Home » Newcomers » Newcomers » 'Indexing Help...' Has encountered a problem(This message is displyaed each time I start up or search help in Indigo)
icon5.gif  'Indexing Help...' Has encountered a problem [message #911105] Tue, 11 September 2012 01:35 Go to next message
Denver Jeans is currently offline Denver JeansFriend
Each time I start up Eclipse or click on Search in help I get the following message.
'Indexing Help...' Has encountered a problem.
Error while Indexing
Details:
Error while indexing
invalid format:
When going ahead and doing the search, I get the following message.
'Local Help' has encountered a problem.
An internal error occured during: "Local Help".
Details:
An internal error occurred during: "Local Help".
invalid format:
I am a fairly new Eclipse and linux user but slowly getting to know my way around. I have tried to find answers in the forums and general google but haven't come up with anything.
Where should I start looking for list of files it is trying to index so that I can see which one is of the wrong format? How can I get it to rebuild indexes?
Re: 'Indexing Help...' Has encountered a problem [message #946698 is a reply to message #911105] Tue, 16 October 2012 12:19 Go to previous messageGo to next message
Bert IJff is currently offline Bert IJffFriend
I have the same problem and have not found a solution either
Re: 'Indexing Help...' Has encountered a problem [message #986428 is a reply to message #911105] Tue, 20 November 2012 11:55 Go to previous messageGo to next message
Guillermo Devi is currently offline Guillermo DeviFriend
I have found the solution to this problem. It has to do with eclipse preferences.
Here is a how to, for solving the problem. It worked for me.
c.onfigs.com/linux/eclipse-indexing-help-error-pop-up-solved/
You will probably need to reinstall... But read the "Beware Drawbacks" section to see what problems you could face.
Regards!
Re: 'Indexing Help...' Has encountered a problem [message #1001437 is a reply to message #986428] Wed, 16 January 2013 17:40 Go to previous messageGo to next message
Oscar Kramer is currently offline Oscar KramerFriend
Guillermo Devi wrote on Tue, 20 November 2012 06:55
I don't understand your solution here. Did you mean to provide a link to another forum entry?
I am experiencing the same problem.
Re: 'Indexing Help...' Has encountered a problem [message #1008180 is a reply to message #1001437] Mon, 11 February 2013 09:52 Go to previous message
Vincent Koldenhof is currently offline Vincent KoldenhofFriend
apparently it is a URL, puzzeld me too so I thought this additional message might help others.
Previous Topic:Whence Eclipse Debugger ids?
Next Topic:PTP startup problems
Current Time: Tue Apr 24 03:22:19 GMT 2018
Powered by FUDForum. Page generated in 0.03250 seconds
