Home » Language IDEs » C / C++ IDE (CDT) » MinGW Toolchain with Eclipse Juno
MinGW Toolchain with Eclipse Juno [message #904580] Tue, 28 August 2012 18:24 Go to next message
Andrey Yavolovsky is currently offline Andrey YavolovskyFriend
I have a problem adding the MinGW toolchain to Eclipse CDT Juno (Build id: 20120614-1722). Not sure what I'm doing wrong, but it was perfectly fine in Indigo.
Here are my steps for installing the MinGW toolchain:
1. Within the Eclipse IDE, from the menubar, select: Help | Install New Software.
2. Enter in the Wascana repository URL. (Sorry, I was not allowed to put the link here because of forum rules)
3. Select the packages that appear and follow the on-screen prompts.
However after Eclipse downloads all the files I'm getting the following error message:
'Installing Software' has encountered a problem.
An error occurred while installing the items
session context was:(profile=epp.package.cpp, phase=org.eclipse.equinox.internal.p2.engine.phases.Install, operand=null --> [R]wascana.binutils, action=org.eclipse.equinox.internal.p2.engine.MissingAction).
No action found for: org.eclipse.equinox.p2.touchpoint.natives.untar.
Does anyone has MinGW installed in Juno?
Or perhaps there is another way of doing the installation?
Re: MinGW Toolchain with Eclipse Juno [message #904871 is a reply to message #904580] Wed, 29 August 2012 09:48 Go to previous message
Axel Mueller is currently offline Axel MuellerFriend
Wascana is no longer supported. Follow the instructions here
Before you ask
- search this forum
- see the FAQ
- google
Previous Topic:Tried all solutions from forum:: Basic C program not working :Binary not found!
Next Topic:Eclipse CDT Juno build doesnt update binary
Current Time: Wed Mar 21 15:08:58 GMT 2018
Powered by FUDForum. Page generated in 0.01557 seconds
