Home » Modeling » TMF (Xtext) » customize ContentAssist(prevent items from being displayed)
customize ContentAssist [message #902814] Mon, 20 August 2012 15:06 Go to next message
Robert Wild is currently offline Robert WildFriend
Member
Hi everyone,
With my dsl and the default implementation, ContentAssist suggests some items which are syntactically invalid. As stated in (http://www.eclipse.org/forums/index.php/t/369336/) I obviously have to redo the validation semantics for ContentAssist.
The documentation talks about how entries can be added to ContentAssist. But how do you prevent that. The entries don't seem to be created by the complete{TypeName}_{FeatureName}()-Methods in Abstract<lang>ProposalProvider but by AbstractJavaBasedContentProposalProvider.createProposals(...). But overriding and modifying this method doesn't work because it uses private fields.
What ist the correct way to filter or remove completion proposals?
Any help would be appreciated since I'm tired of debugging and guessing. Is there any other documentation source than http://www.eclipse.org/Xtext/documentation.html ?
Re: customize ContentAssist [message #902839 is a reply to message #902814] Mon, 20 August 2012 18:00 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
a cannot reproduce your complaints.
there is a completeItemSet_items
which calls lookupCrossReference without a filter. simply call lookupcrossreference with a filter in your subclass
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: http://xtext.itemis.com
Twitter : @chrdietrich
Blog : christiandietrich.wordpress.com
Re: customize ContentAssist [message #902840 is a reply to message #902814] Mon, 20 August 2012 18:01 Go to previous messageGo to next message
~Christian
Re: customize ContentAssist [message #902841 is a reply to message #902814] Mon, 20 August 2012 18:01 Go to previous messageGo to next message
~Christian
Re: customize ContentAssist [message #902842 is a reply to message #902814] Mon, 20 August 2012 18:01 Go to previous messageGo to next message
~Christian
Re: customize ContentAssist [message #902980 is a reply to message #902842] Tue, 21 August 2012 13:56 Go to previous messageGo to next message
Member
That's what I tried. I've overidden all methods from Abstract<lang>ProposalProvider and removed all of the method contents. Those were references to completeRuleCall() and lookupCrossReference(). I thought when all of them are gone, no proposals will be provided. But I still get all the proposals I got before.
It seems the proposals are finally added in AbstractContentProposalProvider.createProposals(), so I tried to track back who triggered the call. And interestingly there's no code in the call stack that I can modify.
Here's the callstack from one of many executions of createProposals. The language is called TopologyDSL by the way.
Thread [main] (Suspended (breakpoint at line 107 in AbstractContentProposalProvider))
	TopologyDSLProposalProvider(AbstractContentProposalProvider).createProposals(ContentAssistContext, ICompletionProposalAcceptor) line: 107
	TopologyDSLProposalProvider(AbstractJavaBasedContentProposalProvider).createProposals(ContentAssistContext, ICompletionProposalAcceptor) line: 246
	CompletionProposalComputer.exec(XtextResource) line: 51
	CompletionProposalComputer.exec(Object) line: 1
	XtextDocument$XtextDocumentLocker(AbstractReadWriteAcces<P>).readOnly(IUnitOfWork<T,P>) line: 32
	XtextDocument.readOnly(IUnitOfWork<T,XtextResource>) line: 78
	XtextContentAssistProcessor.computeCompletionProposals(ITextViewer, int) line: 69
	ContentAssistant.computeCompletionProposals(ITextViewer, int) line: 1830
	CompletionProposalPopup.computeProposals(int) line: 556
	CompletionProposalPopup.access$16(CompletionProposalPopup, int) line: 553
	CompletionProposalPopup$2.run() line: 488
	BusyIndicator.showWhile(Display, Runnable) line: 70
	CompletionProposalPopup.showProposals(boolean) line: 482
	ContentAssistant.showPossibleCompletions() line: 1656
	XtextSourceViewer(SourceViewer).doOperation(int) line: 930
	XtextSourceViewer(ProjectionViewer).doOperation(int) line: 1535
	ContentAssistAction$1.run() line: 82
	ContentAssistAction.run() line: 80
	ContentAssistAction(Action).runWithEvent(Event) line: 498
	ActionHandler.execute(Map) line: 185
	LegacyHandlerWrapper.execute(ExecutionEvent) line: 109
	Command.executeWithChecks(ExecutionEvent) line: 476
	ParameterizedCommand.executeWithChecks(Object, Object) line: 508
	HandlerService.executeCommand(ParameterizedCommand, Event) line: 169
	WorkbenchKeyboard.executeCommand(Binding, Event) line: 468
	WorkbenchKeyboard.press(List, Event) line: 786
	WorkbenchKeyboard.processKeyEvent(List, Event) line: 885
	WorkbenchKeyboard.filterKeySequenceBindings(Event) line: 567
	WorkbenchKeyboard.access$3(WorkbenchKeyboard, Event) line: 508
	WorkbenchKeyboard$KeyDownFilter.handleEvent(Event) line: 123
	EventTable.sendEvent(Event) line: 84
	Display.filterEvent(Event) line: 1262
	StyledText(Widget).sendEvent(Event) line: 1052
	StyledText(Widget).sendEvent(int, Event, boolean) line: 1077
	StyledText(Widget).sendEvent(int, Event) line: 1062
	StyledText(Widget).sendKeyEvent(int, int, long, long, Event) line: 1104
	StyledText(Widget).sendKeyEvent(int, int, long, long) line: 1100
	StyledText(Widget).wmChar(long, long, long) line: 1509
	StyledText(Control).WM_CHAR(long, long) line: 4640
	StyledText(Canvas).WM_CHAR(long, long) line: 345
	StyledText(Control).windowProc(long, int, long, long) line: 4528
	StyledText(Canvas).windowProc(long, int, long, long) line: 341
	Display.windowProc(long, long, long, long) line: 4972
	OS.DispatchMessageW(MSG) line: not available [native method]
	OS.DispatchMessage(MSG) line: 2531
	Display.readAndDispatch() line: 3752
	Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 2701
	Workbench.runUI() line: 2665
	Workbench.access$4(Workbench) line: 2499
	Workbench$7.run() line: 679
	Realm.runWithDefault(Realm, Runnable) line: 332
	Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 668
	PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 149
	IDEApplication.start(IApplicationContext) line: 123
	EclipseAppHandle.run(Object) line: 196
	EclipseAppLauncher.runApplication(Object) line: 110
	EclipseAppLauncher.start(Object) line: 79
	EclipseStarter.run(Object) line: 344
	EclipseStarter.run(String[], Runnable) line: 179
	NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not available [native method]
	NativeMethodAccessorImpl.invoke(Object, Object[]) line: 39
	DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 25
	Method.invoke(Object, Object...) line: 597
	Main.invokeFramework(String[], URL[]) line: 622
	Main.basicRun(String[]) line: 577
	Main.run(String[]) line: 1410
	Main.main(String[]) line: 1386
All of this is part of a non-trivial project I inherited. The original author also doesn't know what exactly goes on here. Any help would be greatly appreciated.
Robert
Re: customize ContentAssist [message #902992 is a reply to message #902980] Tue, 21 August 2012 14:33 Go to previous messageGo to next message
Hi can you share a simple sample grammar and proposalprovider that
reproduce the problem?
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: customize ContentAssist [message #903123 is a reply to message #902992] Wed, 22 August 2012 06:55 Go to previous messageGo to next message
Member
Using the mydsl example:
Is this the correct way to build filters for the ProposalProvider?
public class MyDslProposalProvider extends AbstractMyDslProposalProvider {
	public void completeModel_Greetings(EObject model, Assignment assignment, ContentAssistContext context,
			ICompletionProposalAcceptor acceptor) {
		if (false) {
			completeRuleCall(((RuleCall) assignment.getTerminal()), context, acceptor);
	public void completeGreeting_Name(EObject model, Assignment assignment, ContentAssistContext context,
		if (false) {
Without the if clause the completeRuleCall statements actually add the proposals to the acceptor. With it the same proposals are added anyway. Why is that? Is that supposed to happen? What is the correct way of doing this?
Re: customize ContentAssist [message #903126 is a reply to message #903123] Wed, 22 August 2012 07:17 Go to previous messageGo to next message
Hi I still do not get your point - if you leave the methods empty
(don't call anything not even super) everything should be fine. What
is the unwanted proposal you get?
Re: customize ContentAssist [message #903130 is a reply to message #903126] Wed, 22 August 2012 07:38 Go to previous messageGo to next message
Member
In this example I wanted the ContentAssist not to display anything. But it doesn't do that, even if I leave the methods empty. Just to test how to exclude proposals I wanted to exclude everything.
Re: customize ContentAssist [message #903133 is a reply to message #903130] Wed, 22 August 2012 07:41 Go to previous messageGo to next message
Don't forget completekeyword ;-)
Re: customize ContentAssist [message #903156 is a reply to message #903133] Wed, 22 August 2012 09:28 Go to previous messageGo to next message
Member
ok, when I override completeKeyword the Keyword won't be displayed. So far so good. But after a keyword the content assist still proposes Name although completeGreeting_Name() has an empty implementation. It is called and does nothing but still the proposal is somehow displayed. How can I get rid of that?
Re: customize ContentAssist [message #903162 is a reply to message #903156] Wed, 22 August 2012 10:42 Go to previous messageGo to next message
Did you override completeID too?
Re: customize ContentAssist [message #903178 is a reply to message #903162] Wed, 22 August 2012 12:25 Go to previous message
Member
ok, now I'm able to filter all proposals in the mydsl example. In my project there are some more methods I'll need to override, but I guess I'm gonna find them in ProposalProvider's parent classes.
Thanks for your help.
Previous Topic:Arithmetics example can't serialize Definition references
Next Topic:xtext compatibility error with type from imported package
Current Time: Thu Jan 18 05:55:52 GMT 2018
Powered by FUDForum. Page generated in 0.02558 seconds
