I once spent a long coffee break at JAX London with some Aries committers trying to get Aries running under Virgo and we didn't manage to crack it, so I suspect it would take quite a bit of work.
Note that Gemini Blueprint is a superset of Spring DM 2.0 function, so if Camel used to work with Spring DM, then it might be possible to get it working with Gemini Blueprint via the Spring DM support in Gemini Blueprint. It doesn't sound hopeful though.
I wonder what Camel does to tie itself to the Aries implementation of Blueprint?
