Home » Modeling » TMF (Xtext) » Extend xtend with more extension methods
Extend xtend with more extension methods [message #922052] Mon, 24 September 2012 17:34 Go to next message
Hallvard Traetteberg is currently offline Hallvard TraettebergFriend
I'm generating code with xtend2 and wonder if I could make the code
nicer by defining some extra operator_doubleArrow method, so the =>
operator can be used with an ITreeAppendable on the left hand side.
E.g. instead of append("something") newLine // it is an ITreeAppendable
I could write it => "something" => '\n'
Is it possible to add such extra methods without rebuilding xtend2? E.g.
by defining an extension class in your xtext project and using some
extension point, thus extending xtend?
Hallvard
Re: Extend xtend with more extension methods [message #922235 is a reply to message #922052] Mon, 24 September 2012 21:23 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
You can define a class with a method
operator_doubleArrow(ITreeAppendable, CharSequence) and use that one as
an extension, e.g.
extension MyTreeAppendableUtil
That should do the trick. No recompilation, no altering of the language,
just a library / an API in your project
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 24.09.12 19:34, schrieb Hallvard Trætteberg:
> Hallvard
Re: Extend xtend with more extension methods [message #923018 is a reply to message #922235] Tue, 25 September 2012 14:42 Go to previous messageGo to next message
Aaron Digulla is currently offline Aaron DigullaFriend
I suggest to use the left-shift operator, though:
out << "something" << '\n'
This is used by most other languages and shows the intent better (if you forget for a moment that it also means "shift") since it "points" the data into the right direction.
[Updated on: Tue, 25 September 2012 14:43]
Report message to a moderator
Re: Extend xtend with more extension methods [message #925330 is a reply to message #923018] Thu, 27 September 2012 16:10 Go to previous messageGo to next message
> is used my most other languages and shows the intent better (if you
Yes, I came to the same conclusion after looking at the available
operators. I now use the following extension class. Note how the injects
allow serialization of expressions and types.
BTW, I also tried to use operators (extension methods) for higher order
functions like filter, map and reduce, but it seemed the type inference
had problems with the Procedure sublasses and their extensive use of
type parameters.
Hallvard
----8<-----------------------------
package org.ptolemy.xtext.generator;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.xtext.common.types.JvmTypeReference;
import org.eclipse.xtext.xbase.XExpression;
import org.eclipse.xtext.xbase.compiler.TypeReferenceSerializer;
import org.eclipse.xtext.xbase.compiler.XbaseCompiler;
import org.eclipse.xtext.xbase.compiler.output.ITreeAppendable;
import org.eclipse.xtext.xbase.lib.Inline;
import org.eclipse.xtext.xbase.lib.IterableExtensions;
import org.eclipse.xtext.xbase.lib.Pair;
import org.eclipse.xtext.xbase.lib.Functions.Function1;
import org.eclipse.xtext.xbase.lib.Functions.Function2;
import org.eclipse.xtext.xbase.lib.Procedures.Procedure1;
import org.eclipse.xtext.xbase.lib.internal.BooleanFunctionDelegate;
import org.eclipse.xtext.xbase.lib.internal.FunctionDelegate;
import com.google.common.collect.Iterables;
import com.google.inject.Inject;
public class TreeAppendableUtil {
@Inject private XbaseCompiler xbaseCompiler;
@Inject private TypeReferenceSerializer typeReferenceSerializer;
public ITreeAppendable operator_doubleLessThan(ITreeAppendable
appendable, CharSequence content) {
if (content.length() > 0) {
preAppend(appendable, content.charAt(0));
appendable.append(content);
postAppend(appendable, content.charAt(content.length() - 1));
return appendable;
public Pair<ITreeAppendable,? extends EObject>
operator_doubleLessThan(Pair<ITreeAppendable,? extends EObject>
operator_doubleLessThan(appendable.getKey(), content);
return appendable;
public ITreeAppendable preAppend(ITreeAppendable appendable, char c) {
switch (c) {
case '}': {
appendable.decreaseIndentation(); appendable.newLine(); break;
return appendable;
public ITreeAppendable postAppend(ITreeAppendable appendable, char c) {
switch (c) {
case '\n': {
case '{': {
appendable.increaseIndentation(); appendable.newLine(); break;
case ';': {
case '}': {
return appendable;
preAppend(appendable, c);
appendable.append(String.valueOf(c));
postAppend(appendable, c);
return appendable;
operator_doubleLessThan(appendable.getKey(), c);
return appendable;
appendable, XExpression expression) {
xbaseCompiler.toJavaExpression(expression, appendable);
return appendable;
operator_doubleLessThan(appendable.getKey(), expression);
return appendable;
appendable, JvmTypeReference type) {
typeReferenceSerializer.serialize(type, appendable.getValue(),
appendable.getKey());
return appendable;
Re: Extend xtend with more extension methods [message #927674 is a reply to message #925330] Sat, 29 September 2012 23:19 Go to previous message
Hi Hallvard,
please file tickets with your findings about Procedures, their type
arguments and the type inferrence.
Sebastian
Am 27.09.12 09:12, schrieb Hallvard Trætteberg:
> type parameters.
> Hallvard
> return appendable;
> return appendable;
> switch (c) {
> case '}': {
> break;
> return appendable;
> c) {
> switch (c) {
> case '\n': {
> case '{': {
> break;
> case ';': {
> case '}': {
> return appendable;
> return appendable;
> return appendable;
> return appendable;
> return appendable;
> return appendable;
Previous Topic:multiple DSLs, one Xtext project
Next Topic:parsed CompleteOCL file doesn't resolve cross reference to the ecore referenced file
Current Time: Fri Jun 22 00:13:56 GMT 2018
Powered by FUDForum. Page generated in 0.03225 seconds
