Home » Eclipse Projects » Plugin Development Environment (PDE) » Reading resources from a Eclipse plugin ?
Reading resources from a Eclipse plugin ? [message #906001] Fri, 31 August 2012 08:41 Go to next message
Kosala Yapa is currently offline Kosala Yapa
Hi All,
I am trying to read model.ecore at model folder in plugin "com.kosala.model".
Here is my code:
Bundle bundle = Platform.getBundle("com.kosala.model");
URL fileURL = bundle.getEntry("model/model.ecore");
File file = null;
try {
file = new File(FileLocator.resolve(fileURL).toURI());
} catch (URISyntaxException e1) {
e1.printStackTrace();
} catch (IOException e1) {
This gives an error:
Exception in thread "main" java.lang.NullPointerException.
bundle gets null.
Anyone has a clue to slove this issue?
Thanks in advance
K
Re: Reading resources from a Eclipse plugin ? [message #906072 is a reply to message #906001] Fri, 31 August 2012 11:07 Go to previous messageGo to next message
Joseph Carroll is currently offline Joseph Carroll
Use the sample below as something to build off of. To get a resource, first retrieve the bundle using the getBundleForName() and then call bundle.getEntry() to retrieve the resource within the bundle. Note that getEntry() will only search the specified bundle, which will return a platform URL to the resource.
package braintrader.workbench.internal.common;
import org.eclipse.osgi.service.datalocation.Location;
import org.osgi.framework.Bundle;
import org.osgi.framework.BundleActivator;
import org.osgi.framework.BundleContext;
import org.osgi.framework.Filter;
import org.osgi.framework.InvalidSyntaxException;
import org.osgi.service.packageadmin.PackageAdmin;
import org.osgi.util.tracker.ServiceTracker;
@SuppressWarnings({"deprecation", "rawtypes", "unchecked"})
public class WorkbenchCommonActivator implements BundleActivator {
	// Change to match your bundle ID
	public static final String PLUGIN_ID = "braintrader.workbench.common"; //$NON-NLS-1$
	private static WorkbenchCommonActivator defaultInstance;
	private BundleContext context;
	private ServiceTracker locationTracker;
	private ServiceTracker pkgAdminTracker;
	 * Get the default activator.
	 * @return a BundleActivator
	public static WorkbenchCommonActivator getDefault() {
		return defaultInstance;
	public WorkbenchCommonActivator() {
		defaultInstance = this;
	 * @return the bundle object
	public Bundle getBundle() {
		return context.getBundle();
	 * @return the PackageAdmin service from this bundle
	public PackageAdmin getBundleAdmin() {
		if (pkgAdminTracker == null) {
			if (context == null)
				return null;
			pkgAdminTracker = new ServiceTracker(context, PackageAdmin.class.getName(), null);
			pkgAdminTracker.open();
		return (PackageAdmin) pkgAdminTracker.getService();
	 * @param bundleName
	 *            the bundle id
	 * @return A bundle if found, or <code>null</code>
	public Bundle getBundleForName(String bundleName) {
		Bundle[] bundles = getBundleAdmin().getBundles(bundleName, null);
		if (bundles == null)
			return null;
		// Return the first bundle that is not installed or uninstalled
		for (int i = 0; i < bundles.length; i++) {
			if ((bundles[i].getState() & (Bundle.INSTALLED | Bundle.UNINSTALLED)) == 0) {
				return bundles[i];
		return null;
	 * NOTE: This method is marked as public only because the class is located in
	 * an *.internal.* package within the bundle and is not shared outside of the bundle
	 * If you want to make this Activator available from any bundle, change the visibility
	 * of this method to /* package */
	 * @return this bundles context
	public BundleContext getContext() {
		return context;
	 * @return the instance Location service
	public Location getInstanceLocation() {
		if (locationTracker == null) {
			Filter filter = null;
			try {
				filter = context.createFilter(Location.INSTANCE_FILTER);
			} catch (InvalidSyntaxException e) {
				// ignore this. It should never happen as we have tested the
				// above format.
			locationTracker = new ServiceTracker(context, filter, null);
			locationTracker.open();
		return (Location) locationTracker.getService();
	public void start(BundleContext context) throws Exception {
		this.context = context;
	public void stop(BundleContext context) throws Exception {
		if (pkgAdminTracker != null) {
			pkgAdminTracker.close();
			pkgAdminTracker = null;
		if (locationTracker != null) {
			locationTracker.close();
			locationTracker = null;
		this.context = null;
JD
Re: Reading resources from a Eclipse plugin ? [message #907113 is a reply to message #906072] Mon, 03 September 2012 06:13 Go to previous message
JD,
Thanks a mil for this helpful information.
KY
Previous Topic:File Path to jar inside another jar
Next Topic:Editor type based on document location
Current Time: Tue Jun 18 00:34:23 EDT 2013
Powered by FUDForum. Page generated in 0.01918 seconds
