Home » Modeling » EMF » [CDO] Multi master (clone)(Changes in clone aren't synchronized in master)
[CDO] Multi master (clone) [message #923803] Wed, 26 September 2012 07:57 Go to next message
Ricky de Klerck is currently offline Ricky de KlerckFriend
I was told to ask this question on the emf forum so here it is.. I managed to create a CDO master and clone following the examples in org.eclipse.emf.cdo.examples. (I'm trying to achieve the architecture described like http://www.eclipse.org/forums/index.php/m/880089/)
I still have one problem now.. I've set up 2 clients, one connected to the master and one to the clone. When I save an object in the clone, everything is synchronized well, but the other way around (save object in master) doesn't work. The changes aren't pushed (or pulled) from master to clone. Anybody had this problem before?
Thanks in advance!
Re: [CDO] Multi master (clone) [message #923816 is a reply to message #923803] Wed, 26 September 2012 08:08 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 26.09.2012 09:57, schrieb Ricky de Klerck:
The IRepositorySynchronizer of the CloneRepository registers with the master repository, which then will push all
changes (see PassiveUpdateMode.ADDITIONS) to the registered clone. If commits to the master are not pushed to the clone
then you're either doing something wrong or there's a bug in CDO's replication mechansim. The latter is less likely (no
complaints so far and tests are all passing) but it's impossible for me to judge without more information. Maybe you can
submit a bugzilla and attach a small, *executable* example?
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Multi master (clone) [message #923993 is a reply to message #923816] Wed, 26 September 2012 11:39 Go to previous messageGo to next message
Thanks for your answer. Creating an executable example is not that easy because I now have 2 seperate clients, a clone and a master.. So before I do that, some code might do the trick. First of all, the 'PassiveUpdateMode.ADDITIONS' you mentioned is part of the client, right? The session is created and a setPassiveUpdateMode() is done?
The code of my clients is identical, only the repository is different (clone or master):
System.out.println("Client starting...");
IManagedContainer container = OfflineExampleUtil.createContainer();
IConnector connector = Net4jUtil.getConnector(container, AbstractOfflineExampleServer.TRANSPORT_TYPE, "localhost:"
	        + 2036);
CDONet4jSessionConfiguration configuration = CDONet4jUtil.createNet4jSessionConfiguration();
configuration.setConnector(connector);
configuration.setRepositoryName("cdo");
CDONet4jSession session = configuration.openNet4jSession();
session.options().setPassiveUpdateEnabled(true);
session.options().setPassiveUpdateMode(PassiveUpdateMode.ADDITIONS);
//	    session.getPackageRegistry().putEPackage(VlaamsparlementPackage.eINSTANCE);
CDORepositoryInfo repositoryInfo = session.getRepositoryInfo();
System.out.println("Connected to " + repositoryInfo.getName());
return session;
This is the code to create the master:
CDOServerUtil.createRepository(name, store, props);
And this is (some of) the code to create the clone:
CDOServerUtil.createOfflineClone(name, store, props, synchronizer);
protected IRepositorySynchronizer createRepositorySynchronizer(String connectorDescription, String repositoryName)
    CDOSessionConfigurationFactory factory = createSessionConfigurationFactory(connectorDescription, repositoryName);
    IRepositorySynchronizer synchronizer = CDOServerUtil.createRepositorySynchronizer(factory);
    synchronizer.setRetryInterval(2);
    synchronizer.setMaxRecommits(10);
    synchronizer.setRecommitInterval(2);
    synchronizer.setRawReplication(true);
    return synchronizer;
I make use of the AbstractOfflineExampleServer which is used in org.eclipse.emf.cdo.examples.
Does this help to solve the problem in any way?
[Updated on: Wed, 26 September 2012 12:08]
Report message to a moderator
Re: [CDO] Multi master (clone) [message #924802 is a reply to message #923993] Thu, 27 September 2012 06:16 Go to previous messageGo to next message
Am 26.09.2012 13:39, schrieb Ricky de Klerck:
> Thanks for your answer. To create an executable example is not that easy because I now have 2 seperate clients, a
No, in a "normal" client you don't need PassiveUpdateMode.ADDITIONS and probably shouldn't use it as it leads to
substantially more network traffic. I just mentioned it because the "client" in the RepositorySynchronizer uses this
mode to receive all changes and additions from the master:
CDOSessionConfiguration masterConfiguration = remoteSessionConfigurationFactory.createSessionConfiguration();
masterConfiguration.setPassiveUpdateMode(PassiveUpdateMode.ADDITIONS);
masterConfiguration.setLockNotificationMode(LockNotificationMode.ALWAYS);
remoteSession = (InternalCDOSession)masterConfiguration.openSession();
ensureNOOPRevisionCache();
That should be okay.
> + 2036);
The port is correct?
It's a little bit faster to set these already on the configuration used to open the session.
putEPackage() is indeed not needed anymore for generated and deployed packages with post 3.0 versions of CDO.
> return session;
That looks okay to me.
I don't think so ;-(
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #924980 is a reply to message #924802] Thu, 27 September 2012 09:30 Go to previous messageGo to next message
The ports are correct, otherwise it shouldn't synchronize the other way i suppose.
Is there a certain way a transaction should be started/commited? I now have a method to create test data like this (i deleted a whole bunch btw):
public static void createDummyData(){
	try {
		CDOTransaction transaction = cdoSession.openTransaction();
		CDOResource parlementsResource = transaction.getOrCreateResource("/parlements");
		CDOResource personsResource = transaction.getOrCreateResource("/persons");
		if(parlementsResource.getContents().size() == 0){
			Parlement parlement = VlaamsparlementFactory.eINSTANCE.createParlement();
			//SPA
			Party spa = VlaamsparlementFactory.eINSTANCE.createParty();
			spa.setName("SPA");
			spa.setAddress("test 105/37\n" +
								"1000 test");
			parlement.getParties().add(spa);
			Person vdl = VlaamsparlementFactory.eINSTANCE.createPerson();
			vdl.setFirstName("Jan");
			vdl.setLastName("Achternaam");
			vdl.setGender(Genders.MALE);
			vdl.setDateOfBirth(new Date());
			spa.getPersons().add(vdl);
			Person li = VlaamsparlementFactory.eINSTANCE.createPerson();
			li.setFirstName("Lotte");
			li.setLastName("Achternaam");
			li.setGender(Genders.FEMALE);
			li.setDateOfBirth(new Date());
			spa.getPersons().add(li);
			spa.setLeader(vdl);
                        parlementsResource.getContents().add(parlement);
			personsResource.getContents().add(vdl);
			personsResource.getContents().add(li);
			transaction.commit();
		transaction.close();
	} catch (CommitException e) {
		e.printStackTrace();
Is this the correct way? After the commit (client connected to master), it should be synchronized with the clone database, right?
Re: [CDO] Multi master (clone) [message #925095 is a reply to message #924980] Thu, 27 September 2012 11:15 Go to previous messageGo to next message
Am 27.09.2012 11:30, schrieb Ricky de Klerck:
> try {
> //SPA
> spa.setName("SPA");
> "1000 test");
> spa.setLeader(vdl);
Looks okay to me. As you don't use explicit write locks for your modifications I suggest to synchronize the entire try
block on the used transaction. Another enhancement would be to repeat that block until there's no CommitException anymore.
Yes, that should happen. And it does in our offline test suite, which I just double checked.
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #925177 is a reply to message #925095] Thu, 27 September 2012 13:05 Go to previous messageGo to next message
And where can I find the offline test suite? I'm getting the feeling I'm viewing different code. I just installed the CDO repository examples..
Re: [CDO] Multi master (clone) [message #925229 is a reply to message #925095] Thu, 27 September 2012 14:10 Go to previous messageGo to next message
Ok, i did a little test with the testsuite from org.eclipse.emf.cdo.examples (grabbed the source from http://git.eclipse.org/c/cdo/cdo.git/tree/plugins/org.eclipse.emf.cdo.examples/src/org/eclipse/emf/cdo/examples/server/offline). I tested it with mysql databases so this is the code I changed:
com.mysql.jdbc.jdbc2.optional.MysqlDataSource ds = new com.mysql.jdbc.jdbc2.optional.MysqlDataSource();
ds.setUrl("jdbc:mysql://localhost/" + name);
ds.setUser("cdo");
ds.setPassword("cdo");
IMappingStrategy mappingStrategy = CDODBUtil.createHorizontalMappingStrategy(true, true);
IDBAdapter dbAdapter = new MYSQLAdapter();
IDBConnectionProvider dbConnectionProvider = DBUtil.createConnectionProvider(ds);
return CDODBUtil.createStore(mappingStrategy, dbAdapter, dbConnectionProvider);
//JdbcDataSource dataSource = new JdbcDataSource();
//dataSource.setURL("jdbc:h2:database/" + name);
//IMappingStrategy mappingStrategy = CDODBUtil.createHorizontalMappingStrategy(true, true);
//IDBAdapter dbAdapter = new H2Adapter();
//IDBConnectionProvider dbConnectionProvider = DBUtil.createConnectionProvider(dataSource);
//return CDODBUtil.createStore(mappingStrategy, dbAdapter, dbConnectionProvider);
Test 1:
- removed all tables from both databases (clone and master)
- started master (all tables are created)
- started clone (all tables are created)
- started client (CONNECTED TO CLONE)
- added object via client
- object is added in both databases
- Result: OK
Test 2:
- started client (CONNECTED TO MASTER)
- object is only added in master database
- Result: NOT OK
[Updated on: Thu, 27 September 2012 14:11]
Re: [CDO] Multi master (clone) [message #925898 is a reply to message #925177] Fri, 28 September 2012 05:48 Go to previous messageGo to next message
Am 27.09.2012 15:05, schrieb Ricky de Klerck:
Install the "CDO Model Repository Tests" feature from http://www.eclipse.org/cdo/downloads or checkout the sources of
the various test plugins from Git. The suites ship with launch configs.
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #926050 is a reply to message #925898] Fri, 28 September 2012 08:59 Go to previous messageGo to next message
I installed the "CDO Model Repository Tests" feature and configured it to work with my mysql database, but the test i described earlier still doesn't work. In the ExampleClient I started a CDO session to my MASTER and opened a transaction. In this transaction, I create a resource and add a Category object.
After the save the object is stored in the MASTER database but not in the CLONE. The other way around (client connected to clone) works fine.. Is this the exact scenario you tested? (except mysql database)
Re: [CDO] Multi master (clone) [message #926062 is a reply to message #926050] Fri, 28 September 2012 09:11 Go to previous messageGo to next message
Am 28.09.2012 10:59, schrieb Ricky de Klerck:
Yes: org.eclipse.emf.cdo.tests.offline.OfflineTest.testMasterCommits_ArrivalInClone()
In the 4.2 branch (Git "master") I experience a problem with the root resource ID which I need to analyze/fix. But I
doubt that it's related to your problem. What CDO version are you using?
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #926068 is a reply to message #926062] Fri, 28 September 2012 09:18 Go to previous messageGo to next message
I'm using CDO version 4.1.0
Re: [CDO] Multi master (clone) [message #926317 is a reply to message #925229] Fri, 28 September 2012 14:23 Go to previous messageGo to next message
Am 27.09.2012 16:10, schrieb Ricky de Klerck:
> ds.setUser("cdo");
> Test 1:
> - Result: OK
> Test 2:
> - Result: NOT OK
I've tried both things and many others in both CDO branches 4.2 integartion and 4.1 maintenance. It works perfectly with
H2. Have you tried it with H2?
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #926998 is a reply to message #925229] Sat, 29 September 2012 06:26 Go to previous messageGo to next message
> Ok, i did a little test with the testsuite from org.eclipse.emf.cdo.examples (grabbed the source fromhttp://git.eclipse.org/c/cdo/cdo.git/tree/plugins/org.eclipse.emf.cdo.examples/src/org/eclipse/emf/cdo/examples/server/offline). I tested it with mysql databases so this is the code I changed:
> ds.setUser("cdo");
I remember a challenge with Mysql and CDO's client-assigned IDs: UUIDs tend to contain alpha-numrical characters and
Mysql creates case-insensitive String columns in tables by default. You must change that manually in all tables (or
subclass MysqlAdapter).
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #929149 is a reply to message #926998] Mon, 01 October 2012 09:00 Go to previous messageGo to next message
I've tried it in both mysql and h2.. still no luck. I now installed cdo 4.2.0, but this has the same results. I added a picture of my installed software, maybe you see a wrong version number here..
Installed software:
index.php/fa/11672/0/
Re: [CDO] Multi master (clone) [message #929180 is a reply to message #929149] Mon, 01 October 2012 09:22 Go to previous messageGo to next message
Am 01.10.2012 11:00, schrieb Ricky de Klerck:
Looks like yesterday's I-build and that should be okay. I'm not sure about the "Eclipse for RCP and RAP Developers
1.5.1", though. Have you tried with a normal (classic) SDK?
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #929223 is a reply to message #929180] Mon, 01 October 2012 09:53 Go to previous messageGo to next message
Installed eclipse classic and necessary plugin but still no luck.
index.php/fa/11673/0/
Did you also tried it with the client and checked the result or only with the testcase?
Re: [CDO] Multi master (clone) [message #929230 is a reply to message #929223] Mon, 01 October 2012 09:55 Go to previous messageGo to next message
Am 01.10.2012 11:53, schrieb Ricky de Klerck:
Both. And in both branches.
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #929290 is a reply to message #929230] Mon, 01 October 2012 10:52 Go to previous messageGo to next message
Can you please describe the steps you did to do the test?
On the moment I start the test, only CDO tables are present in the master/clone.. When I add an object in the master, the tables from the EMF package are created (in the master). Is this also the case with your test?
Re: [CDO] Multi master (clone) [message #929298 is a reply to message #929290] Mon, 01 October 2012 10:58 Go to previous messageGo to next message
Am 01.10.2012 12:52, schrieb Ricky de Klerck:
Test 1:
- Result: OK
Test 2:
- Result: OK
I didn't check but without them the test would not pass, right?
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #929310 is a reply to message #929298] Mon, 01 October 2012 11:06 Go to previous messageGo to next message
No you are right.. I have no clue what's wrong.
Re: [CDO] Multi master (clone) [message #929322 is a reply to message #929310] Mon, 01 October 2012 11:15 Go to previous messageGo to next message
Am 01.10.2012 13:06, schrieb Ricky de Klerck:
That's odd, but without the ability to reproduce your problem I can't help ;-(
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #929407 is a reply to message #929322] Mon, 01 October 2012 12:38 Go to previous messageGo to next message
I understand, I'm really happy with the effort you did to help me so far.
One question, my tables in the master database have different names than the one in my clone database, is this correct?
Example:
COMPANY_CATEGORY (master database)
CATEGORY (clone database)
Re: [CDO] Multi master (clone) [message #929420 is a reply to message #929407] Mon, 01 October 2012 12:51 Go to previous messageGo to next message
Am 01.10.2012 14:38, schrieb Ricky de Klerck:
> Example:
That IS a problem! Please make sure that both your repositories use the same value for the "qualifiedNames" property in:
<cdoServer>
<repository>
<store type="db">
<mappingStrategy type="horizontal">
<property name="qualifiedNames" value="???"/>
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #929430 is a reply to message #929420] Mon, 01 October 2012 13:04 Go to previous messageGo to next message
Thought it worked, but it didn't (did a wrong test i guess). Table names are equal now, though..
[Updated on: Mon, 01 October 2012 13:52]
Re: [CDO] Multi master (clone) [message #929540 is a reply to message #929430] Mon, 01 October 2012 14:50 Go to previous messageGo to next message
Am 01.10.2012 15:04, schrieb Ricky de Klerck:
> Finally! That did the trick. I didn't have this line in my clone configuration:
> Map<String, String> props = new HashMap<String, String>();
> props.put(IMappingStrategy.PROP_QUALIFIED_NAMES, "true");
> mappingStrategy.setProperties(props);
Good that it works now.
> But how can it be that this line isn't in the examples? I dubble checked but it isn't there (file - new - Clone server
> example). So the example you ran didn't have this line of code, but still worked?
Hmm, I used these classes directly from my development IDE:
/org.eclipse.emf.cdo.examples/src/org/eclipse/emf/cdo/examples/server/offline/OfflineExampleClone.java
/org.eclipse.emf.cdo.examples/src/org/eclipse/emf/cdo/examples/server/offline/OfflineExampleMaster.java
That might at least explain why we had different results.
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #929558 is a reply to message #929540] Mon, 01 October 2012 15:06 Go to previous messageGo to next message
I allready changed my post. It still doesn't work, I suppose I ran a wrong test..
Could please send (or attach) the 3 files you used? So I'm a 100% sure we have the same code.. (OfflineExampleClone, OfflineExampleMaster, AbstractOfflineExampleServer)
Re: [CDO] Multi master (clone) [message #929574 is a reply to message #929558] Mon, 01 October 2012 15:20 Go to previous messageGo to next message
Am 01.10.2012 17:06, schrieb Ricky de Klerck:
They're here:
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #931687 is a reply to message #929574] Wed, 03 October 2012 12:31 Go to previous messageGo to next message
Eike,
Thanks again for the quick reply. We managed to get our tests to work with the new files you gave me. We musst have had the wrong files after all..
We're now testing the capabilities of the offline clone, but we're having some trouble right from the start..
Our test:
- start master on pc 1
- start clone on pc 2
- start clone on pc 3
- start client connected to clone on pc 2
- start client connected to clone on pc 3
- create resource on pc 2
- create object and save on pc 2
(so far, so good: everything is synchronized)
- disconnect pc 2 from network
- (timeout exception occurs here)
- connect pc 2 to network
Result:
- new object visible in master database
- new object visible in clone database on pc 3
- new object not visible in clone database on pc 2
So it looks like the commit is done when the connecting is back, but the clone (pc 2) isn't synchronized. Any idea what the problem is? I suppose this test should work..
Re: [CDO] Multi master (clone) [message #932915 is a reply to message #931687] Thu, 04 October 2012 15:04 Go to previous messageGo to next message
Am 03.10.2012 14:31, schrieb Ricky de Klerck:
> Eike,
> Our test:
> Result:
I think it should. Unfortunately I see not much in your description that could help me to get an idea about the cause
for your problem. Repository replication is one of the most complex setups in CDO. Doesn't the debugger help you to get
more details about the problem? Are there any exceptions?
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #936833 is a reply to message #932915] Mon, 08 October 2012 11:31 Go to previous messageGo to next message
I'm getting a timeout exception in my clone when I'm trying to save (network disconnected). After this exception the state changes to offline. In my client I'm receiving a classnotfoundexception (TransportException). Could one of the exceptions prevent the synchronizer from synchronize?
The normal way is that it keeps trying to commit till the connection is back online?
Re: [CDO] Multi master (clone) [message #936945 is a reply to message #936833] Mon, 08 October 2012 14:00 Go to previous messageGo to next message
Am 08.10.2012 13:31, schrieb Ricky de Klerck:
What exactly are these exceptions? Stack traces?
The client or the clone?
The clone doesn't commit to the master by itself. It continuously tries to connect to the master in order to receive
replication updates.
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #936964 is a reply to message #936945] Mon, 08 October 2012 14:25 Go to previous messageGo to next message
Yes they are stack traces. But what about the classnotfound exception?
Well, I assume the client? But, is it possible to keep working on the client (clone) when connection is lost? Now it looks like, the program is freezed, untill connection is restored?
> The clone doesn't commit to the master by itself. It continuously tries to connect > to the master in order to receive
Ok, that's clear.
Re: [CDO] Multi master (clone) [message #936987 is a reply to message #936964] Mon, 08 October 2012 14:43 Go to previous messageGo to next message
Am 08.10.2012 16:25, schrieb Ricky de Klerck:
I know. Most of the time exceptions have stack traces. It's just incomprehensible to me why I'm supposed to guess how
they look like in order to help with your problem.
They can harm. The stack traces would help to judge that. Normally they indicate that a needed bundle is not properly
activated.
Yes, that's the whole point of the offline clones. Of course not all functionality can work in oflline state. But the
fundamental functionality is available, including the abilities to read the entire object graph and commit changes.
If something appears frozen it's best to suspend the main thread in the debugger and find out what it's doing / waiting for.
Cheers
/Eike
>> receive replication updates.
> Ok, that's clear.
Re: [CDO] Multi master (clone) [message #937695 is a reply to message #936987] Tue, 09 October 2012 07:27 Go to previous messageGo to next message
This is a part of the stack trace (I'm getting this in the client, if I save when network is disconnected):
!ENTRY org.eclipse.net4j.util 4 0 2012-10-09 09:23:25.644
!MESSAGE org.eclipse.emf.cdo.common.util.TransportException
!STACK 0
java.lang.ClassNotFoundException: org.eclipse.emf.cdo.common.util.TransportException
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	at org.eclipse.net4j.util.io.ExtendedIOUtil$ClassLoaderClassResolver.resolveClass(ExtendedIOUtil.java:284)
	at org.eclipse.net4j.util.io.ExtendedIOUtil$3.resolveClass(ExtendedIOUtil.java:147)
	at java.io.ObjectInputStream.readNonProxyDesc(Unknown Source)
	at java.io.ObjectInputStream.readClassDesc(Unknown Source)
	at java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
	at java.io.ObjectInputStream.readObject0(Unknown Source)
	at java.io.ObjectInputStream.readObject(Unknown Source)
	at org.eclipse.net4j.util.io.ExtendedIOUtil.readObject(ExtendedIOUtil.java:161)
	at org.eclipse.net4j.util.io.ExtendedIOUtil.readObject(ExtendedIOUtil.java:115)
	at org.eclipse.net4j.signal.RemoteExceptionIndication.deserializeThrowable(RemoteExceptionIndication.java:76)
	at org.eclipse.net4j.signal.RemoteExceptionIndication.indicating(RemoteExceptionIndication.java:51)
	at org.eclipse.net4j.signal.Indication.doExtendedInput(Indication.java:57)
	at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
	at org.eclipse.net4j.signal.Indication.execute(Indication.java:51)
	at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
	at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
[ERROR] org.eclipse.emf.cdo.common.util.CDOException
java.lang.ClassNotFoundException: org.eclipse.emf.cdo.common.util.CDOException
!ENTRY org.eclipse.net4j.util 4 0 2012-10-09 09:23:25.664
!MESSAGE org.eclipse.emf.cdo.common.util.CDOException
!STACK 0
[ERROR] org.eclipse.emf.cdo.common.util.TransportException
	at java.lang.Class.forName0(Native Method)
	at java.lang.Class.forName(Unknown Source)
	at java.io.ObjectInputStream.resolveClass(Unknown Source)
	at org.eclipse.net4j.util.io.ExtendedIOUtil$3.resolveClass(ExtendedIOUtil.java:154)
I tried adding org.eclipse.emf.cdo.common.util to the list of dependencies, but I can't find it! Has this something to do with the version of CDO I'm using (4.2)?
Re: [CDO] Multi master (clone) [message #937731 is a reply to message #937695] Tue, 09 October 2012 08:06 Go to previous messageGo to next message
Am 09.10.2012 09:27, schrieb Ricky de Klerck:
> !STACK 0
> at java.lang.ClassLoader.loadClass(Unknown Source)
So the root cause is an exception on the server. The effect you're seeing is that this exception can not be deserialized
by the client, which, by itself, is not much of a problem because the root cause exception message and stack trace are
additionally transfered in text form, too.
I suggest that we first focus on the root cause exception on the server and then decide whether we want/can correctly
transfer it to the client by adding an Eclipse-Buddy registration to the bundle that contains the exception class (for
future debugging).
> !STACK 0
That's a package and it's contained by a bundle that's on the class path anyway. So PDE likely filters it from the
selection list.
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #937742 is a reply to message #937731] Tue, 09 October 2012 08:15 Go to previous messageGo to next message
Well, the plugin org.eclipse.emf.cdo.common is selected in the run configuration. I suppose the package should be in there..
When I do the same test with the example client it allso freezes and after a few seconds it asks if I want to retry or abort the operation.. I cannot do anything else at that moment.
Re: [CDO] Multi master (clone) [message #937775 is a reply to message #937742] Tue, 09 October 2012 08:44 Go to previous messageGo to next message
Am 09.10.2012 10:15, schrieb Ricky de Klerck:
> there..
I plan to spend some time on testing the offline replication mechanism. Hopefully by end of this week. But I can not
promise it 100%.
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #937781 is a reply to message #937775] Tue, 09 October 2012 08:53 Go to previous messageGo to next message
Ok, looking forward to here from you.
Re: [CDO] Multi master (clone) [message #937824 is a reply to message #937775] Tue, 09 October 2012 09:49 Go to previous messageGo to next message
I might have some more observations which will help to solve the problem..
This is what I did:
- start master (pc 1)
- start clone (pc 2)
- start client connected to clone which inserts dummy data
- stop client
- disconnected pc 2 from network
- start client connected to clone (data already present)
- change name one object: app freezes for a few seconds, nothing is changed in database
- change name other object: changes are applied in database, and also the previous change is applied!
- connected pc 2 to network
- result: nothing is changed in master database
Re: [CDO] Multi master (clone) [message #938005 is a reply to message #937824] Tue, 09 October 2012 13:13 Go to previous messageGo to next message
It seems like the state of the clone isn't set to OFFLINE when connection is lost.. Therefore an exception occurs. After this exception the state changes to OFFLINE but this is too late (or the commit/save should be done again).
Re: [CDO] Multi master (clone) [message #944998 is a reply to message #937775] Mon, 15 October 2012 07:37 Go to previous messageGo to next message
Eike Stepper wrote on Tue, 09 October 2012 04:44
> there..
promise it 100%.
Eike, any progress on this?
Re: [CDO] Multi master (clone) [message #945051 is a reply to message #944998] Mon, 15 October 2012 08:04 Go to previous messageGo to next message
Am 15.10.2012 09:37, schrieb Ricky de Klerck:
>> in > there..
>> or > abort the operation.. I cannot do anything else at that moment.
>> promise it 100%.
No, I'm sorry! And it seems more and more unlikely that I manage to get at this before end of the EclipseCon next week.
Still these possible issues with the offline mode are very high on my list.
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #983300 is a reply to message #945051] Tue, 13 November 2012 20:57 Go to previous messageGo to next message
I'm curious if you already had the time for this issue?
Ricky
Re: [CDO] Multi master (clone) [message #985166 is a reply to message #983300] Thu, 15 November 2012 07:46 Go to previous messageGo to next message
Am 13.11.2012 21:57, schrieb Ricky de Klerck:
Yes. I have been distracted for a couple days, though.
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #986293 is a reply to message #937781] Mon, 19 November 2012 18:31 Go to previous messageGo to next message
Am 09.10.2012 10:53, schrieb Ricky de Klerck:
It took me a bit longer but now it's available. I show a demo in
http://thegordian.blogspot.de/2012/11/use-online-data-offline.html
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #990397 is a reply to message #986293] Wed, 12 December 2012 09:56 Go to previous messageGo to next message
I really appreciate the effort you put into this! The result is amazing and we're definitely going to use this in our applications.
Re: [CDO] Multi master (clone) [message #990704 is a reply to message #990397] Thu, 13 December 2012 05:56 Go to previous messageGo to next message
Am 12.12.2012 10:56, schrieb Ricky de Klerck:
> applications.
Excellent. Nice to hear that the effort was worth it ;-)
Cheers
/Eike
Re: [CDO] Multi master (clone) [message #990791 is a reply to message #990704] Fri, 14 December 2012 09:57 Go to previous messageGo to next message
Eike,
We found a problem in the 'org.eclipse.emf.cdo.server.db' plugin. In a few classes, for example 'AbstractHorizontalMappingStrategy', double quotes were added to the table alias. We've tested it with MySQL version 5.5.25, but it doesn't work because of these quotes.. the MySQL syntax won't accept it. When I remove the quotes, everything works fine again. But you must have added them for a reason, because they weren't there in the previous version..
Ricky de Klerck
Re: [CDO] Multi master (clone) [message #990811 is a reply to message #990791] Fri, 14 December 2012 10:44 Go to previous message
Am 14.12.2012 10:57, schrieb Ricky de Klerck:
> Eike,
> version..
That has been reverted already. Please use a newer drop. If the problem is still there, please submit a bugzilla and
tell us exactly where you've found the quotes.
Cheers
/Eike
Previous Topic:[CDO] NPE at CDOObjectHistoryImpl.filter(CDOObjectHistoryImpl.java:58)
Next Topic:generate genmodel from schema xml
Current Time: Wed Jun 20 21:28:40 GMT 2018
Powered by FUDForum. Page generated in 0.03463 seconds
