| Can't open Eclipse Juno [message #919183] |
Fri, 21 September 2012 15:16  |
Crystal Pavis Messages: 4 Registered: September 2012 |
Junior Member |
I can't get Eclipse Juno to open.
Here is my eclipse.ini file
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20120522-1813
-product
org.eclipse.epp.package.jee.product
--launcher.defaultAction
openFile
--launcher.XXMaxPermSize
256M
-showsplash
org.eclipse.platform
256m
openFile
-vm
C:\Java\jre6\bin\javaw.exe
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Dhelp.lucene.tokenizer=standard
-Xms40m
-Xmx512m
When trying to open Eclipse it says:
An error has occurred see log..
The log says:
!SESSION 2012-09-21 15:10:42.111 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_34
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
!ENTRY org.eclipse.osgi 4 0 2012-09-21 15:10:42.611
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
I appreciate your help!
~Crystal
| Re: Can't open Eclipse Juno [message #922147 is a reply to message #922032] |
Mon, 24 September 2012 15:44  |
Junior Member |
Thanks for your suggestion. I had also seen that on StackOverflow before I posted here. I had tried it by pasting
Dosgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@
to the bottom of the eclipse.ini file and I receive this error:
Could not find the main class:
Program will exit.
When I close that I get a popup that says
Java was started but returned exit code=1
C:\Java\jre\bin\javaw.exe
and more text but I can't copy and paste it.
So I pointed it to a different JDK I have on my computer and it went back to the original error message:
[Updated on: Mon, 24 September 2012 15:57] Report message to a moderator
FUDForum. Page generated in 0.01947 seconds
