Home » Modeling » EMF » EMF Serialization in older XMI format
EMF Serialization in older XMI format [message #910918] Mon, 10 September 2012 16:12 Go to next message
Ian Carr is currently offline Ian CarrFriend
How can I serialize an EMF (UML) model using one of the older XMI formats.
I need to export in XMI 2.1 to import into another tool, but my models are being
serialized as 2.4.1 format using the latest Juno.
Re: EMF Serialization in older XMI format [message #910921 is a reply to message #910918] Mon, 10 September 2012 16:20 Go to previous messageGo to next message
Maybe XMIResource.setXMIVersion can help, but I suppose you need UML to
do it for you so please ask about UML on the eclipse.modeling.mdt.uml2
forum.
> formats.
> are being
Re: EMF Serialization in older XMI format [message #910929 is a reply to message #910921] Mon, 10 September 2012 16:39 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
I thought this was asked previously on the UML2 newsgroup, but cannot
find the message.
MDT/UML2 supports backwards compatibility; reading old UML versions.
It does not support forwards compatibility; if you really want it, raise
a Bugzilla. But generally the rationale is that if you don't want UML
2.4.1 don't use it at all; install the older support.
Ed Willink
> to do it for you so please ask about UML on the
> eclipse.modeling.mdt.uml2 forum.
>> formats.
>> models are being
Re: EMF Serialization in older XMI format [message #910930 is a reply to message #910921] Mon, 10 September 2012 16:42 Go to previous messageGo to next message
Thanks for that, I have a Resource which I can probably cast down to an XMIResource?
I assume the string parameter is intended to take values from XMIResource such as VERSION_2_1_VALUE?
Re: EMF Serialization in older XMI format [message #910933 is a reply to message #910929] Mon, 10 September 2012 16:46 Go to previous messageGo to next message
It seems to be a catch 22.
I need the bug fixed tools (including Acceleo code generation) from Juno, which now exports in 2.4.1 format by default. But I am trying to round trip the UML through visual paradigm which in it's latest incarnation supports XMI up to version 2.1 but not beyond. Hence the question.
Re: EMF Serialization in older XMI format [message #910937 is a reply to message #910930] Mon, 10 September 2012 16:52 Go to previous messageGo to next message
Ian,
Yes, UML is using a derived XMIResourceImpl so you should be able to
downcast and use that constant.
> an XMIResource?
Re: EMF Serialization in older XMI format [message #911768 is a reply to message #910937] Wed, 12 September 2012 09:29 Go to previous message
Many thanks,
setting the version or the namespace property seems to work.
For reference, to migrate a file I am able to:
   resource.load
   ((XMIResource)resource).setXMINamespace(XMIResource.XMI_2_1_URI)
   resource.save
Not sure this is changing anything other than the namespace and version properties (I assume that there is nothing exploiting any schema content change), but my files are now being recognised by VP again.
Ian
Previous Topic:[CDO HibernateStore] Cannot use identity column key generation with <union-subclass> mapping f
Next Topic:convert or refactor classic-uml model?
Current Time: Tue May 22 12:13:05 GMT 2018
Powered by FUDForum. Page generated in 0.07900 seconds
