Home » Eclipse Projects » Remote Application Platform (RAP) » Widget ID's for composites(Would like ID for testing using selenium)
Widget ID's for composites [message #912614] Thu, 13 September 2012 21:20 Go to next message
George R Malary is currently offline George R MalaryFriend
Member
Just a general question, I know we have WidgetId's for most widgets, but there are certain things that we cannot assign id's to.
For selenium testing, we identify UI objects using these unique id's. Would there be a way to assing an id to a Composite itself? This would make most things much easier to find, as we wrap everything up in Composites anyway. I see though firebug that all composites are assigned an random id anyway, "w78xxxx".
Just a thought, that would solve some of our issues where we have to navigate the DOM to find widgets.
Re: Widget ID's for composites [message #912761 is a reply to message #912614] Fri, 14 September 2012 06:06 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
I think that you can assign a custom id to the Composites in the same
way. Composite is just a widget like all others.
composite.setData( WidgetUtil.CUSTOM_WIDGET_ID, "myCustomId" );
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Widget ID's for composites [message #913048 is a reply to message #912761] Fri, 14 September 2012 17:01 Go to previous message
Member
Thank you very much. I could have sworn I tried this before, and it didnt work. I just may be going crazy. Worked perfectly.
Only remaining annoyance is getting rows in a table, but I believe there is an issue open for that, where each row would get assigned some id based on row number.
Thanks again.
Previous Topic:Showing columns sortable, and highlighting current column that is sorted
Next Topic:CSS + Markup support for TreeItem
Current Time: Sun Feb 18 22:37:39 GMT 2018
Powered by FUDForum. Page generated in 0.01876 seconds
