Home » Newcomers » Newcomers » exit code=13(Eclipse won't start)
exit code=13 [message #910978] Mon, 10 September 2012 14:30 Go to next message
Monty Herr is currently offline Monty Herr
When I try to start Eclipse, I get the message in the attached screen capture.
How do I fix it?
  • Attachment: Capture.JPG
    (Size: 72.61KB, Downloaded 48 times)
Re: exit code=13 [message #910982 is a reply to message #910978] Mon, 10 September 2012 14:40 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
so what is the bit-ness of your java? Your Eclipse is 32bit.
Tom
Am 10.09.12 20:30, schrieb Monty Herr:
> How do I fix it?
Re: exit code=13 [message #910990 is a reply to message #910982] Mon, 10 September 2012 15:12 Go to previous messageGo to next message
How do I determine "bit-ness"? (Good word!)
And is it possible to get a 64-bit version of Eclipse? I downloaded and installed from eclipse-SDK-4.2-win32-x86_64.zip.
[Updated on: Mon, 10 September 2012 15:21]
Report message to a moderator
Re: exit code=13 [message #911000 is a reply to message #910990] Mon, 10 September 2012 15:35 Go to previous message
Russell Bateman is currently offline Russell Bateman
Just ensure that you're using a 32-bit JRE with a 32-bit Eclipse or a
64-bit JRE with a 64-bit Eclipse. That yours are mismatched seems
probably based on what you've revealed.
Previous Topic:Opening Files
Next Topic:Configure server test
Current Time: Sun May 19 14:09:56 EDT 2013
Powered by FUDForum. Page generated in 0.01790 seconds
