Home » Eclipse Projects » Sapphire » Horizontally aligned checkboxes
Horizontally aligned checkboxes [message #920247] Sat, 22 September 2012 22:25 Go to next message
Uli B is currently offline Uli BFriend
how can I achieve horizontally aligned checkboxes?
I tried with Split Form/Blocks and also with Related Content, but with these I cannot get fix or minimum distance between the fields.
Is there a better way?
Re: Horizontally aligned checkboxes [message #922075 is a reply to message #920247] Mon, 24 September 2012 18:08 Go to previous message
Konstantin Komissarchik is currently offline Konstantin KomissarchikFriend
If I understood your question, this is currently not possible. The ultimate intent for the split form is to support more control (like min width and no resize). Could you open an enhancement request to document your scenario? Make sure to provide as much detail as possible regarding what you are not able to achieve. The description in this post is a little sparse.
- Konstantin
Previous Topic:Resource class not found while exporting plugin using ant
Next Topic:Sapphire at GitHub
Current Time: Wed Mar 21 05:27:15 GMT 2018
Powered by FUDForum. Page generated in 0.01753 seconds
