Home » Eclipse Projects » BIRT » RAD and BIRT
RAD and BIRT [message #120253] Mon, 30 January 2006 20:07 Go to next message
Originally posted by: dperry.aaamissouri.com
I have been attempting to use BIRT for a few days with RAD. It seems the
report design perspective works correctly, but when I click on the preview
tab, it just hangs indefinitely. Has anyone has any success with RAD and
BIRT? I am using BIRT version 2 and RAD 6.0.1.1 which is built from
Eclipse 3.0.2.
Re: RAD and BIRT [message #120305 is a reply to message #120253] Mon, 30 January 2006 20:39 Go to previous messageGo to next message
Originally posted by: elhanan.migdal-group.co.il
i don't what is RAD, but the same effect i got when i try to process a
table of 220,000 birt just kept eating my memory, used eclipse 3.1.2 here
Re: RAD and BIRT [message #120315 is a reply to message #120305] Mon, 30 January 2006 20:44 Go to previous messageGo to next message
RAD is IBM's version of Eclipse. My report is small - only a few rows, but
it behaves the same way that yours does - just keeps eating up memory when I
try to preview. I can bring up my report on a stand-alone tomcat server
with birt deployed. I would like to get the preview function working
though.
"Elhanan Maayan" <elhanan@migdal-group.co.il> wrote in message
news:29d4269ac17c9ccd3749100cac83ecd8$1@www.eclipse.org...
Re: RAD and BIRT [message #120720 is a reply to message #120315] Tue, 31 January 2006 09:07 Go to previous messageGo to next message
in my case both preview the run report function behave the same way (both
eat up memory.
Re: RAD and BIRT [message #122343 is a reply to message #120720] Wed, 01 February 2006 04:13 Go to previous messageGo to next message
Originally posted by: deosunny.gmail.com
Did you guys try the integration with ReportEngine API?
Re: RAD and BIRT [message #122911 is a reply to message #120253] Wed, 01 February 2006 22:48 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Installing BIRT with RAD should work if you do the following
1 - Download the BIRT Framework and extract to folder (e.g. c:/birt2.0)
2 - Download additional required files (iText, Axis and prototype.js) See
Birt Install page
http://www.eclipse.org/birt/phoenix/build/
Apply addition files to the directory you extracted BIRT to.
3. Navigated to the IBM Rational Links folder,
(e.g. C:\Program Files\IBM\Rational\SDP\6.0\eclipse\links)
4. Created a new link file in this directory named org.eclipse.birt.link
5. In this link file, enteredthe path to the location of BIRT 2.0, e.g.
path=c:/birt2.0
The Eclipse SDK, EMF and GEF are not needed. They should already exist.
Jason Weathersby
BIRT PMC
"Dan" <dperry@aaamissouri.com> wrote in message
news:drls1j$ekd$1@utils.eclipse.org...
> Eclipse 3.0.2.
Re: RAD and BIRT [message #127189 is a reply to message #122911] Thu, 09 February 2006 16:10 Go to previous messageGo to next message
This still did not work. When I try to preview, it eats up all my CPU and
runs forever. This is just a small report that runs in 20 second or so in
Birt 1.0.
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:drrds0$alb$1@utils.eclipse.org...
> Birt Install page
> path=c:/birt2.0
> Jason Weathersby
> BIRT PMC
preview
> > Eclipse 3.0.2.
Re: RAD and BIRT [message #127290 is a reply to message #127189] Thu, 09 February 2006 17:26 Go to previous messageGo to next message
Does the same thing happen when previewing with the Web Viewer?
news:dsfpuh$ta6$1@utils.eclipse.org...
> Birt 1.0.
>> Birt Install page
>> path=c:/birt2.0
>> Jason Weathersby
>> BIRT PMC
> preview
>> > and
>> > Eclipse 3.0.2.
Re: RAD and BIRT [message #127356 is a reply to message #127290] Thu, 09 February 2006 17:39 Go to previous messageGo to next message
Yes it does. It behaves like this if I click the preview tab or go to
file--> preview. If I run the Web Viewer on a Tomcat server I am able to
view the reports, but when I try to preview it runs forever. I believe the
preview uses the embedded Tomcat server like the help does. My help works
though.
I tried to switch the preview function to use the Tomcat server I have
running in RAD, but when I would try to preview, it would change ip address.
Funny thing is, the preview works fine with 1-0-1.
news:dsfu0d$585$1@utils.eclipse.org...
and
in
> > Birt 1.0.
See
> >> Birt Install page
> >> path=c:/birt2.0
exist.
> >> Jason Weathersby
> >> BIRT PMC
the
> > preview
> >> > and
> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #127565 is a reply to message #127356] Thu, 09 February 2006 19:12 Go to previous messageGo to next message
Dan,
Any chance you could download Eclipse, EMF and GEF do an install with those.
create the link in the links directory and fire up a copy to see if it
works?
You shouldnt have to reinstall BIRT. This would only be for a test. If
that works than
we can look at what conflict we are having.
Jason
news:dsfv44$77g$1@utils.eclipse.org...
> the
> though.
> address.
> and
> in
>> > Birt 1.0.
>> >> c:/birt2.0)
> See
>> >> Birt Install page
>> >> e.g.
>> >> path=c:/birt2.0
> exist.
>> >> Jason Weathersby
>> >> BIRT PMC
> the
>> > preview
>> >> > and
>> >> > from
>> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #127607 is a reply to message #127565] Thu, 09 February 2006 19:29 Go to previous messageGo to next message
Previously, on my second machine, I installed Eclipse 3.0.2, which is the
same version of Eclipse that RAD is built off of. I then installed Birt 2.0
and all the prerequisites. The preview functionality worked fine.
Today or tomorrow, I will do as you suggested on the machine with RAD and
report back.
news:dsg462$flp$1@utils.eclipse.org...
> Dan,
those.
> works?
> that works than
> Thanks
> Jason
to
> > the
works
> > though.
> > address.
CPU
> > and
so
> > in
> >> > Birt 1.0.
> >> >> c:/birt2.0)
prototype.js)
> > See
> >> >> Birt Install page
> >> >> e.g.
> >> >> path=c:/birt2.0
> > exist.
> >> >> Jason Weathersby
> >> >> BIRT PMC
seems
> > the
> >> > preview
RAD
> >> >> > and
> >> >> > from
> >> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #127658 is a reply to message #127565] Thu, 09 February 2006 20:03 Go to previous messageGo to next message
It didn't take as long as I thought. On my RAD machine I installed Eclipse
3.0.2 along with EMF and GEF. I linked it to the same Birt 2 directory as
my RAD environment. I then copied over a report, and it previewed fine.
Any ideas?
> Dan,
those.
> works?
> that works than
> Thanks
> Jason
to
> > the
works
> > though.
> > address.
CPU
> > and
so
> > in
> >> > Birt 1.0.
> >> >> c:/birt2.0)
prototype.js)
> > See
> >> >> Birt Install page
> >> >> e.g.
> >> >> path=c:/birt2.0
> > exist.
> >> >> Jason Weathersby
> >> >> BIRT PMC
seems
> > the
> >> > preview
RAD
> >> >> > and
> >> >> > from
> >> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #127791 is a reply to message #127658] Thu, 09 February 2006 22:36 Go to previous messageGo to next message
Are you getting any conflict statements in the RAD logs?
news:dsg7jn$lbl$1@utils.eclipse.org...
> Eclipse
> Any ideas?
>> Dan,
> those.
>> works?
>> that works than
>> Thanks
>> Jason
> to
>> > the
> works
>> > though.
>> > address.
> CPU
>> > and
> so
>> > in
>> >> > Birt 1.0.
>> >> >> c:/birt2.0)
> prototype.js)
>> > See
>> >> >> Birt Install page
>> >> >> e.g.
>> >> >> path=c:/birt2.0
>> > exist.
>> >> >> Jason Weathersby
>> >> >> BIRT PMC
> seems
>> > the
>> >> >> > the
>> >> > preview
> RAD
>> >> >> > and
>> >> >> > from
>> >> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #128167 is a reply to message #127791] Fri, 10 February 2006 16:36 Go to previous messageGo to next message
Which log should I check?
Dan
news:dsgg62$3ps$1@utils.eclipse.org...
> > Eclipse
as
> > Any ideas?
> >> Dan,
> > those.
> >> works?
If
> >> that works than
> >> Thanks
> >> Jason
to
able
> > to
believe
> >> > the
> > works
> >> > though.
have
> >> > address.
> > CPU
> >> > and
or
> > so
> >> > in
> >> >> > Birt 1.0.
> >> >> >> c:/birt2.0)
> > prototype.js)
> >> > See
> >> >> >> Birt Install page
2.0,
> >> >> >> e.g.
> >> >> >> path=c:/birt2.0
> >> > exist.
> >> >> >> Jason Weathersby
> >> >> >> BIRT PMC
> > seems
> >> > the
> >> >> >> > the
> >> >> > preview
with
> > RAD
> >> >> >> > and
built
> >> >> >> > from
> >> >> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #128232 is a reply to message #128167] Fri, 10 February 2006 17:37 Go to previous messageGo to next message
Dan,
I dont remember where the log file is generated in RAD, but on load it
creates a log file showing any problems.
When you preview there should be a log in the workspace that shows any
errors.
Jason
news:dsifq5$hhs$1@utils.eclipse.org...
> Dan
>> > Eclipse
> as
>> > fine.
>> > Any ideas?
>> >> Dan,
>> > those.
>> >> works?
> If
>> >> that works than
>> >> Thanks
>> >> Jason
> to
> able
>> > to
> believe
>> >> > the
>> > works
>> >> > though.
> have
>> >> > address.
>> >> >> > my
>> > CPU
>> >> > and
> or
>> > so
>> >> > in
>> >> >> > Birt 1.0.
>> >> >> >> c:/birt2.0)
>> > prototype.js)
>> >> > See
>> >> >> >> Birt Install page
> 2.0,
>> >> >> >> e.g.
>> >> >> >> path=c:/birt2.0
>> >> >> >> already
>> >> > exist.
>> >> >> >> Jason Weathersby
>> >> >> >> BIRT PMC
>> > seems
>> >> > the
>> >> >> >> > the
>> >> >> > preview
> with
>> > RAD
>> >> >> >> > and
> built
>> >> >> >> > from
>> >> >> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #128257 is a reply to message #128232] Fri, 10 February 2006 17:35 Go to previous messageGo to next message
Where is the log in Eclipse?
news:dsij0n$rqj$1@utils.eclipse.org...
> Dan,
> errors.
> Jason
> > Dan
> >> > Eclipse
directory
> > as
> >> > fine.
> >> > Any ideas?
> >> >> Dan,
with
> >> > those.
it
> >> >> works?
> > If
> >> >> that works than
> >> >> Thanks
> >> >> Jason
go
> > to
> > able
> >> > to
> > believe
> >> >> > the
help
> >> > works
> >> >> > though.
> > have
ip
> >> >> > address.
> >> >> >> > my
> >> > CPU
> >> >> > and
second
> > or
> >> > so
> >> >> > in
> >> >> >> > Birt 1.0.
> >> >> >> >> c:/birt2.0)
> >> > prototype.js)
> >> >> > See
> >> >> >> >> Birt Install page
> > 2.0,
> >> >> >> >> e.g.
> >> >> >> >> path=c:/birt2.0
> >> >> >> >> already
> >> >> > exist.
> >> >> >> >> Jason Weathersby
> >> >> >> >> BIRT PMC
It
> >> > seems
> >> >> > the
on
> >> >> >> >> > the
> >> >> >> > preview
> > with
> >> > RAD
> >> >> >> >> > and
> > built
> >> >> >> >> > from
> >> >> >> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #128350 is a reply to message #127791] Fri, 10 February 2006 18:52 Go to previous messageGo to next message
Originally posted by: to.sreddy.gmail.com
Jason,
I am trying to create a link from RAD to BIRT(both versions 1.0 and 2.0)
with BIRT 2.0
I installed RAD 6.0 and create da link to BIRT 2.0, created a
project,datasource,dataset...>
then i try to preview the result in Dataset mode, i got JVM failure error,
JVM terminated Exit code=-1073741819
with BIRT 1.0
I changed the link file path to BIRT 1.0 created dataset --> able to
preview the result in dataset mode.
Then i dragged a table from the palette and from the DataExplore view
mapped the fields from the table, and now try to preview the result.
I got the following error
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it
from fulfilling this request.
Any clue..
Thanks.
Srini
Re: RAD and BIRT [message #128376 is a reply to message #128257] Fri, 10 February 2006 18:56 Go to previous messageGo to next message
In your workspace under .metadata. Just do a search for *.log and you will
see the catalina logs.
Jason
news:dsij9q$sie$1@utils.eclipse.org...
>> Dan,
>> errors.
>> Jason
>> > Dan
>> >> > Eclipse
> directory
>> > as
>> >> > fine.
>> >> > Any ideas?
>> >> >> Dan,
> with
>> >> > those.
> it
>> >> >> works?
>> >> >> test.
>> > If
>> >> >> that works than
>> >> >> Thanks
>> >> >> Jason
> go
>> > to
>> > able
>> >> > to
>> > believe
>> >> >> > the
> help
>> >> > works
>> >> >> > though.
>> > have
> ip
>> >> >> > address.
>> >> >> >> > all
>> >> >> >> > my
>> >> > CPU
>> >> >> > and
> second
>> > or
>> >> > so
>> >> >> > in
>> >> >> >> > Birt 1.0.
>> >> >> >> >> c:/birt2.0)
>> >> > prototype.js)
>> >> >> > See
>> >> >> >> >> Birt Install page
>> > 2.0,
>> >> >> >> >> e.g.
>> >> >> >> >> path=c:/birt2.0
>> >> >> >> >> already
>> >> >> > exist.
>> >> >> >> >> Jason Weathersby
>> >> >> >> >> BIRT PMC
> It
>> >> > seems
>> >> >> > the
> on
>> >> >> >> >> > the
>> >> >> >> > preview
>> > with
>> >> > RAD
>> >> >> >> >> > and
>> > built
>> >> >> >> >> > from
>> >> >> >> >> > Eclipse 3.0.2.
Re: RAD and BIRT [message #128391 is a reply to message #128257] Fri, 10 February 2006 19:02 Go to previous messageGo to next message
Dan,
You can find the log file in the following path.
...your work space/.metadata/.plugins/catalina.2006-02-10.log
Jason,
Here is my log file for HTTP 500 Error.
WebappLoader[]: Deploying class repositories to work directory
C:\RationalApplicationDeveloperTrial6.0\RADWorkSpace\.metada ta\.plugins\org.eclipse.tomcat\ROOT
ContextConfig[]: Added certificates -> request attribute Valve
StandardManager[]: Seeding random number generator class
java.security.SecureRandom
StandardManager[]: Seeding of random number generator has been completed
StandardWrapper[:default]: Loading container servlet default
StandardWrapper[:invoker]: Loading container servlet invoker
CoyoteConnector Coyote can't register jmx for protocol
WebappLoader[/viewer]: Deploying class repositories to work directory
C:\RationalApplicationDeveloperTrial6.0\RADWorkSpace\.metada ta\.plugins\org.eclipse.tomcat\viewer
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/viewservlets.jar to
C:\ESR\Birt2.0\eclipse\plugins\org.eclipse.birt.report.viewe r_2.0.0\birt\WEB-INF\lib\viewservlets.jar
ContextConfig[/viewer]: Added certificates -> request attribute Valve
StandardManager[/viewer]: Seeding random number generator class
StandardManager[/viewer]: Seeding of random number generator has been
completed
StandardWrapper[/viewer:default]: Loading container servlet default
StandardWrapper[/viewer:invoker]: Loading container servlet invoker
completed
completed
completed
StandardWrapperValve[ViewerServlet]: Allocate exception for servlet
ViewerServlet
javax.servlet.ServletException: Error allocating a servlet instance
org.apache.catalina.core.StandardWrapper.allocate(StandardWr apper.java:672)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:210)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:643)
org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:246)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:641)
org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:171)
org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorReportValve.java:153)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:700)
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:683)
at java.lang.Thread.run(Thread.java:813)
----- Root Cause -----
java.lang.NoClassDefFoundError: org.apache.axis.transport.http.AxisServlet
at java.lang.ClassLoader.defineClassImpl(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:211)
at java.security.SecureClassLoader.defineClass(SecureClassLoade r.java:147)
org.apache.catalina.loader.WebappClassLoader.findClassIntern al(WebappClassLoader.java:1679)
org.apache.catalina.loader.WebappClassLoader.findClass(Webap pClassLoader.java:968)
org.apache.catalina.loader.WebappClassLoader.loadClass(Webap pClassLoader.java:1409)
org.apache.catalina.loader.WebappClassLoader.loadClass(Webap pClassLoader.java:1289)
org.apache.catalina.core.StandardWrapper.loadServlet(Standar dWrapper.java:885)
org.apache.catalina.core.StandardWrapper.allocate(StandardWr apper.java:668)
ViewerServlet
completed
ViewerServlet
ViewerServlet
ViewerServlet
ViewerServlet
-Srini
Re: RAD and BIRT [message #128404 is a reply to message #128257] Fri, 10 February 2006 19:08 Go to previous messageGo to next message
sorry, ignore my earlier mail,
search here
...your work
space/.metadata/.plugins/org.eclipse.tomcat/catalina.2006-02 -10.log
Re: RAD and BIRT [message #128416 is a reply to message #128376] Fri, 10 February 2006 19:12 Go to previous messageGo to next message
Here is the log:
C:\aaa\PolicyStarRAD\.metadata\.plugins\org.eclipse.tomcat\R OOT
C:\aaa\PolicyStarRAD\.metadata\.plugins\org.eclipse.tomcat\v iewer
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/axis-ant.jar to
C:\birt2.0\eclipse\plugins\org.eclipse.birt.report.viewer_2. 0.0\birt\WEB-INF
\lib\axis-ant.jar
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/axis.jar to
\lib\axis.jar
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/commons-discovery-0.2.jar to
\lib\commons-discovery-0.2.jar
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/jaxrpc.jar to
\lib\jaxrpc.jar
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/saaj.jar to
\lib\saaj.jar
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/wsdl4j-1.5.1.jar to
\lib\wsdl4j-1.5.1.jar
completed
Re: RAD and BIRT [message #128504 is a reply to message #128416] Fri, 10 February 2006 20:15 Go to previous messageGo to next message
Dan
Is this all that was in the log file when previewing the report?
I dont see anything obvious. I checked which version we tried this on and
it was Birt 2.0 and RAD 6.0.
Jason
news:dsiov9$ikg$1@utils.eclipse.org...
> Here is the log:
> \lib\axis-ant.jar
> \lib\axis.jar
> to
> \lib\jaxrpc.jar
> \lib\saaj.jar
> completed
Re: RAD and BIRT [message #128517 is a reply to message #128504] Fri, 10 February 2006 20:23 Go to previous messageGo to next message
That is all that is in the log. I am using RAD 6.0.1.1. I might try
rolling back to 6.0 to see if that makes a difference.
news:dsis9p$prr$1@utils.eclipse.org...
> Dan
> Jason
> > Here is the log:
> > \lib\axis-ant.jar
> > \lib\axis.jar
> > to
> > \lib\jaxrpc.jar
> > \lib\saaj.jar
> > completed
Re: RAD and BIRT [message #129344 is a reply to message #128517] Mon, 13 February 2006 17:06 Go to previous message
The problem seems to be with IBM Rational Application Developer Fix Pack
6.0.1.1. I rolled it back and now I am able to preview with Birt 2.0.
news:dsit5b$rha$1@utils.eclipse.org...
> > Dan
and
> > Jason
> > > Here is the log:
completed
> > > \lib\axis-ant.jar
> > > \lib\axis.jar
> > > to
> > > \lib\jaxrpc.jar
> > > \lib\saaj.jar
> > > completed
Previous Topic:Unable to preview chart- status 500 err
Next Topic:Drill-Through in 'Run' mode (not frameset mode)
Current Time: Thu May 24 08:19:54 GMT 2018
Powered by FUDForum. Page generated in 0.03982 seconds
