo runs).
> Jason
The Netherlands
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #125292 is a reply to message #125279] Fri, 06 June 2008 16:30 Go to previous message
Eclipse User
Jason,
Keep in mind that an ID must be an NCName so an integer is not a
conforming thing. You might create a restricted ID so that it's _
followed by digits (where the first digit can't be 0), and then map it
to a a long with a value to string conversion that eats/inserts the "_"...
Martin Taal wrote:
> Hi Jason,
> edatatype/instanceclass would prevent this. So yes this sounds like a
> gr. Martin
>> Martin Taal wrote:
>>> Hi Jason,
>>> Teneo runs).
>> company. Therefore all database information is stripped from the XSD
>> before it is presented to them. However if the type is xsd:ID then
>> it wont matter, so long as I can make sure that Teneo doesn't get
>> confused by that.
>> Jason
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #619183 is a reply to message #125164] Thu, 05 June 2008 16:53 Go to previous message
Hi Jason,
</value>
correct?
gr. Martin
> Hi all,
> it is.
> </value>
> Thanks all,
> Jason Henriksen
The Netherlands
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #619184 is a reply to message #125165] Thu, 05 June 2008 17:17 Go to previous message
Hi Martin!
Jason
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #619185 is a reply to message #125165] Thu, 05 June 2008 17:21 Go to previous message
Ed Merks is currently offline Ed Merks
Martin,
Martin Taal wrote:
> Hi Jason,
> recorded as:
> </value>
> correct?
> gr. Martin
>> Hi all,
>> use it as it is.
>> </value>
>> Thanks all,
>> Jason Henriksen
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #619186 is a reply to message #125167] Thu, 05 June 2008 17:46 Go to previous message
Hi Ed,
gr. Martin
Ed Merks wrote:
> Martin,
> Martin Taal wrote:
>> Hi Jason,
>> recorded as:
>> </value>
>> correct?
>> gr. Martin
>>> Hi all,
>>> use it as it is.
>>> </value>
>>> Thanks all,
>>> Jason Henriksen
The Netherlands
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #619187 is a reply to message #125168] Thu, 05 June 2008 18:44 Go to previous message
Martin,
Martin Taal wrote:
> Hi Ed,
> descriptors?
> gr. Martin
> Ed Merks wrote:
>> Martin,
>> Martin Taal wrote:
>>> Hi Jason,
>>> recorded as:
>>> </value>
>>> correct?
>>> gr. Martin
>>>> Hi all,
>>>> I use it as it is.
>>>> </value>
>>>> Thanks all,
>>>> Jason Henriksen
<html>
<head>
</head>
Martin,<br>
<br>
<blockquote><a
</blockquote>
<br>
<br>
Ed,
<br>
descriptors?
<br>
<br>
gr. Martin
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
Martin Taal wrote:
<br>
<br>
<br>
<br>
recorded as:
<br>
<br>
<br>
&lt;/value&gt;
<br>
<br>
<br>
correct?
<br>
<br>
<br>
<br>
gr. Martin
<br>
<br>
<br>
<br>
<br>
it is.
<br>
<br>
<br>
<br>
<br>
<br>
&lt;/value&gt;
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thanks all,
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
<br>
</body>
</html>
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #619188 is a reply to message #125165] Thu, 05 June 2008 19:06 Go to previous message
important at all.
For example:
<attribute
</subDiffElements>
Jason
Martin Taal wrote:
> Hi Jason,
> version check?
> recorded as:
> </value>
> correct?
> gr. Martin
>> Hi all,
>> use it as it is.
>> </value>
>> Thanks all,
>> Jason Henriksen
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #619191 is a reply to message #125170] Fri, 06 June 2008 00:41 Go to previous message
Hi Jason,
gr. Martin
> important at all.
> For example:
> <attribute
> </subDiffElements>
> Jason
> Martin Taal wrote:
>> Hi Jason,
>> recorded as:
>> </value>
>> correct?
>> gr. Martin
>>> Hi all,
>>> use it as it is.
>>> </value>
>>> Thanks all,
>>> Jason Henriksen
The Netherlands
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #619201 is a reply to message #125173] Fri, 06 June 2008 13:06 Go to previous message
Martin Taal wrote:
> Hi Jason,
> runs).
Jason
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #619203 is a reply to message #125253] Fri, 06 June 2008 16:10 Go to previous message
Hi Jason,
gr. Martin
> Martin Taal wrote:
>> Hi Jason,
>> Teneo runs).
> Jason
The Netherlands
Re: EMF Compare & ChangeDescription on Teneo/Database backed EMF objects [message #619204 is a reply to message #125279] Fri, 06 June 2008 16:30 Go to previous message
Jason,
Martin Taal wrote:
> Hi Jason,
> gr. Martin
>> Martin Taal wrote:
>>> Hi Jason,
>>> Teneo runs).
>> confused by that.
>> Jason
Previous Topic:[Teneo] JMX MBean and class loading issues
Next Topic:[Teneo] Can't persist reference when EOpposite is set.
Current Time: Tue Oct 08 07:54:33 EDT 2013
Powered by FUDForum. Page generated in 0.02647 seconds
