Home » Modeling » M2T (model-to-text transformation) » [Acceleo] select over a Set(String) object
[Acceleo] select over a Set(String) object [message #904500] Tue, 28 August 2012 14:42 Go to next message
Andrea Sindico is currently offline Andrea SindicoFriend
How may I execute a select over an set of String?
I mean setOfString->select(='test') is wrong, also setOfString->select(self='test')
what is the right syntax?
Follow me on Twitter @andreasindico
Re: [Acceleo] select over a Set(String) object [message #904507 is a reply to message #904500] Tue, 28 August 2012 14:54 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
Have you tried defining an iterator variable and using it?
Ed Willink
Re: [Acceleo] select over a Set(String) object [message #904517 is a reply to message #904500] Tue, 28 August 2012 15:25 Go to previous messageGo to next message
My aim is not to iterate over the set. I need to do something only if a string (say 'test') is contained in the set. If the set does not contain that string I need to do something else.
i.e.
[if setOfString->select(??='test')->notEmpty()]
generate something
[else]
generate something else
[/if]
How would you do that by means of an iterator?
Re: [Acceleo] select over a Set(String) object [message #904545 is a reply to message #904517] Tue, 28 August 2012 16:46 Go to previous messageGo to next message
setOfString->exists(s : String | s = 'test')
setOfString->includes('test')
Ed Willink
> i.e.
> generate something
> [else]
> [/if]
Re: [Acceleo] select over a Set(String) object [message #904558 is a reply to message #904500] Tue, 28 August 2012 17:20 Go to previous messageGo to next message
Thank you Ed I did not know that syntax
Andrea
Re: [Acceleo] select over a Set(String) object [message #904802 is a reply to message #904558] Wed, 29 August 2012 07:24 Go to previous message
Laurent Goubet is currently offline Laurent GoubetFriend
Andrea,
Ed's answer is right, I'll just add that you can also use iterators in select and reject operations with the same syntax he has outlined for "exists" :
[setOfString->select(s : String | s = 'test')]
i.e :
variable.operation(iterator | body)
. This same syntax exists for all 'iteration' operation : select, reject, collect, exists, forAll, isUnique, one, any and sortedBy.
Though of course, "includes" is better if you only need to check whether you set contains a given value.
Laurent Goubet
Obeo
Previous Topic:[Acceleo] generating input filename
Next Topic:[Acceleo] Capability Question
Current Time: Fri May 25 15:03:41 GMT 2018
Powered by FUDForum. Page generated in 0.02727 seconds
