Home » Eclipse Projects » Virgo » Bundlor: No value found for placeholder 'xy'
Bundlor: No value found for placeholder 'xy' [message #913583] Sat, 15 September 2012 23:38 Go to next message
Jean-Pierre Bergamin is currently offline Jean-Pierre BergaminFriend
Member
Hello everyone
I'm trying to get our multi module maven project up and running on STS 3.0 with Virgo 3.5 and Bundlor 1.1.1.
When I'm trying to generate the MANIFEST.MF file by right clicking a project and choosing "Virgo > Run Generation of MANIFEST.MF File", nothing happens and the following error shows up in the error log (with different values for the placeholder):
java.lang.RuntimeException: No value found for placeholder 'spring.version'
	at org.eclipse.virgo.util.common.PropertyPlaceholderResolver.resolve(PropertyPlaceholderResolver.java:117)
	at org.eclipse.virgo.util.common.PropertyPlaceholderResolver.resolve(PropertyPlaceholderResolver.java:129)
	at org.eclipse.virgo.util.common.PropertyPlaceholderResolver.resolveProperty(PropertyPlaceholderResolver.java:109)
	at org.eclipse.virgo.util.common.PropertyPlaceholderResolver.resolve(PropertyPlaceholderResolver.java:102)
	at org.eclipse.virgo.bundlor.support.propertysubstitution.PlaceholderManifestAndTemplateModifier.modify(PlaceholderManifestAndTemplateModifier.java:50)
	at org.eclipse.virgo.bundlor.support.StandardManifestGenerator.generate(StandardManifestGenerator.java:49)
	at org.eclipse.virgo.ide.bundlor.internal.core.BundlorProjectBuilder.generateManifest(BundlorProjectBuilder.java:549)
	at org.eclipse.virgo.ide.bundlor.internal.core.BundlorProjectBuilder.build(BundlorProjectBuilder.java:220)
	at org.eclipse.virgo.ide.bundlor.internal.core.BundlorProjectBuilder.build(BundlorProjectBuilder.java:154)
	at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:321)
	at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:396)
	at org.eclipse.core.internal.resources.Project$1.run(Project.java:618)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
	at org.eclipse.core.internal.resources.Project.internalBuild(Project.java:597)
	at org.eclipse.core.internal.resources.Project.build(Project.java:124)
	at org.eclipse.virgo.ide.bundlor.ui.BundlorUiPlugin$RunBundlorJob.run(BundlorUiPlugin.java:99)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
We are using maven properties in our template.mf files like:
org.springframework.*;version="[${spring.version}, ${spring.version}]"
Those version properties (e.g. "spring.version") are defined in the top level maven project, but seem not to be found. The same setup worked with STS 2.7, the old Spring DM tooling and Bundlor 1.0.0.
Any chances to fix this on our side of is this a bug of the new tooling?
James
Re: Bundlor: No value found for placeholder 'xy' [message #916850 is a reply to message #913583] Wed, 19 September 2012 14:53 Go to previous messageGo to next message
Glyn Normington is currently offline Glyn NormingtonFriend
I'm not sure whether anyone answered any of the duplicated threads. It's probably best to capture that problem in a bugzilla with some simple setup to reproduce.
Re: Bundlor: No value found for placeholder 'xy' [message #940669 is a reply to message #916850] Thu, 11 October 2012 21:37 Go to previous messageGo to next message
Member
I opened a ticket for this: https://bugs.eclipse.org/bugs/show_bug.cgi?id=391725
This sample project shows this behaviour: https://bitbucket.org/ractive/virgo-tools-bug
Re: Bundlor: No value found for placeholder 'xy' [message #940769 is a reply to message #940669] Fri, 12 October 2012 00:09 Go to previous message
Thanks for capturing the bug.
Previous Topic: Virgo Tomcat Server 3.5.0 repository host returns 404
Next Topic:Can you describe how you are using Virgo?
Current Time: Tue Feb 20 23:51:09 GMT 2018
Powered by FUDForum. Page generated in 0.01637 seconds
