Home » Newcomers » Newcomers » Getting the XML editor and the Android Common XML editor in the same window
Getting the XML editor and the Android Common XML editor in the same window [message #908513] Wed, 05 September 2012 10:03 Go to next message
Björn Jónsson is currently offline Björn Jónsson
I was wondering if the following is possible to do:
When you open a XML file with the Common Android XML Editor you get 2 tabs at the bottom, Graphical Layout and the regular text source.
When you open a XML file with the XML Editor you get 2 tabs, Design and Source. Design being the Node view.
Is it possible to somehow get the Design tab in the Common Android XML Editor?
Re: Getting the XML editor and the Android Common XML editor in the same window [message #908538 is a reply to message #908513] Wed, 05 September 2012 10:41 Go to previous messageGo to next message
Russell Bateman is currently offline Russell Bateman
> Editor?
Please read sticky posts at top of forum.
Re: Getting the XML editor and the Android Common XML editor in the same window [message #908548 is a reply to message #908538] Wed, 05 September 2012 10:53 Go to previous message
Cheers and sorry. Didn't look at it since it had Trouble in the name. You can delete this post.
Previous Topic:jboss tools hibernate is getting error while installing @ eclipse indigo sr2
Next Topic:Cannot open Eclipse [Java Path Issue]
Current Time: Thu Jun 20 03:36:09 EDT 2013
Powered by FUDForum. Page generated in 0.01560 seconds
